Barnyb
Team UK
8 hours ago, surfsailor said:
I also think that - since nearly 50% of the main foils are allowed to be 'flap' - most early designs are going to comprise straight sections with anhedral. That's not to say design teams won't be working on organic shapes, but rather that - since organic shapes with articulation will require some tricky design solutions - teams are certainly not going to reveal what they are working on in that area until the last possible minute.
:lol:
7 hours ago, Tornado-Cat said:
Amusing that the brit boat has 2 floats, which also means that the real boat may capsize in low wind before flying, a small gust and...
Glass half empty, or glass half full? Could just mean they want to be careful, as its a completely new concept and they aren't sure of its characteristics yet.
Training wheels - there's almost certainly little or no ballast in these wings/arms which there will be in the real thing - scale effect - so if you want to keep the displacement parameters in the right sort of area then no spare weight.
So they'll be good for mimicking the straightlining aspects, but not for maneuvering as as you won't have the equivalent polar moments - in either yaw or heel principally, but also partially in pitch.
In sailing terms, then this will be both more sensitive and more reactive too than the full sized animal, but they will learn plenty from the exercise.
^ Do you think they have any intention to use the rig - or is it just the to model COG etc for tow-testing?
And the outriggers?
I guess you realize that they don't need to be extra careful with a small test boat and that foils are probably not balasted yet, but will be soon (my guess).
But they will learn the hell of a lot.
Of course they need to be extra careful - any day lost to damage is a day wasted, and right now that is their key advantage...they will only learn when they are out on the water and anything no matter how incidental that limits that is regarded as a *major problem* right now.
I would think Safety is paramount, and getting the most out of their equipment is also important? Especially given its a brand new concept.
Bah, if they capsize they can put the boat up in a matter of minutes with the assistance, it won't be the same with the real boat !
But back on the original point, have you ever sailed a 5o5, 470, 420 or something like that ? did you have crew on a line ? now imagine replacing him with a ballasted dummy :)
Damage is damage
Pretty sure anybody trying a trapeze for the first time has been that guy once or twice... :D
At least it can't go flying around the front of the mast!
I find when I am looking at the frankenboat that the foils don't really seem curved enough for me, surely the leeward foil is going to want to be further out with the foil sections still flat?
The way they are there it's either really high out of the water or the foils are heavily canted when sailing (this would generate lift to windward so maybe it is intentional).
11 hours ago, rh2600 said:
Damage is damage
Agree... mechanical, electronics, everything.
And time lost to re-check everything.
On 7/22/2018 at 2:37 AM, hughw said:
Wing forward? Yup, used that on the Q23 3 years ago!
Ran it in cfd and worked out just fine, and also in practice.  Also on the Q17, Flo1, and a couple of others upcoming shortly.
It was used before that on the Assassin Moth 10 years ago, courtesy of Nick Holroyd.
The best thing that ever happened to my Assassin foils was getting them ripped off by a crab pot.  Design might have been ok, but the rubberised epoxy they must have used to build them made for flexi pieces of shite!
Replacing them with Mach 2 ones made the boat actually nice to sail and able to do more than 20knots.
Looks like at least 8 ft clearance needed for that tiny test boat in regards to another boat making contact with the foils during racing.  So how does that translate to the JC75?  At least 12?  Not good with gauging distances with photos but it seems clear tight action in the pre-start and close racing around the course and turning marks can't/won't happen.
WetHog  :ph34r:
15 hours ago, rh2600 said:
Damage is damage
Especially when considering salt water and electronics, and other things, don't get along very well.
WetHog  :ph34r:
WetHog  :ph34r:
Tend to agree, especially if the teams find in testing that the boats have a tendency or possibility of doing a bit of the sideways crawl that Ben did in Bermuda. The JC75 going sideways with one of those big blades in the air will be a fearsome sight to see, and, I suspect, will lead to a set of rules designed to keep the boats away from each other.
It doesn't seem to likely with the design shown as the more horizontal part of the foil will break the surface first without affecting the part that provides the lateral lift.
However it seems possible that with high enough speed only the inboard half of foil will be immersed (with the T-junction above the waterline) and works as surface piercing (hydroptere style) angled foil.
If that happens you would start getting some sideways action and now you have the other half of the foil pointing straight out just above the water ready to take out course marks or anything nearby!
2 hours ago, 2Newts said:
The JC75 going sideways with one of those big blades in the air will be a fearsome sight to see..
Surely this will play to the Brits advantage. Centuries of experience in combat with big blades attached ....
