• Announcements
    • Zapata
I'm on it. Dilaudid every 4 hours, Tylenol every 4 hours, offset by 2 hours.
I was outside yesterday boosting my car and forgot I was supposed to be using my walker. Got about 6 steps in before I realized and went back for it. My wife thinks I'm pushing it a bit.
When you start the PT you will find out what "pushing it" is.
I was afraid of that.
Keep pushing it Ish, the folks that get into trouble are the folks who don't push it, because it hurts. And they suffer the rest of their lives because of that. Push. And keep pushing until a Doc tells you to back off some...
Question:
The boat came with a kevlar racing sail in pretty good condition except for a split near the head, along a stitch line. I think it could be repaired by a professional, with little effort.
However, the sail has been bagged for years, and has mildew all over it. I believe the mildew is permanent, under the laminate. Is this just unsightly or does it damage the sail?
Wet and Forget is available from Amazon and Costco in the US. I use it around the outside of the house but have not used it on the boat yet.
Spray and Forget is one of the North American versions of same.
Just be aware of imitators, i used to think it was all the same shit and bought whatever 30secs crap was on special, but wet and forget is quite different. A mate had a roller cruising-laminate genoa and it looked like crap, however a spray with the good stuff and it has looked sweet ever since. 2 years ago now.
Yep, seems easily available here. I'll give it a go.
"Not everywhere is flat."
I know. We have hills here, and are able to conveniently locate our water storage tanks on them. Depending on the water source, we may or may not use the whirly-things called pumps to get the pressure up to the level of the storage tanks.
re: pushing it:
You need to know what your pain tolerance is. If you are prone to holding back because of pain, then yes push it. If you are prone to damage yourself because you push it when you shouldn't, then don't push it. I didn't think the rehab for my knee replacement was that bad. In many ways it was a relief to be actually doing something to help the healing process, instead of the seemingly interminable waiting for it to heal.
Pics dammit! We need more pics!!
Of the boat?
Splash was supposed to be this past Friday. Fail.
My boat is parked in the "Land of Misfit Toys," way in the back. It's a quagmire back there. I was told that the yard had some gravel brought in and would launch me on Friday. I showed up a week later on Friday, as per my two earlier phone conversations with the yard scheduler, but when I inquired at the office, no one knew what the hell I was talking about and the gravel was still in a big pile. The yard scheduler was out to lunch. They decided the ground was too wet for the travel lift anyway. The scheduler told me to call back Monday.
I called today, as directed. The answer? "We're going to spread some gravel around and launch you on Friday."
So, I have no new pics and no real news except that everything below the waterline has been inspected, repaired or replaced as necessary.
New anti-foul, and I've polished and waxed the topsides, I nuked the massive wasp nest in the anchor locker and bent on the mainsail.
I've installed the 2nd new battery in the battery bank, and then for good measure, I swabbed out some suspicious looking skid marks in the fuel tank before filling it with 10 gallons of fresh diesel. Turns out the skid marks were nothing. I thought they might be snotties that could clog the fuel pickup, but they were nothing to be concerned about. The tank is really pretty clean.
Hopefully I'll have better news this weekend.
Ajax
If you had wasps up there, did you check the fuel tank vent, bilge pump discharge?
Ajax
I replaced all cockpit and bilge pump discharge hoses and yes, they had wasps. They're clear now. I'll check the tank vent.
Well, that's how it goes with a new boat ...you have to work the bugs out. :ph34r:
Ajax
holding tank vent too. And inside the mast and boom are likely wasp nest spots.
I'll ream the holding tank vent out with a stiff wire and see what happens.
I've been banging and moving around the boom and disturbing the mast and nothing came out so I think I'm ok there.
When I was replacing the cockpit drain hoses and the bilge pump discharge, I was down in the lazarette which is accessed through a cockpit locker. I'm down in the belly of the boat with no quick and easy escape, unscrewing hose clamps. The first hose was rotted so badly that it simply tore off, leaving a stub on the skin fitting. I heard an angry "BZZZZZZZZ!!!!" and wasps began crawling out of the hose. I hollered to my spousal unit outside the boat to blast water in through the skin fitting to drown the bastards while I was slapping them down with a section of hose.
The boat is on a concrete pad surrounded by a quagmire and a tall, grassy field. Paper wasps are simply migrating to the boat from the field and crawling into cozy, dark places to nest. We watched them do this. I expect to find more when I arrive on Friday.
