MidPack
J/88
Could use two experienced crew for the race Annapolis to St Michaels this Saturday. Transportation back provided.
Apparently there's a J-Fest Regatta in Toronto the week before the J88 North Americans in Youngstown.  With Quantum LYRA in Rochester, that's potentially three one-design regattas in three consecutive weekends on Western Lake Ontario.
J/Fest Great Lakes
Ashbridges Bay Yacht Club, Toronto, Ontario Canada
Contact: Roger Van Vlack
July 21-23, 2017
I am making up some shorter lower headstay strops if anyone needs them. Also going to attempt to solve the misalignment issues many boats have, but I think all boats have the cross piece glassed in a slightly different orientation.
Also have complete sets of lifelines of 5/32" wire if you need to replace your dyneema prior to NAs. $430 delivered.
Jeff Goff
904.495.1894
The lower headstay strop is an interesting component. We had ours changed to a 1" shorter version at BIRW, the old one had a bend in it where it comes through the furler base.
After installing the new one and then tuning the rig, we discovered the new strop was bending in the same way as the old one thereby loosening off the rig. That meant we were chasing the rig tuning for a few days until the strop acquired the requisite bend.
My first time racing a J88, fun boat and met some great people in the fleet at BIRW.
The strop on Deviation had no noticeable bend. It's my theory that the actual attachment bar in each boat is in a slightly different place. We do believe out strop is not exactly centered in the drum and are planning to shim the lower toggle in an attempt to get the furler to work 1/2 decently.
An interesting option maybe for some boats to convert to the Euro setup with no furler and Hank on sails.
Jeff Goff
I just installed one of Jeff's strops on my boat. The old strop did not have a bend, it was just too long. New strop is working great and we can finally get the headstay tune where we want it. As a side benefit, the furler, while still less than ideal, works much better.
The Mid-January "J" Fest 2018 is posted.
From Iris Vogel, J88 Class President:
Announcing the first event of your J88 winter series. [St. Pete NOOD is another one]
We have a deal worked out with Sailor's Wharf in St Pete, they offer storage at $9' per month on the trailer
and a special haul/launch package.  They are located close to St Pete Yacht Club and they provided excellent
service last year.
Contact Carol Sells (727) 823-1155
csells@sailorswharf.com
Edited by Bill's Sock Puppet
The formatting on this forum is really fucked up. Sorry for all the edits.
Some J/88 cruising. A friend bought a J/88 Mai Tai and sailed her from hamble to Gothenburg (11 days and 865 nautical miles).
That looks like a great trip - I'm assuming that with the inshore course,  and the 81 miles a day average that you day-sailed most of it and were able to 'park up' most nights ?
Hornet finally got out to play (sting). Thanks Tim Ford for the pics.
Textbook perfect day of racing!
Looking at adding some wind instruments to #28. Currently we have a prostart and shift but we would like to have wind info for more repeatable trim and tuning. I did some research and I'm kind of leaning towards the B&G Triton 2 Speed/Wind/Depth package. I'm not interested in drilling holes in the boat to mount the displays. Can Triton2 displays be mounted on a simple open back mast mount or does it have to be sealed on the back side? Thoughts?
Does anyone have any other suggestions? Garmin? Raymarine?
Looking for the next boat and considering a J88 - can you tell me what breeze the boat needs to get up on a plane and how/why it is faster than a J92S which seems to have pretty much the same length, weight, and SA/D?
The Triton 2 displays use standard NMEA 2000 Micro - C connectors which can be sealed watertight.  There is no separate power feed as they are pretty low power and get feed power from the N2K bus.  Use the molded connectors, the rubber o-ring in the connector and put a dab of dielectric grease on the connector end before mating with the display.  The open back mast mounts should work fine.
It's technically a semi-plane and I'm not sure it's a go/no go threshold exactly, and of course highly point-of-sail dependent. Where a OD J/105 needs close to 20 kts to "plane", the J/88 breaks loose closer to 15 kts. The J/88 is over 2700 lbs lighter than a J/105 yet IIRC the OD chute is 96 sqm (J/88) vs 89 sqm (J/105) - dramatic difference off the wind.
I've never sailed on a J/92 or a J/92s so I can't offer a comparison, and I don't have any idea how big the J/92s chute is. As you've referenced planing - "length, weight and SA/D" are good indicators what to expect upwind, but not entirely off the wind.
I crewed some at DIYC many years ago, it was a great club!
18.9 knots in that Swedish video looks like planning to me!  Or is there some Euro conversion factor for knots?
