Halyards on which side?
#1
Posted 20 September 2004 - 03:10 PM
As far as I know there isn't a standard. However, probably headsail halyards are often on the port side....is this due to rounding marks to port?
#3
Posted 20 September 2004 - 03:25 PM
J/130, on Sep 20 2004, 03:20 PM, said:
My 3 boat mains had 2 port one stbd.
spin hlyrds one on each side.
dont think it matters where the main is.
#6
Posted 20 September 2004 - 03:34 PM
J/130, on Sep 20 2004, 11:20 AM, said:
You want to have them like this so at mark roundings the mastman doesn't have go to the leeward rail to jump the halyards. We have always made this change on any boat we sail on. Don't know if anyone else agrees or not, always works great for us.
#8
Posted 20 September 2004 - 03:38 PM
#9
Posted 20 September 2004 - 03:40 PM
oldskool, on Sep 20 2004, 11:34 AM, said:
We also changed my boat so that the port-side spinnaker halyd is hoisted from the stbd side. Mast man raises halyard from the windward side, while keeping weight up high.
Great way to go and easy to change - all you need is a bosun's chair and a wire shirt hanger to make the swap.
Concerning the jib and main halyards - I don't see a reason to change them to another side. Since you don't have a need for high-side weight when raising either the jib or main, keep them where they are.
My two cents.
#10 Guest Anarchist David Levine_*
Posted 20 September 2004 - 03:43 PM
From a practical point of view for boats optimized for around the bouy racing with standard port roundings, you put a Spinn (Center) halyard on the starboard side, next to the main, so that as you come down the windward approach to the rounding, the guy who's jumping the halyard's on the windward side of the boat. That leads you to keeping the Jib halyard(s) on the port side. Where nicely enough, in a classic round the bouys race, you want to have your bowman/mastman jumping the jib back up as you come into the leeeward mark, chute up, on part tack.
Now, on a lot of modern designs, where the main goes is pretty irrelevent. We don't reef, much, we haul the main up once, underpower, and leave it up, and play the cunnginham for luff tension on the sail. That said, it's really nice when the strings are in traditional places, if only because it makes it easier when I hop on a boat and want to go sailing. :-)
- David
#11 Guest Anarchist Hot Wheels_*
Posted 20 September 2004 - 04:00 PM
longy, on Sep 20 2004, 03:38 PM, said:
Ditto.
Just be sure the internals clear the spreader base hardware inside.
Some spars have a bar inside connecting the spreaders, especially if there is any chance of the spreader being torqued aft by the upper, as on a Sonar. This means the internal halyards must be on the correct side of the bar to prevent chafe and friction as the spar bends upwind.
#12
Posted 20 September 2004 - 04:07 PM
Primary jib halyard on port side so if you are doing a headsail change you can set up for an inside hoist on starboard tack. Life is easier if you don't have right-of-way issues half way through the change, and inside hoists are faster to set up.
#15 Guest Anarchist coachizzorules_*
Posted 20 September 2004 - 07:14 PM
jib - port side. so when you come out of the mark (usually on port tack), you can adjust the jib halyard from the high side, if you didn't guess right on halyard tension on the hoist
spin - cleats onto starboard side of mast. raise spin from windward side on a typical starboard tack mark rounding.
LOCK THE THREAD
#16
Posted 20 September 2004 - 07:22 PM
#18
Posted 20 September 2004 - 08:39 PM
Crank Boy, on Sep 20 2004, 12:13 PM, said:
7.9 sailor, on Sep 20 2004, 06:21 PM, said:
that makes all the sense in the world
That is completely wrong. The red halyard has to be on the port and the green has to be on the starboard side. It will never work the way he has it set up.
#19 Guest Anarchist Aeolus_*
Posted 20 September 2004 - 09:03 PM
Aeolus
#20
Posted 20 September 2004 - 09:07 PM
Forgot. this is Frisco..
Main Halyard on port side + Gay
Main Halyard on Stbd = straight
Main Halyard in middle means your ass hurts
Spin halyards boths sides meanas you go both ways
#23
Posted 21 September 2004 - 04:19 PM
PNWGuy, on Sep 20 2004, 11:31 AM, said:
yep- spin on high side for bear aways
jib on prt for roundings- thats where you want the weight 99% of the time
minor divergence- but we dont have a 2nd spin; but 2nd jib on stb
#24
Posted 24 September 2004 - 06:47 AM
The main halyard is to Stb. because if I ever want to throw a reef in or out I want to be on Stb. tack. (single line reefing lead to Stb with jammer in boom).
Sign In
Register
Help
MultiQuote
