eyeshotpar
Can we save Portsmouth handicap racing?
Set aside your concern about the politics and ownership
Set aside my concern that the underlying philosophical goals are slightly different and this may be meaningful to some.
you state
More sailors = more data = better model
Why do you think data collected from the fruitcake with the E scow on Loch Lomond is meaningful in any way?
Do you think E Scows have gotten measurably faster in the years since their hey day in what the 70s?? In the USA.... the answer would be NO... the class design peak performance was measured in its hey day against the yardstick boats (also sailed in their hey day).... It should not change. (if it has... its a result of Fortran running on 8 bit computers limited to 100 data points and some bad decisions by the PN committee)
In the UK....the system is based on fleet medians if I understand correctly.. But again... the fruitcake data is one off and the UK system would punt as well.
Take the post above..... the RS Areo was competing last weekend against the international 505 and the international Laser along with some other designs.. What would be the FAIR rating for the fleet and the RS areo sailor... A) . Take the UK system ratings of the three boats and linearly interpolate a USSA PN rating for the RS Areo and use it.... OR B) would you rather use the questionable data obtained from the small but growing fleet of RS Areo sailors in the USA (IF the US PN system would violate its principles and generate an RS areo rating?)
Your point "PY yardsticks allow eccentricity to blossom and how can that be anything other than good?" AND 505's point that PY yardstick got everyone competing last weekend are the Key Points and speak to the underlying principle of why you have a Handicap system in the first place
The small devil is in the details and since times have changed.... you just have to honor the underlying principles you and 505 brought up and be flexible.
A transparent process is critical to getting sailor buy in... however simply turning the crank on the PY machinery with garbage in will do nothing more then generate garbage out. I see the appeal of a unified table run by the brits... but think this issue is best left alone... (and then best driven by the Brits .... however after Brexit... they seem to be more insular these days)
Simple is best...
Simple is .... well simple..... perhaps you mean user friendly?
Best is a value.... do you mean Accurate? Fair? Precise? Good enough for a beer can race? How about all of these values applied at wind ranges form 3 to 25 knots. My car is simple to use... but under the hood... it is now half computer. Not simple in principle.. just simple to use.
Maybe... "simple is best" does not work when you try and rate a brand new UFO (foiler at breeze) against a laser in a club race or try and rate a Moth... vintage 1980 versus a Moth vintage 2017.
The thing about a value like "Best" .... it can change in an instant for any individual... Yesterday... they were happy with the ratings table in 7 knots of breeze...... tomorrow.... they don't value the table when they have to sail in 15 knots of breeze... "Yo... handicap racing is a POS and waste of my time" (a sentiment often heard at the bar after racing)
You are better off building a system based on your principles. I would prefer to build a rating system around the principle of Fair Competition from 3 to 25 knots. Simple would not enter into this principle.
YMMV but I think the nonlinearity inherent in racing lasers against 2016 moths means you need wind speed ratings. Now with a laptop .... you enter one more number after elapsed time, sail number/class ... So... now you measure and enter wind speed average. ( I loose the argument most of the time.... to the demand for Simple.... so take my point of view for what its worth)
If simple to do, and complicated under the hood is best, then what is needed is a well designed app! The results could be transmitted to the organization for updating the variables. Almost everyone can use an app nowadays.
RaceQs is a really neat app, and probably be adapted to do this with a little tweaking. You can use it to score a race already, and record it if everyone is running the app.
Computers can make the complicated simple to do if some genius can design the right app.(that genius ain't me btw)
US307
How does a well designed app help the Brits get a rating for the "fruitcake with the E scow on Loch Lomond "?
Why does making it easier for "garbage in" to be collected improve things?
If "fruitcake" has a great day for "fruitcake" and out sails his UK e scow rating.... aka a personal rating obtained with the killer app.... should he win the race?
When you see fleets of new designs competing in handicap races against fleets of older designs/yardstick boats... Fire up the killer app and turn the crank. Until you have this precondition..... the killer app is not the answer.
We won't publish a number unless it has a reasonable foundation, which would require more than one fruitcake at one club.