Wait, wait, time out here. I call BS.
You are married and you are a two boat owner?
I thought that defied the laws of physics and could not happen in this universe?!
You better more fast and get second wife before Einstein find out.
Geeze, next you will be telling me the thing planes...
Ajax
Try to check vent line before launch!
From experience a Universal 5424 will run +/- 20 min at low RPM with a clogged fuel tank vent. Then the lift pump will be unable to draw fuel out of the tank and the engine will stall.
Quick fix is to open fill cap while you motor to the slip.
Simple solution, she owns one, you own one
The Pearson is up for sale. I've already received the obligatory offers from Nigerian scam artists trying to have the boat shipped and pay via fake Paypal accounts.
There's only going to be one keelboat.
I get to keep the Hobie. She has two kayaks of her own, so I ain't the only one suffering from Polynavicular Morbus.
Snore- thanks for the tip on the fuel vent.
Re: Infestations. It's weird, the paper wasps never showed much interest in Arcturus, even when it was on the hard for a year, next to a shed that they love. I mean 12" diameter nests all over it. They usually get in to everything around here. I figured they just don't like plastic.
At the old marina, mud-daubers would build a few small structures on board every year. Nothing where it's moored now.
Lately, we get a lot of visits from honey bees, taking a rest in mid-river. (What? You mean the Queen sent you all the way over to that bush on the other side of the river? What a b___!)
When I got my boat, there was a bird's nest in the boom which is, of course, hollow and open at the aft end. The mud wasps were new during my ownership. All my paper wasp friends are at my house.
The birds that nest under the YC porch sit on my lifelines and shit on the boat.
Birds and mud wasps are a problem in the great White North as well (p.e. it snowed last Monday @#$%^&). I put a balle dup black garbage bag into the end of the boom to keep the birds out.
Ah. What you have there is Polistes brentswainus. Might check to see if the nests have been welded.
Excellent. Good thing I had swallowed my wine before I read that.
Of the boat?
It's funny but people want pics of anything boat related myself included. You could have posted pics of the wasp nest!!
I found and find it really hard to photo something while I'm working on it. I just don't think that way.
Looking forward to seeing your boat in the water! Very exciting!
When I moved my old boat from outside Hamilton to Lake Simcoe (~150km? including an explosive tire failure on the 407, good thing the trailer was 2-axle) we discovered a surprised and unhappy mother racoon and her kits under the cockpit.
I called a local exterminator with coon experience, he said, "Leave the hatch open and I'll be she's gone by tomorrow!" ... I was lucky and he was right.
You could also move the hasp to be on the cockpit wall and the staple/latch portion to the hatch. That way when the hatch slams shut the hasp won't slam over the staple. The line around the winch is probably less work though and just about as effective.
That's the way C&C set it up. Still hurts when it slams down on you, but at least you don't get locked in.
You could also install a gas strut to hold the hatch open. Verrah nice
15002_output.jpg?t=1189699593
Gee that's a great idea. (Sarcastic font see post 89)
I've seen the struts on caravan boats before, why is it such a bad idea?
Well mine is 80 - requires a healthy reduction valve.
We have about 90 psi water pressure here. I live just down the street from the water plant. They don't have a tower. Giant pump, I guess.
In other water related news, yesterday I received notices that a new water main is to be installed down my driveway, then it will turn and run down my mother's property line next door and out through about 1,000 of swamp to the creek. That should be interesting. They'll basically be doing construction on pudding that is overgrown with vegetation. Airboats and specialized swamp machines can go there but nothing else can.
/h2o hijack
Oh...so lucky I didn't have THAT problem.
In other news, one of my neighbors has sailing experience and seems interested in buying my Pearson 30. That would be terribly convenient.
I stressed that I'd be happy to answer any questions that arise after the purchase and maybe even help with certain maintenance but not to depend on me as his personal mechanic. He seemed to get it.
The week is going by far too slowly. I'm ready, the boat's ready, the rain has finally stopped and it's a holiday weekend that's coming up. I'd really, really like to get it in the water now.
James, Alcatraz had posted the same idea in post 89 and I had missed it. Hence the sarcasm The struts were on the boat when we bought it and they work like a charm
Oh! Oh! I recently replaced the hood struts on the Beemer, and saved the one that wasn't flat "as a spare." New weekend project! (Also don't forget to add a LED dome light down in there.) Thanks, guys.
Good luck with the launch, Ajax. Assign someone to take some pics, and have fun!
