Here are additional details of Orange II's difficulties, from an e-mail from navigator Roger Nilson.
Best, Tim Zimmermann
http://www.wetasschronicles.com
Email from Roger:
"On the way down to Cabo Verdes in fresh NE trade winds, we had flawless sailing except two small happenings. One was catching a 2 meter long shark, which got folded around our starboard daggerboard. After stopping and backing, the poor backbroken shark could be seen floating off.
The other was suddenly breaking the steering cables on port side. At 25 knots of boatspeed with 1100 sqm of sail, it is not good loosing control. A fast reaction from the helmsman and another crew quickly running over to take the helm on the other side, and all was fine.
Early morning the 2nd of March a strong, hard, vibrating sound developed under the area of the propeller. We knew the shark had not been close to that area, so it had to be something else. The hope was that we had caught something, but the sound was indicating a worse condition, as it got stronger and stronger into the last dark morning hours.
At 0530 we stopped and backed off. No improvement. We decided to slow down the track, and at 0630 we had sailed the boat into the lee of Ilha de Santo Antao, the most north-western of the islands in the archipelago of Cabo Verdes. Our very experienced diver Vlad went down into the dark and bumpy water. He brought bad news to the surface.
The oval, streamlined "box" made out of carbon and foam, covering the vertical square drive to the propeller, had started to peel off from the bottom of the boat...
First we decided to sail down to the smoother waters of the doldrums, hoping to fix it there. But 70 nm later, running fast with the genaker, the noise got worse and worse. Our cat was creating heartbreaking sounds, and we had to look for better options. We altered course 45 degrees to port and aimed for Fogo Island in order to find a really calm place leeward of this large Island. As the daylight was vanishing, we changed the course a bit and pointed at the smaller but closer Island Brava, the most south-easterly of all the volcano-created islands.
After finding a flat, windless spot, very close to this dry but pretty island, Vlad was down with his diving bottle again. The mission was to see and evaluate if we could repair or cut off the whole thing.
The conclusion came soon. As you are not allowed to lift the boat out of water during a Jules Verne, we were facing a hopeless case. No chance to repair or cut off the box and strut below water with resources available onboard. To continue with high speeds in the Southern Ocean would be dangerous. Further damage to the bottom of the hull could have developed. "