30 fruitcakes at 30 clubs is probably just as good as one fleet of 30 in the Brit system.
Most scoring programmes widely used in the UK do indeed upload data to the RYAs on line system. Hopefully clubs are just getting the last of their early winter series results uploaded this week to feed into next season's numbers.
The none-obvious problems with multi number systems are two fold.
The first is that if you divide your classes into say three wind ranges you immediately dramatically reduce the number of classes that you have reasonably valid data for, because each number is represented by about one third the number of results, so the number of classes that you can publish results for plummets, and disproportionately too since there is a very pareto-esque distribution of class popularity, and a very long tail.
The second is that wind speed is just one of a number of factors. Current arguably has an even bigger effect on performance differences between the longest and shortest boats, in the UK with a huge variety of different venues the actual type of racecourse too is vital, but as soon as you try and allow for all of those you are into a minefield of complexity and even bigger problems trying to get reasonably well founded numbers.
And, to be honest, there's quite a lot to be said for every dog having its day. Noone gets to win on a magic handicap, since crew speed differentials are so much greater than boat speed, but if your club has a dozen crews of roughly similar ability then its by no means a bad thing if they all get to share the race wins rather than having Jane and Bob win every week.
RaceQs might be a really neat app but it's incredibly difficult to get working. Particularly if you use a 'modern' browser such as Chrome 64bit that doesn't support the plug ins that are used.
I don't see myself as stupid but I've had several attempts, all fruitless. The first one had a 35ft yacht parked on the grass at the lake I was sailing my 14ft cat on! (yes I know how to fix that but only with an F18 cat).
We are talking dinghy's here too so everyone would need at least an Android 2 phone with a GPS to record races, a waterproof container and somewhere to put it.
None the less, it would generate easily transmitted data, that isn't fudged by anyone. There will always be some problems with a handicapping system, no matter how you do it. At least, if you had an app that compiled the data and averaged it(them?), it wouldn't require some dear soul to do all the work. It would also be updated at some interval(automatically if you desired).
We have about 20 boats that race from time to time. There really is only one OD fleet(J22), and only about 6 of them race each year. Of the rest, most times there is one or two of the same OD in a race.
Still, it is a lot of fun, and you don't have to drive 150 miles to and again back from a race. There may be 5 of the 20 boats that are newer than 10 years old. I have one of the newer ones, and maybe the oldest one (42 year old International Tempest).
As far as RaceQ's, if you look at the youtube videos, it helps. I run it on an iphone, no problem. Takes a bit of learning to set the race up, but it is all explained in the videos.
Take a look at the Texas Centerboard Class. The seem to have a lot of fun and do a series of races. (I really need to take my dinghy and join them!!)
US307
+1 Mambo
My point has been that the US is lacking an organization to promote and administer any dinghy handicap system. I hav'nt seen USS doing that.. Using the communication and data crunching tools that exist today and adding a little intregrity and common sense.we could create an environment that would increase numbers in small boat racing and improve the general sailing scene in the US. PROMOTE is a big part of the equation..
There are too many areas where open class dinghys are considered lepers so the folks just don't show up. In truth, an increase in open dinghy classes would increase OD racing too. The RYA model could be a good place to start.
We agree. you need 30 unique owners.... Not one owner... 30 times.. the Brit system is correct to not publish a rating for the E scow on the loch.
The issue is... what to do with fruitcake and his e scow on a loch in scotland?
My suggestion... interpolate the E scow rating from the US tables and give him a UK number and let him race in the club. Turn the data in yearly and Trust the wonks running the UK system to not issue a rating based on 30 results from one guy.
My two points here are that a killer app is not a panacea AND most importantly does not solve the problem of the requirement of widespread participation for these handicap systems to work and suck in new designs.
I suggest, that clubs honor the principles of handicap racing and provide an opportunity for fruitcakes with oddball boats to race.
When you get "a fleet" of a new design racing against "fleets" of yardstick boats.... THAT is the time to collect the data, fire up the killer app, get the returns in and crank the numbers.