There are a few subtle differences, with a full crew of 7 it will get up on the plane in around 18kts of wind sailing vmg angles, 2 up that will be much lower. The 92s dspl/L is higher than the 88s when not taking into account the spinnaker size, the 92s carries around 82sqm and the 88 around 92sqm. The d/L ratio of the 88 is lower than the 92. In typical j boats fashion nothing is drastically diffent between generations but a few small things add up to make the 88 just a bit sweeter to sail
What we see is in line with JL92S' comments. On our 88, we get 11-12 kts of boat speed with full crew and wind speed in the 18-20 kt range.
1 hour ago, Greyhound37 said:
Picking up a new Triad next month. Any Florida races appropriate for a J88?
from J88 Class President ...
Quote
For all who have missed the winter schedule:  Also, see the J88 website for information.
Mid-January J Fest 2018  -  St Petersburg FL -  January 19 - 21, 2018
2018 Helly Hansen NOOD  -  Regatta St. Petersburg  -  St Petersburg FL  February 16 - 18, 2018
2018 Sperry Charleston Race Week  -  North Charleston SC  -  April 12 - 15, 2018
In St Pete, we have a special rate for storage at the Sailor's Wharf
Boat deliveries can be arranged through:  Dan CoughlinJeff Goff,  and Jeff Pawlowski
The most important thing is to enter the regattas and get your housing early, especially in St Pete.
Other upcoming events:  J88 Class party, time and place TBA
See you all on the water,
Iris
Has anyone here with a US built boat experienced any faults with their spreaders? Mainly on the inboard ends.
Apparently it's a common fault on the UK boats because the masts are inverting downwind and causing the spreaders to fail at the inboard end.
Is that the fault you are referring to?
As much as I like the J88 concept (under 30', inboard, head, asy on sprit, semi-planning) I just cannot justify the price.  If you didn't have the coin for one of these, what would you be sailing?
Honestly I do not understand either why such a price differential between the J/88 and the J/92s (although the latter is not being built anymore). I understand the carbon rig makes some difference, but 50% difference of boat price is hardly justifiable...
Columbia 30 or 30-2. Gotta say the boat checks all the boxes with some bonus points.
The Lumbo is almost 10 years old now. People thought is looked funny for a Sportboat with the cockpit comings and an inboard engine. Now JBoats are doing the same thing.
Both boats are relatively close in comparison. Check the numbers. SA/Displ are very close.
Same cockpit layout, inboard, Aso/sprit, but the Lumbo is lighter so should hop a plane a bit quicker. You can also stand up inside. Some also have a Southern Spars carbon rig.
You can buy a Lumbo and trick the hell out of it and still pay less than half for a new J88. If class racing is important to you, stay with the J.
If you're just doing PH stuff or offshore, you have options.
Problem with tricking out a Lumbo (or any other older boat) is the resale value is still largely set by the un-tricked out ones...so while it may be half the price of the J, you still have a pretty soft resale price when the time comes...doesn't mean it isn't a viable course of action...just know the "trick out" money is unrecoverable
The 92s costed around £80-90k on the water  the end of production about 6/7 years ago so in today's money it would be around 100k. An 88 currently is about £130k+ the keel construction on the 88 is more complex using a fin made up of a SS shaft with a fairing around it made of glass and like you say the carbon rig will add costs. When you break it down the two boats are more similar
The problem you have here is that the J 88 is being built currently.  Businesses have ever higher costs.  A new boat represents the costs of doing business TODAY and hopefully a little profit or else why be in business.
A boat built 5-10 yrs ago was priced according to the costs of business 5-10 years ago.  Trust me, it was cheaper then.  In addition, the first owner absorbed that cost when he sold it as most subsequent owners do also.  The large market of used boats further lowers the 'market' price and means the previous owners have absorbed some of the boat's cost/value loss.  You don't want a new boat builder to absorb those costs or they won't be a builder for long.
I get it.  A new boat is outside most folks budgets and even more so when we see other bigger, better, faster boats on the market for less.  Be grateful that there are still some folks willing to pay for the 'new boat smell' AND willing to absorb the depreciation 'costs'.  If you think that a new boat 'should' cost much less, I encourage you to start a boatbuilding business and maybe you'll have ton's of folks beating the path to your doors.
Disclaimer:  I am not a boatbuilder but just a simple business owner who has gotten the opportunity to see the inside of 'real business costs'.  FWIW, I would never be a boatbuilder as the margins are not worth justifying the investment--assuming a profit could be made...
