Fireball
#3
Posted 31 March 2005 - 04:24 AM
The boom is very low, so if you get too much heel on when reaching you will not be able to depower by letting the main out because the boom will be dragging in the water. Bear away.
Very sensitive upwnd to the centerboard - make sure that the centerboard case is not floppy and tired because that's a pain to fix.
It's not a OD - but a develpment class except for sail area and hull shape + weight. I'm pretty sure that every boat is rigged differently and the foils are different shapes. My dad built his out of plywood, but there were also some made of 100% glass and some glass hulls with plywood decks.
You can have a spinnaker launcher (tube in deck) rather than bags. The launcher is much easier to use than a bag.
Don't take it out in heavy air on your first day.
#6
Posted 31 March 2005 - 05:34 AM
Ingmar, on Mar 30 2005, 07:46 PM, said:
I'd go along with that.
Blabert: Who built it and when?
Used to sail a Chippendale with Needlespar rig. Nice boat. Great trainer for 505's and more......... only negative.....a poxy little chute.
#8
Posted 31 March 2005 - 07:52 AM
I've got a bizarre shot of the boat we sailed at the Europeans and Worlds qualifiers. For some reason the crew is trapezing 2 feet higher than needed - perhaps it was much wavier than the photo shows.
herehttp://www.navwiz.com/photokorn/photos/8/med_1102611889-8.jpg
#9
Posted 31 March 2005 - 08:44 AM
Fireball UK website
They are a laugh and great for just blasting around in. They also have a bandit PY handicap (in some peoples opinion ;) )
#10
Posted 31 March 2005 - 08:52 AM
wraith, on Mar 30 2005, 11:52 PM, said:
A lot of 'ballers do seem to trapeze high- if you look at the gallery here you'll see a lot of instances. It's good to see a development class which has stayed closeish to roots, unlike the Cherub for instance which has moved so far away from the original.
Attached File(s)
#11
Posted 31 March 2005 - 10:08 AM
Wet Spreaders, on Mar 31 2005, 04:24 AM, said:
[QUOTE]
Ummm, without wanting to be too much of a pedantic pain in the arse (yep, well OK I AM being a PPITA) a "1970s version of a skiff" was actually...a skiff. A '70s skiff had shedloads more sail than a Fireball (maybe 3 times the kite in an Aus 14), much more righting moment, much more open rules.
Interesting to see once again the differing definitions of "development class" you have in the 'States, AFAIK the Fireball class has ALWAYS called itself a one - design although tolerances are wide.
FWIW, maybe a workable definition of "OD" is something where the rules contain the whole shape; the Fireball rules include a copy of the hull lines and if you build to it you'll create a real boat that really sails.
In contrast, in a development class there's nothing that defines a floating shape....there's just a bunch of points at the limits to the box. Or that's a definition that would fit the UK, NZ, Australia, France, Germany and everywhere outside of NA.
#12
Posted 31 March 2005 - 10:30 AM
Their small kite does suck, but to compensate, they normally include very tight reaches to try and make the downwind ride the most fun possible, considering.
I would definitly call the class OD, with loose tolerances.
Really fun boat when the wind is extremely strong, and most other classes stay on the beach.
#13
Posted 31 March 2005 - 10:33 AM
Chris 249, on Mar 31 2005, 10:08 AM, said:
I've always figured that a one design is one where the same bloke always gets the designer's royalty - eg Peter Milne always gets the royalty if you build a Fireball, but if you build a Cherub John Spencer (or his estate) gets nothing, instead it goes to whoever designed that particular shape, Bethwaite, Farr, Murray or whoever (to mention some older designers people here will know.
I suppose you could say that a Fireball was the 70s equivalent of a skiff in the Northern hemisphere in that the equivalent sorts of people who now sail SMODs that they believe are skiffs then would have probably sailed Fireballs (or 505s), but in no other sense at all.
Actually I'd dispute that the Cherub is that far from its roots compared to the Fireball. OK, they look different, but John Spencer's Development classes were just about always for a reasonable performance boat that the ordinary bloke could design and build themselves, and that's still happening. By contrast the Fireball looks the same, but was orginally designed as a cheap boat with a strong self build element. This has long gone in favour of high spec manufacturer built boats which the sailors in the class believe home builds can't compete with. So which has gone further from its roots? They've both evolved, but in different ways.
As for gift handicaps, you hear that a lot in some places, but its never struck me that way. They're just one of those boats (small sail area, low hull length, narrow waterline beam) which are strong in some conditions so on the occasions when they do do well people notice...
#14
Posted 31 March 2005 - 11:33 AM
I usually managed to be a bit lower - but IIRC this was a race after a gale, and we wouldhave had 8 to 10 foot seas in the bay...
#15
Posted 31 March 2005 - 11:40 AM
87 UK
5 Shetland Fireballs
5 Australian Fireballs
10 French Fireballs
2 Czech Fireballs
9 Irish Fireballs
3 Swiss Fireballs
1 Canadian Fireball
2 American Fireball
1 Kenyan Fireball
1 Italian Fireball
The class expect the entry to top 150 should be a cracking event.
Event website http://www.fireball-worlds.com/
#16
Posted 31 March 2005 - 01:24 PM
Dude, it's a two sail reach. A good crew always trapezes higher on a two sail because most skippers can't keep up with the changes in apparent wind when sheeting main and steering. So you will often get a roll into windward.
Plus the boat is flat and the sails are trimmed in, he doesn't need to go lower.
#17
Posted 31 March 2005 - 02:25 PM
dont attack me - I am the crew in that photo!
Glad to hear I was doing ok ..
#18
Posted 31 March 2005 - 03:09 PM
we trapped high also it's was not umcommon for the boat to skip over a wave stick the nose up and douche the crew
#19 Guest Anarchist Tenacious J_*
Posted 31 March 2005 - 03:57 PM
Quite a shame there aren't more of them here in the States. Trying to convince the owner that we should go to Montreal for North Americans. He wants to do Nationals in Pymatooning. Perhaps we can do both...
#21
Posted 31 March 2005 - 08:55 PM
32057, on Mar 31 2005, 08:17 PM, said:
So Great!
That seems the antithesis of US boats. We race J24s Lightings, Thistles, Snipes, CFJs and 420s for the most part. in the US. I wouldn't describe any of those boats os "so great".
We used to have a 400 boat US fleet of Fireballs in the 70s. There is still balling (as it is known) in Ohio, South Carolina, and a great midwinter regatta at Davis Island YC in Tampa, FL.
Fireballs are inexpensive, tuneable, planing dinghies. They weigh 175# and will plane upwind in 13 knot winds and downwind in 9 knots. Relativley easy to handle 25 knots. A real handfull in 30 knots. (what fun boat isn't) Competetitve crew weights are (were?) between 295 and 320 pounds. (We won a lot of national races at 260) (But a lot more at 300)
The one-design rules are quite permisive in running rigging, but tight in sails. The hull shape is controled at the ends and the cockpit bulkhead frames at the front and back of the cockpit with +- 4 mm at most points, with a couple extra points along the rocker.
They are easy to build for home craftsmen using the stitch and glue method, or serious craftsmen could buld them with chine stringers.
Rule allows good centerboard foil sections, but tight control on the profile. The rudder rule is wide open.
I seemed to find a bunch of disreputable deviations within the rules for the hull and deck that were subsequently outlawed.
What is the thwart number of the boat in question?
Sign In
Register
Help
MultiQuote