I see more data needed as a limitation and not a problem. Over time, the data set will fill out. So, what am i missing that is a problem.
AS to current and course and windspeed effects being about equal and a nightmare to manage... Indeed ...... arguable!
There is no doubt that sailing a balanced course versus an unbalanced course is a challenge to a handicap system using time on time. Does the extra weather leg balance out the less time spent going down wind on time on time racing? Again, this is a data coding issue also impacts the amount of data. It seems to me, that the handicap system just has to declare where they find their final table to be "most accurate" and let the clubs decide how to run races to be fair to all competitors. The USA system stated that the table was based on balanced W L race courses lasting at least 30 minutes to an hour in length. Your point is also true that many races would fail to meet the standard and so the amount of data you collect must go up (otherwise, garbage in... garbage out).
IMO, What ever the RC decides... will indeed be arguable...and the best you can do is be transparent.
The impact of current on waterline would probably not come up in a discussion /bitch session on handicap racing in the US. You don't hear war stories about how the current swept all of the 18 footers down the course and let those pesky little 14s and 16 foot boats avoid the worst of it and get around the weather mark. So, without war stories/horror stories and measurable data.... current effects on ratings on this side of the pond is not a big issue. So, it may be an important issue... but its not viewed as a problem.
The impact of windspeed on handicap racing is a constant point of discussion.
What you do hear about is the effect of wind velocity relative to the power in the designs on the water. A single number system ignores the physics of the overpowered design flying a hull (getting on plane... etc) and leaving the other designs dead in the water (so to speak) How can this be fair etc etc. It has nothing to do with sailing skill in winning a race! SO the question becomes, would not a handicap table that took this power factor into account be more fair in removing the boat class from the equation of who won the race? Perception that a single number system is inherently unfair before you even rig the boat for the day of racing is, IMO, a problem. Again, this is arguable... and the argument reaches a head when I hear; the club A class sailors are not racing if its "howing" 20 knots while the club F18s are saying... HEY, this is just getting sporty.... You can't have the racing shortened just because its windy now....
So, we agree... the issue is arguable and the amount of valid data is a limiting factor.
The USA notion is that the handicap table is attempting to eliminate the boat design as a factor and thereby recreate a "one design level of racing" the multihull users adopted the wind tables for buoys racing before the system cratered (AND it was always a red headed stepchild to one design competition)
We don't use data over 3 years old: classes change all the time, and its really not sensible to do so. So we have a pretty good idea how big our data set is. There are too many classes that are a bit marginal on data anyway.
If you look at the published data we list the number of data points we have for each class, and while we have 21,000 race results over the last 3 years for Lasers, we have only 247 for a class as significant as the 49er: that's how much it drops off at the bottom of the curve...
http://www.rya.org.uk/SiteCollectionDocuments/technical/Web%20Documents/PY%20Documentation/PN%20List%202016%20(Web%20Version).pdf
Current is a huge factor: one of our major tidal clubs recalculates all their numbers with an empirical formula to allow for current. Bucking a 3 knot tide in a boat that does 5 knots is a lot different to a 3 knot tide in a boat that does 10 knots, and they have a lot of 3 knot tides.
Empirical handicapping is the art of the possible really. While we might idly dream about the wonderful things we might be able to do in the future with mode detailed data and all the rest of it, practically speaking in the UK at the moment the single number system does seem to be the least worst compromise. At the moment the main thing we are looking it is ways for clubs at similar venues to be able to combine results so as to get water specific values for their most popular classes. On the whole that seems to be a more popular focus than wind related handicaps.
+1 Mambo
Promote what exactly?
Yacht clubs should offer open handicap class dinghy starts? I am sure the clubs would if you could promise them a critical mass of boats. Perhaps they have filled up their race circles for the regatta but there are plenty of clubs who would love more participation. This is not the "Field of Dreams"... build it and they will come meme..... (AND Remember.... the they.... were ghosts!)