Screw the dome light. Get some led strip lighting and glue 4-5 feet of LED strip lighting down there. You don't go into the laz often, but when you do, having it lit up like Times Square is handy.
Helps you find all the shit that rolls into the nooks and crannies.
Mr. Johnson,
I design pipelines for a living. I hate dealing with soup posing as soil. I hope your house foundation doesn't decide it wants to join in on the fun once the trench walls start collapsing.
Shu
That was cold!
Having done a fair amount of construction in SFLA, it is most likely sand so they can probably get by with a 4' ditch, and no shoring. At the worst they will probably drag a trench box.
Karma is a bitch. Don't get PJ riled :)
I'll swing by mid week and report on the gravel and any improved ground conditions.
Some gravel down and two more loads at the ready. Still pretty soft looking (was on a conference call so couldn't get out of the car and walk around any). Yard appears to be trying hard to not screw it up again.
Possible t-storms in the afternoon now. I'm going to call them and ask to be splashed around 10am, so they'll need to keep the heat on and spread that rock.
Not a replacement for a proper positive closure device (e.g. hasp or better), though.
Looks a lot better than a piece of lastic round the primary though, and you get the nice whoosh noise
LOL @ the "whoosh" noise.
My spies have informed me that the yard has finished filling in the travel lift path with gravel, so there should be no impediment to splashing tomorrow.
Once it's in the water though, it all comes down to whether or not I did my maintenance right. I need 3 things to happen tomorrow:
-Water stays on the right side of the hull.
-Jib goes up without a fuss (roller furling)
-Engine runs as well as it did during the demo.
Luff groove cleaned and lubed?
I don't have the little groove cleaning thingy that you attach to the halyard but I do have a plan.
What Sailman says...but use the oldest, rattiest jib first....then switch the the good one, and spray that one to...
Fingers crossed for you and the Teal Wonder!
No longer "discarded," this boat is owned with love and will be for a long, long time.
There was some more fuss at the yard when the travel lift sank again, even after genuine, solid efforts to fill the whole area in with gravel. We've had that much rain. The yard folks persevered, got the lift free and got me out, and into the water (frankly, I think they just wanted to see my stern disappear into the sun, never to return).
I had some water pump issues which I have sorted out just this morning and with some help. Finally got the 5-6 year old engine oil changed as well. The boat sails really sweetly. A small jib is a joy to tack.
Stuck again:
Free, and moving at last:
Wet after a very long dry spell:
Sailing... still lots of work to do, so ignore the vang disaster going on there. That's PO repair.
Safe at a "layover port" before I bring 'er home.
Ajax, I'm a uni student in the uk who's about to do what you did. Me and my bbuying partner are doing the same as you, tahnkyou foer the confidence to do it!
Glad for you. Looks like all is going well. Thanks for the pics.
I have and on occasion fly a 150 Genoa, but the 135 is a perfect size on the boat. T-33's are a joy to sail.
Thanks for the play by play. I had fun watching from the cyber bleachers. Sweet boat in the right hands.
Is a sideways slip like that less expensive than the normal kind? Isn't it a bit awkward adjusting the docklines?
Congratulations on a successful launch and a good first trip.
Now, all you have to do is to get rid of the old boat.
Ajax, glad to see your new boat is floating! Good luck!
Mr. Johnson,
The proposed route is hundreds of feet from my house. The part they will be trenching is sand.
The acquisition guy on the phone said that when they got to the swamp and creek, which is about a mile wide, they plan to drill a hole under the creek. He said it would be 30-40 feet under the surface. There's limestone down there.
Cool beans!
... Hmm. I've never seen a travellift operator dressed quite like that. I guess they don't have OSHA back east? Back where the people who make up these laws live...
Cool beans!
He's good! (gummint inspectors don't work on holiday weekends....)
So I'm going to have to be the one eh? No one else here going to mention it?
Swap the jib sheets over ffs.
Happy for you my friend, looks good and looks like it'll sail very nicely.
Lol, yeah yeah, I know! I was in a hurry. For some reason, my jibs don't have UV covers sewn on them so I'll fix it when I take the jib down.
Congrats Ajax...very solid!!!
Thank you for sharing this project online, really inspiring for the rest of us! I'm like you, I can't swing 5 figures for a boat so I try to bring abandond dreams back to life...
Think when I finally pull the trigger on the next "bring out another thousand" I'm gonna have to try this "help advise me on getting my project boat seaworthy" thread idea...