Note from J88 Class President:
Quote
Dear J88 Class,
2017 has been an amazing year for the J88 class.  We had more than 10 one design events in Long Island Sound and all over the country:
Key West Race Week, seven boats
Charleston Race Week, five boats
American YC Spring Series, seven boats
Larchmont YC Edlu distance race, five boats
Cedar Point One Design, nine boats
East Coast Championships, BIRW, seven boats
J88 North American Championships Youngstown, twelve boats
YRA LIS Championships RYC, five boats
STC Vineyard Race SYC, four boats
STC Championships RYC, seven boats
American YC Fall Series, nine boats
Congratulations to the winners but most of all to everyone who participated and helped the class to grow.  We will have new boats joining the fleet and a great schedule for 2018, see the website J88class.org for a complete listing of one design events.
There is still time to enter the J Fest in St. Petersburg, FL, on Jan 19-21, St Pete NOOD on February 16-18 and Charleson Race Week April 12-15.  Deviation is also doing the J-Cup in Cowes, England on May 25-27 which should be great fun.
The great thing about a J88 is the travel regattas that you can attend, so if you need help with boat deliveries or logistics, contact me and I will make it happen!
Wishing you and your families all the best for the Holidays and New Year,
Iris Vogel
I'm interested in gently used 88 sails.  If anyone is looking to clear out their basements let me know what you'd want for them?
I have a handful of gently used 88 sails.
PM me if interested.
PM sent.
I am looking for the carbon bow hatch roller for chute take downs. Or the complete kit that Quantum was offering.
Anyone know where to get this?
Massive respect to the team Blue Flash for entering their J88 into the Race to Alaska!
Funny story really. We did Ensenada, California Offshore Week, and the MAC...so what's left for an offshore oriented J88?  According to my 19 y/o son and his college sailing friends, it's R2AK time.
Easy right? Just pull the engine, add solar panel and build a pedal drive from scratch.
Gotta say the pedal drive has been a challenge. Built one.. broke it. Built another.. broke it... the epoxy for version 3.2 is drying now...
Bought some oars yesterday :)
The crazy youth can be followed on instagram here:.
That is amazing! Good Luck to you all and enjoy the trip!
On another note I had a steel cradle built for my J-88. Bought a trailer so I don't have any use for it now. Free to a good (or bad) home. Located Jabins Annapolis
Some J/88 solo sailing.
We started a new archipelago race, 125 nm solo through all the small islands on the west coast of Sweden. J/88 first to finish. J/111 fastest around the course.
What's the autopilot set up?  It didn't look like a tiller unit.
The autopilot they (and another UK J88) use is a bracket bolted directly to the rudder and the pilot ram exits out of the transom trough a watertight gasket. Not sure of the specific hardware used (they all run B&G systems so maybe a triton or h5000 pilot).
Stunning scenery and it’s nice to see Mai Tai enjoying a second life in the far north :)
I'm interested in finding a used J88 and am in Vancouver Canada.
Owner of Hull #58 has also decided not to race the NAs in Chicago.  Boat is located in Milwaukee, and can
be delivered to the event.  Great shape, professionally maintained.  PM me if interested.  Thanks.
J-88 Hornet did the Annapolis to Oxford race 9.8
23 knots from the NE decreasing to 15-20
24 boats in A-2 we finished second.
GP-26 was first by 14 minutes. He was hitting 20+knots. We were 12-14 with a max of 16.5 in the gusts.
Great event! Photo is the start hoist and trim going on
The J-88 continues to be an effective PHRF tool. Annapolis YC race to Solomons 1st in A-2 and 5th in fleet of 60 boats. It helps to have downwind conditions and reaching :-)
4 races, 3 firsts and one second to the Donovan 26 is a downwind 15-23 kts.
Very fun platform
Do any of you J/88 owners have a remedy for putting the main on? I'm getting sick of dropping ball bearings all over the deck. I'd prefer to leave the cars on the mast but that seems problematic as well. I'd probably deposit as many nut/bolts into the harbor as ball bearings. While reading yachtworld write up on Ventus it sounds like they have a solution: " All cars with custom pins for quick removal for the storm trisail". I've thought of a quick pin type solution but I'd be concerned about them coming out as well. Thoughts?