Until the one design classes in your region decide that participating in a three boat one design race is not more fun then racing in a six boat handicap race.... you won't have any opportunities to add in 3 open class dinghies. The three open class dinghies will have to function as a class and show up at handicap races. with the three boats that they have. (That means that they have to ORGANIZE like a one design class and get the buy in and commitment from the sailors for a season schedule)
Now... you could promote handicap racing to one design dinghy classes.. However, I am not sure how the National Sailing authority would have a role to play here... It will look like a zero sum game to most and the small OD classes would see themselves as loosing if the national sailing authority recomended such a course of action. Promotion must be at the local sailor level. One design class MEMBERS have to decide that handicap racing is a way to strenghten their class and not the kiss of death.
The peice to figure out is.... In the UK.... how fixed are dinghy sailors on mostly competing in one design.... Would they prefer a three boat OD start/race over a 6 boat handicap race at their club?
Would they pack their boat up and travel to another club for a handicap race? Is there a bit more lattitude in organizing dinghy racing in the UK.
Severn Sailing Association is the strongest dinghy club in the mid atlantic region and they don't do handicap racing at the club.... their OD sailors just don't wanna. They will race small classes till the bitter end.. They certainly are not packing their boat up and traveling to a club one river down the bay and racing handicap there. They would also decline to offer a start to a handicap class because they value the leverage they have... (if you want to race dinghies in Annapolis... then you sell your boat and get one of the ones we use at the club)
So, my question to you would be... Promote what.... and to whom..... clubs?, classes?, OD Sailors?. Open class dinghy sailors? Then of course... Who exactly should be doing the promotion.... US sailing.. Builders, RSA's, Clubs, OD Classes, Handicap class officials, individual sailors.?
In my view, these essentially people issues are much more difficult then the machinery of getting a handicap table that is accurate and fair.
+1 Mambo
Yacht clubs should offer open handicap class dinghy starts? I am sure the clubs would if you could promise them a critical mass of boats. Chicken and egg. But if U don't offer it I'm pretty sure they won't come Perhaps they have filled up their race circles for the regatta Whose dreaming now but there are plenty of clubs who would love more participation. This is not the "Field of Dreams"... build it and they will come meme..... (AND Remember.... the they.... were ghosts!)
So, my question to you would be... Promote what.... and to whom..... clubs?, classes?, OD Sailors?. Open class dinghy sailors? Then of course... Who exactly should be doing the promotion.... US sailing..How about a new organization that will get the job done Builders Could help, RSA's, Clubs,Could help OD Classes, Could help Handicap class officials,An Oxymoron individual sailors.Could help? Why so many posts and threads re: no OD racing in my area, sailing diminishing etc etc. Not too many posts re our last regatta had too many entrants.
Before writing I reviewed USS site looking for anything re openclass dinghy racing. .....I rest my case. I'm old enough to remember the red Lobster cup and other open class regattas that were truly memorable. I've participated in several Mug races with over open class 250 entries. Doing 22 minute W/L races in lasers is not everyones cup of tea. I dearly love my present club but with lasers, sunfish and the only double hander being a 420 we are waining. Not every single hander wants to sail a laser or every couple wants a 420 or lighting. They want to sail their boat. Why don't we fucking get it!
Indeed a chicken and egg problem.
However, I can tell you that in working with Yacht clubs that have NO members sailing handicap dinghies OR for that matter OD classes and you want a start in their event.... You Need organization! They want to know things....and they need somebody accountable that they can get on the phone and by digital means.
When things go sideways.... the club needs somebody to work it out with....... For instance... when the lightning fleet declared... they were not coming back to the club if the open fleet got a start... A conversation had to happen.
ghosts don't answer the phone...
Whether its Open class... or OD class.... the operative word is CLASS.... meaning class leaders, organization, rule sets etc.
Remember... this is not key west... Everybody on the local level is volunteering... nobody is entitled to squat. If the three boats are happy racing one design and don't wanna play in handicap.... OK... it is what they value... But the conversation was had.
One design classses are loosing members every year... Open class fleets have even fewer ties that bind the group. It is a lot of effort.
stuart walkers advice to me (and anyone who would read his book) about building and maintaining OD fleets.... When you loose the last member in your pecking order of the fleet.... you have a new last member.... Pretty soon.... you have nobody.... So... the most important person in the fleet is the last member in the pecking order. With respect to an open class.... well... you have to get enough critical mass... to even have a pecking order..