21 hours ago, kiwi777 said:
BAR Prototype being launched
This boat only has dynamic stability, any sailor can imagine how instable it is.
In 9 kts of wind they don't have enough speed to fly and there is no way their lw ballasted foil can act as a keel, not sure their ww foil up is enough to prevent them from capasizing. That means that they would have to have their ww foil in the water and use it to increase the righting moment. Anyway, strange kind of pterodactyl.
Bernasconi seemed to think 9 knots would be sufficient.
That is highly amusing.... Or, do you think they are just being cautious while they learn to sail something which has never been done before?
Day late and a dollar short newbie...maybe check the thread next time
Thanks to Rennmaus .....
we saw these a few days ago.
Monday it finally appears on the FP - with a link to a different thread, well done.......where they have just reached the 'Jesus Lizard point' in the discussion. :(
They did not put floats on foiling cat prototypes for last ACs.
It is true that the AC75 is proportionally wider than the brit proto, but, seriously, if you are a sailor, would you sail this narrow boat without keel, and with a ballasted foil down pulling to leeward and adding to the push of the sail without 2 floats ?
Foiling trimarans have float above their foil, the hydroptère too has floats, it's for a reason !
Depends what side of history you want to be on. If you want to be part of a potentially revolutionary new concept, and be one of, if the first, to make it work, then you would sail it. If you're content to sit back and let someone else do it, or wait till next time, thats your decision. Imagine if those who tested and ensured the stealth bomber worked said "Oh nah, no ones done it before, and it kind of looks too dangerous for me, no thanks. Or the guys who flew the first mission to the Moon said "No thanks, its too dangerous", they wouldn't be remembered as heroes like they are today. There's a reason why guys like Gary Powers, Neil Armstrong, and Buzz Aldrin are, and always will be remembered, because they did something no one had done before. I'm not saying these boats are going to be as influential as the Moon landings, or the Stealth Bomber, but these boats have the potential to be revolutionary, and those testing them are in essence, test pilots, so they've obviously decided which side of history they want to be on.
Is it just an assumption by some here that the foils arms on the test boat are unballasted - or is that know?
Can you really get any meaningful data out - with a critical component of the whole concept missing?
I recognize I did not time to read the rule properly, I wonder if the ballast could be water whichamount could be controlled when the foil is up ?
Answer here I guess
Thanks, stable and fast until the ww foil hits the water. Nice.
They drop it, then it hits the water.
Here too
NEOS Team UK foil-borne on their 28' test monohull, which SI has dubbed the 'Water Bug'
2018-07-24 | TOM EHMAN
PLYMOUTH, GBR (#1076) – A friend in the UK has kindly sent a video taken today of Sir Ben Ainslie's (GBR) modified Quant 28 under sail and in full flight. The video was taken by Harry Aitchison and appeared this evening (London time) on the London Corinthian Sailing Club Facebook page. The post was cheekily entitled, "We have liftoff." It is the first video of which we are aware of Sir Ben's test platform. We previously had pictures of the yacht dockside and under tow, but this is the first video of the yacht sailing let alone fully foil-borne. It appears the floats seen in recent photos have been removed for this video, leading one to believe that the floats are necessary for stability while at the dock and under tow. Your thoughts?
https://www.sailingillustrated.com/single-post/2018/07/24/AC36-First-video-of-INEOS-Team-UK-fully-foil-borne-on-their-28-test-monohull-which-SI-has-dubbed-the-Water-Bug
2 hours ago, mad said:
Nice find!! Wonder how happy the team are about that showing up so quickly?
Then again, the Solent isn’t exactly private.
Looks like fantastic, fururistic monohull sailing to me! Can’t wait to see more!!
Yeah, it looks a lot less awkward sailing than when it is hanging in the air.
I'd say they've gone without, it's not really going to make the biggest of difference to the boats when foiling, as the centre of gravity when sailing isn't going to be that different.
It's really would only on a boat this size move a few feet to windward, on the big boats it still won't be that much, I guess the only real point (IMO) is the ability to self right the big boats. Self-righting this little boat with a small rib will be east as hell, and of course won't disqualify them from the race for using outside assistance ;)
I'd imagine ballasting would decrease the amount of hydraulic effort required to get the foil back into the correct position for a tack or gybe and give significant advantage in terms of righting moment (or does that not matter once you are foiling? I wonder if the foil can trim fwd and aft then its a useful trim tool when it comes to weight trimming the boat for level.