What type of main track do you have? The French built selden rigs don’t use cars with bearings, only sliders. On our old main with slides we have used drop nose pins for the very top car so we can flake the main flat rather than remove the gaff batten. I imaging drop nose pins could work for the whole sail
US built boats have Harken AA sliders for the main. https://www.harken.com/uploadedimages/CategoryImages/3d6548a0-1441-4cdf-a140-019315975b78.png
Fortunately there aren't many of the bearing cars. 4 if memory serves. We use the 4" section of track that came with the boat to remove the cars, invert and tape.
BTW 8 88's signed up for Charleston Race week 5 months out. Impressive. That will be my first one design race in any boat.
We can just about scrape 5 boats together in the UK but sadly they are very expensive and the French are increasing the prices again next year so it’s doubtful they will sell any new boats again. In your area which sailmaker is the most popular?
The Chesapeake Bay only has two 88's racing that I am aware of and the second one does not compete in local distance.
Not sure if its North or Quantum. I had North first but the main drove me to drink so now I am all Quantum.
a new 88 coming to NL next year.
We have a Quantum A5 for our 88.  It’s close to a code 0 but still qualifies as a spinnaker with the minimum mid-girth. It’s a game changer for us on any race with a longer close reaching leg in light air.
A couple of questions, do you have a bobstay fitted and is the sail on a furler?
20 hours ago, JL92S said:
Anyone out there running code 0s on their 88s?
We run a code zero with a bobstay. .  I think a furler would be nice but we kept cost down. Not many conditions and races we can use the code zero. What races do you plan to use it for?
The UK class just allowed them into class racing, a few of the boats here also race 2 handed so a couple of boats have them. For ours I had considered a Doyle cableless code 0 if we went down that road
Hi! I can't believe I found you on sailing anarchy! Thanks so much again for allowing me to be part of that adventure, I hope you don't mind me posting a picture here but sailing that boat off the coast of northern British Columbia was the most fun thing i've done sailing. So grateful for all you guys I met on Blueflash.
Jack, Thx for bringing back summer memories from the great north.  Spending a couple weeks with 4 teenagers returning the 750 miles from Alaska on that little boat was epic! (and cozy :)
Still so very proud of you guys for pulling off R2AK!
Quick comment on the code zero discussion:  On BlueFlash we use the typical zero from TWA 70-90 in TWS up to 10-12.  But the real asset on the J88 is the smaller zero we run up to TWA 55 in TWS 5-8.  To be effective it's important to have full pole out, use a 2:1 tack line, bobstay, and once hoisted,  full backstay. It's run through the jib car.  This creates a tight enough luff and narrow sheeting angle to act as a true upwind sail, which is very fast in the J88.  North has our design.
Does your small code 0 measure as a spinnaker or jib?
Code zeros are generally made with the mid -girth at 75% of the foot so that they can rate as a spinnaker rather than as a jib.  Hence the advantage in offshore/coastal situations where we often sail less than "full upwind mode" anyway for strategic reasons (often sailing faster to the next big shift).  The smaller zero gets you there maybe +.5-1.0 knots faster, yet the rating is unchanged.
I should add that after 4 happy years, our J88 is on the market to be replaced with a new J121 and we are very excited!  Also happy to share details of J88 offshore/coastal tips via PM to the interested.  We raced her a few thousand miles(N2E, Islands, Cal Offshore, Mac, R2AK etc) and did learn quite a bit as we went along.
Two 121’s in Portland?  Super cool!
Did your upwind zero foot pass over the lifelines or through the saddle at the pulpit?
Outside pulpit but sheets to jib track Twa 55-65, so crosses lifeline.  Further offwind we switch lead to spin blocks with twing at rail. Helpful to have two wichard padeyes midway either side of stanchion base to allow various leads for zeros/jib reaching.
Our hope is J121 for Cabo 2019, not PDX. It's really an offshore boat. We need some luck for that timing!
How much have the A2 sail designs changed for the J/88? I'm using a 2014 vintage north A2 and seem to have some downwind speed issues. We are probably on the heavier side for crew weight and I'm sure we have room for improvement on our jibes. Just trying to gauge how much of our issue is using a gen1 J/88 North A2. Thanks in advance
Quantum are on their 7th generation of A2 for the J88. We went from a first generation North A2 like yours to a second generation sail in 2015 followed by a Quantum A2 in 2017. But a brand new version of your existing sail will still be much faster. When you try and run deep look to see how much the upper leech tries to collapse as the old and tired material can no longer support the shape.
The problem for you is you're using a 4.5 year old sail which, even being as charitable as possible to your treatment of the sail, stopped being fast approximately 2.5 years ago.
I'm looking for a used A2 if anyone has one available. PM me.