I think our club has been remiss, and not sending in race results. I will try and get that going again this year, see what happens.
you state
I think my post was misunderstood by some.
I advocate a simple unified PY Yardstick rating. I advocate choosing one calculation (the underlying algorithm is almost identical) and pooling all the data.
More Sailors = More Data = Better Models.
I gave two sets of examples .
1. The US RS Aero Fleet would be better off because their data would include the much larger UK RS Aero fleet. The UK Viper fleet would be better off because their data would include the much larger US Viper fleet. Both sides of the Atlantic would be better off because More data = a better model for both classes.
2. The individual eccentric boat owners on both sides of the Atlantic would be better off. If there is a Merlin Rocket (sigh gorgeous boat) in the US it would be impossible to get a US PY rating because there are no Merlins on our side of the pond BUT if there was a pooled PY system, he (or she) could get a meaningful valid rating because it would be based on the 100s of Merlins in the UK.
If there was an E Scow owner in the UK, it would be impossible to get a PY rating because there is no E scow data in the UK database but there are 100s of E scows in the US and a unified single rating for the Escow would be accurate and allow said Escow on loch lomond to race against the local Squibs and RS 400s in a meaningful way.
In the US, the answer would be a resounding YES.
Because they adopted a massive assym spinnaker about 5-7 years ago.
But Im not sure what that has to do with the benefits of pooling the two systems into one system.
Quote
This is the exact problem in managing two systems.... The coding issue is one of the major problems.
One of the last events I scored had a local fleet of Chesapeake 20s competing in a distance race. A Chesapeake 20 is a local design, two person dinghy with a Star Rig. Native to the Western shore of the bay.
The USPN table listed a Chesapeake Dinghy. That is the rating used for the past 15 or so years... and coincidentally the 20's usually won the distance race until A cats started competing.
Having been on the PN Committee... I don't remember seeing PN Data for anything called Chesapeake.... So, a conversation with an old timer from the EASTERN shore.... yielded... OH.. Yeah.... we had a Chesapeake dinghy when I was a kid... it was a precurser to the laser... you know... single handed dinghy..
Ooops.. The coding problems are an issue between the left shore and the right shore of the same bay.... So, I can't imagine the issues between either side of the pond.
It's a wonderful idea... but the devil is in the details.
14 boats out Sunday. 505's, Flying Scotts, RS Aero,Jet14, Lasers and Wayfarers.
We have rotating RC and everyone records times and wind readings then sends them to our scorer. Nothing's perfect but we get boats on the water, everyone competes intensely and it works.
Way to go!
The HPDO at American Yacht Club has always had a PY Division to pick up the high performance dinghies that wanted to be at the event but could not get a full fleet together.
https://www.facebook.com/HeinekenHPDO?ref=hl
Simple is best...
William of Occham...had right idea. As most history has shown, simple is best (any value you want) in the beginning and always best later! Truth is simple, as an example, uncomplicated...means to an end...not other way round.
Has anyone tried different ratings for different wind bands?
We have a few classes that go from bulldog to greyhound as the wind increases.
Sure, all the time in the ninetys and before. More work for the R/C but helped level the playing field. Ratings for different wind speeds are published in the USS portsmouth handbook.
Thanks 5 0. I was look for results for regattas with aeros and Lasers. The Jan 22 results had it.
I salute the Thistle sailor who despite being 10 portsmouth points faster could win an 11 minute race. Very hard to do.
So, I will answer this straight up. The start is everything, assuming even start, a boat with a 93 index finishes a race in 11 minutes, Thistle finishes in 9.5 minutes, Thistle wins!
I'm currently in a club for which mixed fleet racing is the only option.  One problem we face is arguments over the assigned US Sailing D-PNs.