...and if you were making a testbed, wouldn't you test all the parameters you need to, as laid out in the rules? bit of a pointless exercise with questions unanswered so I'd guess that these foils (or the generation of the foils to come for this boat) will have internal voids so that they can play with different levels of ballast and measure the effects against synthetic modelling.
Am I right in thinking that UK is the first team to actually get out there with a prototype?
No floats, which confirms what thought, they are necessary for light wind, or at the dock. The good point is to see them going well with a soft sail.
Blown away by that video.  So cool.  Much better than expected at this stage.  Game on.  Excited.
Yep, looking good. Well done FRACKIBAR, Dan B and the algorithms  - works right out of the box, again.
Will hopefully counter some of the nay-saying Whineasaurs
A nice NASA-like progression through the development - or so it would appear.
Re ballast. remember that the foil arms are a supplied item, so there is no point in 'playing with ballast in voids' there (unless you are doing it on behalf of the whole group!?). The foil wings are open +/-.
The Herald's take... https://www.nzherald.co.nz/sport/news/article.cfm?c_id=4&objectid=12095149
What is so new here ? forget the mono and think platform. I noticed right from the beginning that it was very close from the Vampire Project that has been sailing for years. The difference are the inversed V foils tips and the flaps.
It was nonsense to move the whole foil for stability, flaps are going to be the real improvement. But the inversed V might provide auto stability too.
Everything is new here.
39 minutes ago, swedishswimmingteam said:
I've gotta say, it looks WAY more stable than I thought it would be this early in the piece.
9 minutes ago, mfluder said:
Imagine this scaled up to 75 feet. Game on!
So long as the boats stay a specific distance apart.  ;)
WetHog :ph34r:
WetHog :ph34r:
Thats usually the idea. Its not bumper cars you know.
1 minute ago, mfluder said:
WetHog :ph34r:
C'mon wh, we've been all over this already
No, not usually.  Just in the AC.
WetHog  :ph34r:
WetHog  :ph34r:
Maybe time to stop watching and or following the AC then?
It looks to pop up on the other foil very quickly...flaps are going to be a game changer for control.
Looks better tuned for pitch control already as well.
I follow the AC for national reasons, cool boats and seeing said cool boats match race.
Why do you follow the AC?  Serious question.
WetHog  :ph34r:
WetHog  :ph34r:
Because 1) National reasons (Real) National reasons.
2) Like you I enjoy seeing the boats and technology associated.
3) Because I've followed every AC since 87 and was there to witness the homecoming of the winning 95 team, the successful defence of 2000, and the debacle of 2003. Yet I and many others kept the faith and saw our dreams come true.
4) Kiwi's have a passion for the AC unlike many other countries.
Good reasons.  I too have followed since '87.  Saw KZ1 in person when it made a visit to Annapolis.  Very cool boat.
I notice match racing isn't on your list.  That explains our disagreement.  Fair enough.
WetHog  :ph34r:
WetHog  :ph34r:
Match Racing is great, but realistically, in today's era of speed end extreme performance, match racing is only part of the overall package. We haven't seen real match racing since 2007, and probably won't for a few cycles. Boats just hit the corners now because thats what makes for great TV. But there are plenty of match racing regattas to follow. Swedish Match Racing tour, the Congressional Cup, etc.
Ok, then if its just about speed now, and match racing is basically and afterthought, then you would be ok with making the AC a fleet race?  Start off Rangitoto Island, all boats head up to Little Barrier Island, round Little Barrier Island to starboard and the 1st one back wins the Cup?  Or how about a speed trial, one boat at a time?
WetHog  :ph34r:
^ Hmmmm, sounds a lot like GS's DOG default course - was he wrong too IYO?
Not necessarily and if GD went that route he probably would of gotten more Challengers.  :lol:
WetHog  :ph34r:
Or if he was as rich as Croesus he could have just paid extra teams to enter - imagine that!?
That's 2 of your moans taken care of...next
Why does match racing need to be in slow boats.
Isn't a match race a race between two boats, fast or slow?
I’m curious how many Emirates fan boys threw a tantrum about imaginary course boundaries, but now try to justify the imaginary diamond around the dopey foils.
Edit: and now try to justify it being good for racing.
Try and justify it not being good racing. And saying "I don't think it will be" isn't justifying it.
So, just for the record, you’re saying that if I dig into old threads, I won’t find you pouting about artificial boundaries?  A simple yes or no will suffice.