J-88 Oceanvolt has been asked about several times as I look through the entire thread but nobody really answered. Does anyone have any input on the boat and how they work? Knowing the battery range is perfectly good for all the sailing I do which is club racing and daysailing, I do want to deal with the range in some fashion so I can cruise if I want to. Has anyone seen them using a suitcase generator to augment the batteries for longer trips?
Dan
There may be some available from Chicago owners especially after the bad blood caused by Verve Cup Regatta protests.
Dan
Very little known about the oceanvolt boat. It was on the market about a year or two ago and not sure where it went. Heaven knows how much it would have cost to buy an 88 brand new with the ocean volt system but I guess a retro fit job could be done to an existing boat.
Personally I didn’t like the UK sails and the self tacking jib of the OV boat. I’m not sure how many amp the system draws but I would much rather fit an Efoy fuel cell and then you’d have a truly silent boat with extended range.
I assume the OV system uses a lithium battery bank, I know the saildrive can be used as a hydro generator but that’s about all I know about the system.
Theres plenty of good European 88s on the market in the UK right now at what must be an attractive price considering the £-$
JL, a hydrogen fuel cell was my first thought as well but I think I need about 2000 watts to maintain a good speed and that, according to what I can read, would take a ton of gas to maintain for cruising objectives like 10-12 hours. It does look like I could do it pretty easily with a little suitcase generator that I would only put on board when going far away.
From what I have seen conceptually, the fuels cell is capable of both using hydrogen gas and making it if you add power and water. My mind went to the boat sitting overnight tied up to the dock with power plugged in and making fuel for the next day! Lots of apparent issues with this including now compressing the gas so you can take it with you. Interesting concept though.
Dan
The efoy fuel cell we race with on a sunfast 3600, it’s fuelled by cartridges of methanol and the byproduct is water that fills a small bottle that you empty. We did a 2000 mile race that took 12 days, we used 7L of methanol in total which powered the B&G H5000 system including a 12” plotter and autopilot that was used around 90% of the time. We never started the engine once and arrived at the finish line with a 100% battery level and fuel to spare. It produces a small amount of heat, is the size of a small desktop pc and is almost completely silent. Granted it won’t give you the motoring range of a Diesel engine but combined with a couple of solar panels and the saildrive working on regen it wouldn’t be a bad solution. Besides, the J88 is after all a sailing boat and not a motor boat...
9 hours ago, jackolantern said:
The oceanvolt boat got demolished by Courageous in the 12Meter on J/88 on C&C 30 protest from 2016
What? Can you elaborate? Was the protest based on the propulsion system?
Dan
Quote
You don’t have to be a fanatic enemy of CO2 emissions to appreciate the Oceanvolt option. Racing sailors also might find it interesting, because, J/Boats says, it comes with a weight savings of approximately 150 pounds compared to the standard 14-hp diesel. The bitter pill however, is the $20,000 surcharge, which can be even higher, depending on how much battery capacity the owner desires.
from boats.com
Thanks MidPack, I have voraciously read and watched everything I could on this boat in anticipation of trying to make a deal for one. I now have the deal in place subject to a successful review of my boat. Time will tell, but I think the range and necessary re-charging will be absolutely no problem given how I use the boat. Typically I motor from my slip out of the marina then out of the harbor less than a 1/4 mile followed by racing or day sailing then reverse the process.
I believe improving battery technology and other power sources will make the occasional cruising case work well too. If fuel cells can continue to improve then 100 mile range under power should be achievable and one would hope most of your trip would be under sail!
Dan
N, thanks so much for the link! I had missed the story somehow and now it all makes sense though I wish I could see it all to learn from it.
Dan
Pics of race #2 Saturday December 7th of the 49th Manuel Fagundes Seaweed Soup Regatta include a J88.
J88 usa80 Wings, American YC / New York is now Ravenette in California.
49185650243_eee168ff76_b.jpgIMG_1256_DxO
49186335622_d79a0fe6bd_b.jpgIMG_1259_DxO_4500
49186346287_e64660d763_b.jpgIMG_1265_DxO_4500
64 boats registered.
22 boats started
The winds gusted above 25 knots and it rained.
Race results are on Jibeset.net, Link.
https://www.jibeset.net/show.php?RR=GGYC_T009157579&DOC=r2&TYP=html
MidPack, I saw this as well and tried to understand what really happened from the two sides of the story. Trying to make sense of it makes me feel sorry for Protest Committees and the job they have. Dan