We have a very wide range of boats - J-22s to Sunfish. The fleet covers several discussible numbers  such as:  American 14-6s (96.3), Holder 14s (93.2), O'Day Mariner 19 (104), Hunter 212 (93.2), and new model Hunter 22 for which we've been using the H216 number (90.8). (The H22 is listed by US Sailing at 96.5, compared to the 212 at 93.2!)
I've been following Portsmouth handicapping for a long time., and I'm aware of the problems of really "fair"  comparisons over a range of boat types, design objectives, wind conditions, etc. However, I'm wondering how other clubs have dealt with the issue.
Work it out, start is 90% of it, unless drag race...something has to work and Portsmouth seems closer to reality than most; Rest is flotsam, IMHO. Work it out.
In the US, the answer would be  the boata resounding YES.
Great idea, in this modern era of zippy-zap communications & data, why is it not already happening?
Also, there -is- at least one Merlin Rocket in the US. I've seen it twice
We had 19 boats competing in 4 Portsmouth races Sunday.
1 505, 1 Contender, 1 Musto Skiff, 1 Laser 2, 1 Windmill, 3 Thistles, 2 Flying Scotts and 9 Lasers. Lots of fun and the usual Chili social afterwards.
Next race day Sunday the 3rd. Competitors meeting at noon and first gun at 1.  We use 3 minute signal starts in our winter series.  If you're in Central NC you should come out and join us.sis_csc_winter_2017-18.pdf
the best part was that it was a coaching race. for people at the back of the fleet it was great to get help from the racers around me regarding what I was doing wrong (which is many, many things).
Another successful turnout for the Portsmouth fleet Sunday. 13 boats, 4 races. I'm sure we would have had more if the wind hadn't been forecast 2-4!
2 Sunfish, 5 Lasers, 3 Flying Scots, 2 Thistles and a 420.  The 505 Boys were doing RC.
On 1/18/2017 at 11:51 AM, Tcatman said:
Handicap racing tables are about a PROCESS... the table is just the latest result. The table has credibility and buy in by the sailors when they support the process.
So, the first thing is to decide what is the underlying philosophy behind your process.
Jim C writes for the UK.
So then.... you need club racing... and you need active fleets to make this system work.... ASSUMING you can get race data.
Jim makes a strong case for why the UK system makes lots of statistical sense and of course... it is supported by the sailors.. So... they have a valid process and strong buy in from the sailors.
The problem in the US... for all of the classes not being included or updated.... are not active fleets racing in clubs .... They are one off racers.... Any data they produce is more of a personal handicap for the helm then a class rating for the design. Using the UK system in the US would have a flawed process underyling it and No buy in from the sailors.
The US portsmouth system is very different in philosophy. I wrote.
In the US system... the top finishing boat in class is recorded... and the statistics are based on those results compared to yardsticks.
Its an interesting issue comparing the UK and USA philosophies... but for the future of US handicap racing...
The underlying assumptions for this system to work properly are not in place in 2017. They are similar to .. the UK criteria.. of active fleets racing in clubs and again.... for the boats not in the tables.... the US does not have valid data coming from viable fleets racing against yardstick FLEETS and the system as designed can't work properly.
What's worse, because of the philosophy/design of the US system.... a single pro sailor could race the boat against yardstick boats and generate the underlying data for the class Or they could sandbag and generate data. The US system could codify an individual handicap rating as a class rating.. So.... what to do.... the under lying process is fatally flawed and If you continue to use it... you will loose the buy in from the larger population of sailors who have used it for years.
So.... I understand a club saying... we have all of this data... I understand a racer with an atypical ride wanting a solution. Unfortunately the USA PROCESS is not in place and valid.
The USA solution is for the sailing clubs with participation from the one off or new designs is to form a committe, guestimate, WAG, PHRF... go to the sage on high.... whatever, in a transparent system that works for your club members and publish a modified table with this rating used in the table. Demark the new rating somehow and brand it with the club name... (Carolina sailing club WETA rating) When two or three clubs do this... You will have 3 ratings and then a conference call at the beginning of the season and perhaps you find a consensus rating for the new design.. Sailor participation will tell you when you get it about right..