First of all, there is a HUGE difference between the diamonds around the boats, versus the course boundaries around the course. The course boundaries were introduced solely to keep the boats close to ensure close racing. The Diamonds are being introduced to keep the boats apart due to safety concerns. But by all means, dig all you like.
Tell yourself whatever helps you sleep at night. It’s just as stupid. It’s an artificial boundary to deal with a stupid boat.
Afraid to answer my question Clarkey boy?
The only stupid thing is your question, and your stupid comment. Don't let me catch you following this AC since everything about it is stupid. I will call you out for your hypocrisy if you continue following this cycle.
I think that the boundaries were largely due to pond venues. We may not see that this cycle.
As the races won't be in a pond. As gd says, the north shore beaches will be a fabulous vantage point, spread out for a dozen miles. No amphitheater.
On 7/24/2018 at 4:07 PM, Tornado-Cat said:
Answer here I guess
Actually, the answer is the 3.375 m radius circle in the Design Rule.  It takes a heavy foil to get the c.g. of the arm and foil to be outside the circle.  Think of it like twin winged bulb keels.
Can't be anything but impressed by that B)
Short straightline vid didn't really prove much on its own but this vid is much more convincing.
That looked pretty close to a foiling gybe & at the least they got back up quickly without obvious struggle, flight looks reasonably stable.
We do still not know what kind of angles they can pull though.
We've seen a lot of vids with boats reaching on foils. The gybe is way more impressive!
that was an almost foiling gybe in a dying Solent sea breeze - pretty impressive stuff given the wind strength.
if they are doing this in less than 10 knots true then the mind boggles when it comes to the full size bus! closing speeds at the bottom mark are going to raise a few heart rates.
so where are the US, ITA, NZ test boats?
Yes, and wingeg bulb keels attached to the side of the boat.
I was wondering if they could fill their upped foil with water but the space seems too limited.
ETNZ are going straight into their first AC75 early next year. Nothing before then by the looks.
Yep, may have just about been 10kts in the ‘gusts’ very impressive for such small breeze
is that a bit brave?
"the difference between bravery and stupidity is the outcome'
Not really - their simulations obviously indicated good stability, and BAR's mini-rig has proved that too be true, and that ETNZ are right to be just getting on with a bigger boat.
23 minutes ago, Tornado-Cat said:
The boat looks more stable sailing and gybing than the GC32 for sure and even AC50s.
Who are you and what have you done with the real TC?
in the computer being raced hard 24/7 ;)
That flybe certainly looked 'perfectable' - (even if the angle is horrendous at present)
Finally allowing flaps instead of moving the whole foil was long overdue.
Considering GD thinks some of what Coutts did with AC35 wasn't that bad, offering teams a design package to buy in the hopes of getting more Challengers, I wouldn't rule out an AC36 version of SoftDick Japan popping up in the near future.  Especially if the politicians start chirping about team bases going unfilled.  Patrizio the Poodle and Matteo the Magnificent have the money to do it.  ;)
WetHog  :ph34r:
Oh boy, we got a new forum monitor who will arbitrarily determine who can and cannot follow the AC and participate in discussions on this forum.
WetHog  :ph34r:
Wrong, time before Guillaume Verdier had already worked on a projet of a 39 ft in NZ. The boat was not constructed but the project was finished, so TNZ already had a package of a smaller boat done.
Wethog, you will recall that all the ETNZ fans who were inwardly critical of AC33/34/35 had the good grace to keep their negative opinions to themselves. Nobody had a bad word to say. Politeness demands they we should behave towards ETNZ with all the tolerance and good grace previously displayed by their fan base.
(Hey, I know not all the ETNZ fans are bell-ends. Only some.)
WetHog  :ph34r:
What I'm saying is, you go on about how dangerous the boats are, how silly the boats are, how they "can't be match raced" how ridiculously expensive they are, how you don't agree with what ETNZ and LR are doing, you don't agree with the Nationality/ resident rule, but you weren't an Oracle fan either, how you want to see "traditional match racing".
You say you like watching cool boats match racing, well you've already said you don't like the boats, and they are too dangerous and silly, so you don't like the boat, so there's one of the things that you want gone.
You've already said the boats can't be match raced either, so there's the second thing you want to see gone too.
The rules are set, so the residential, nationality rule isn't going to change.
So whats left for you to like about it? Why follow it if you don't like anything about it? You're not going to see anything you want to see, so why waste your time following it?
I comment on boats whatever some may think.
The irony is that you thought I criticized the AC75 because "I hated TNZ", but the boat has been designed by a french and a brit :)