So... colored printers/spreadsheets that highlight the PHRF class rating. A handicap committee in clubs with members sailing the one off designs and a conference call/ forum discussion at the beginning of the North American season... and you have a NEW Process that will probably get buy in from sailors. You won't corrupt the 20th century Portsmouth ratings, you will have integrity of the process, transparency and more then likely support from the sailors on the water for the actual racing.
This makes a lot of sense.
And for the OD only crowd I'll reply as someone living in an area where OD is the only thing you can do and I've been doing it for over 25 years.  There are those of us that have their OD boats but look at a new boat like a Melges 14, VX/Evo, Musto Skiff, or even a single handed 29'er, and want to go have some fast fun.  Most US OD boats are extremely old with many problems that surround facing something from your grandfather's day.  Then I have watched someone move into the area and have some old boat that was popular where they last raced for 40 years and consider one of the local OD because otherwise they cannot race.  Then I never see them again.
The answer is a big yesbut the answer is a lot easier than actually doing it. Mostly good observations and comments so far. It is obvious that the existing organization supposedly administrating the US Portsmouth handicapping system is not working nor has any intention. A new organization or group  must be developed  to do it. With todays technology it could be far better than just fixing or continuing the existing system. There isn't any situation mentioned in this thread that couldn't be resolved by a knowledgeable group. There will always be situations where a handicapping system will not meet the standards of strict OD racing but in the meantime a lot of sailors could be having  fun racing their boats on weekends. Many already are, using whats available but it could be a hell of a lot better.
"Lead ,follow or get out of the way"  It's time. Any takers?
John D
I'm handy with a spreadsheet and could move to a database, I would be interested.  My time in the local YRA would be useful to reaching out to regional clubs and see if there is interest in submitting data.  But first comes the hard work of determining how to create and track ratings that will be reasonable and not generate resentment.  Also a simple method to report races by boats, something online and either performed manually or uploaded via a .csv.  I think that approaching the USSA and the RYA would be a good first step, no reason to re-invent their processes.  It might even be a good idea to consider dumping USSA D-PN and moving to RYA PN and if USSA is willing, take old USSA data and re-rate old classes into the RYA PN.  The world doesn't need more ratings systems and dinghy ratings are not likely to go VPP based.  As part of that process I would warn competitors that ratings will always be conservative when first applied so as to not upset apple carts and encourage new boats to continue to submit data.  And all new ratings would be required to be reviewed yearly for a minimum of 10 years.  Make this and more part of the mission statement.  I would also keep an open mind to the idea that the USSA would like to have volunteers pull this together and work inside of the USSA.
And the obligatory warning.  If you have no idea how hard it is to work for a YRA or handicap committee I would recommend seeking counsel before considering this effort.  Lead underwear, crocodile skin thickness, and a constant willingness to listen is required.  Your hard work will occasionally be rewarded with a thorough ripping apart by know-nothings at clubs, bars, and places like SA.  And you'll have to read and listen patiently as well as remain professional throughout less your work be undermined by petty arguments.
Great, there's one :rolleyes:. Any more? Keep in mind that this would NOT = OD competition but could expand the fun of sailboat racing.
We send all of our scores into the black hole of US Sailing.  There is no committee to keep things updated and the sad thing is they don't care.  Lets face it the money is in big boats and like most things in this country US sailing has gotten to the point where that's all that counts.
We use the published portsmouth numbers when available and sign them when they are not often using the RYC numbers as a benchmark.
Regardless no handicap system is perfect but it has had the intended affect of getting more boats on the water, increasing competition and sailing skill.  During our winter series we wave Rule 41 so that experienced or skilled sailors can help out those less so. We'r even discussing waving it for our Championship series.  I have talked to many sailors in the area trying to get them to come out and race with us.  A big deterrent to their participation is intimidation.  Many are self taught, don't know the rules etc.  We have been able to convince several new sailors to join us by waving the rule.
I tried for several years to get a local Laser sailor to join without luck.  I would see him on the lake whenever the whitecaps showed up but he had never raced. He finally joined a few years ago where he was at the back of the fleet.  He's now at the front and one of our biggest recruiters.
At the club level I think whatever it takes to get more boats on the water and increase everyones skill is what needs to be done.  The majority of our sailors travel to OD regatta's and our club hosts some as well.
  • Like 5
2 hours ago, dburchfiel said:
Another 14 boats on the water yesterday. Thistles, Flying Scots, Lasers, Sunfish a 420 and a 505.
A couple of Wayfarers too!
Wot ?!!?!?! No Buccaneers?
18 hours ago, Lifesave said:
Just wondering dburchfiel. Do you travel to other clubs to race PN or do you just race there?
I travel all over the country to sail in 505 regattas but sail Portsmouth with our club.
Surprising huh!  Our club's largest one design fleet and we seldom get them out in the winter even though we can keep our boats mast up for FREE for our winter series.
If you're ever in town you should come out and sail with us.  We miss you since you set off to New Bern.
So the answer is a NO I don't sail PN anywhere but my club. Same trouble we are having here in TX. People want you to come travel to their club but won't come to ours. Just wondered.
I don't even know what other clubs have Portsmouth racing.  I've wanted to attend the HPDO for years but it's always been at our busiest time of year at work and haven't been able to.
I read in Sailing World that US Sailing was going to at least post the tables outside the login. But I don't thing that happened. I would like to mail in some results from our club, but don't have a clue how.  At our club we sail almost exclusively Portsmouth Yardstick. Participation is down. Our biggest Regatta in the fall  is the oldest continuous running PY regatta in the US, I think 2018 will be the 57th.
The handbook with tables downloads as a pdf now.
http://www.ussailing.org/racing/offshore-big-boats/portsmouth-yardstick-handbook/
It does not include the inactive  classes table, not sure if that is available
Interesting thread.  My opinion is that Portsmouth racing doesn't need saving in the US, people just need to do it.  Get away from the chest pounding one design mantra and get people out on the water.  My home club, Fort Walton YC (www.fwyc.org) has a Summer Portsmouth Series and a Winter Portsmouth Series.  The winter series is called the Frosty Nipple.  Anything 21 feet and under is allowed to enter for $5.00 entry.  Four races a day, with typical race times from 14-25 minutes, W/L twice around, and at times a triangle.  The club gets Viper 640's, Nacra 17's, Laser, Sunfish, Vanguard 15's, 420's, Force Fives, etc out there.
FYI,   US Sailing has reorganized...  The Portsmouth Yardstick will now join all handicap systems under the Offshore committee.     Nate Titcomb is the US Sailing official in charge.   He announced at a recent USSA meeting  that effort would be put into US Portsmouth.
Now, what that means in 2018 is a mystery to me.   USA Dixie Portsmouth is about Fleets of sailors in a CLASS racing FLEETS of Sailors in a second class around a standard course compared to fleets of sailors on a yardstick class.   I can''t find these events.  (Which is why you can't update the tables)
What people WANT is a complete rating table....   that has the following attributes..... It's accurate....and sailors acknowledge that its fair to all....   It  is transparent...  you know what events and fleets and data go into the calculations,  It has authority....   ie backed by the integrity of your national body and not some body with an ax to grind... and finally robust.   Your new class  ( or one off design) gets a fair rating that you can use to compete with fairly and  right away.
I don't see how you can do this in 2018 with a Portsmouth engine.  Consider,   The RYA Portsmouth only collects data for 8 catamaran classes that are still active in the UK....  The rest of the universe of catamarans in the UK  get a rating from SCHRS...   So, its a hybrid system needed to make things work over there..    Given the differences between US and UK portsmouth...  I bet the US is best off going full national PHRF for a small boat handicap table.
That just leaves you with a rebranding problem....umm... Its LIKE portsmouth... works just like Portsmouth... your number didn't change in the new system... but..... its. US Sailing Dinghy PHRF..  The USA has lots of experience doing PHRF
[snip]
Good luck with getting a complete rating table that is completely accurate (even if you know what accurate is) and that sailors acknowledge is fair to all. That's kinda like social justice and equality. You just have to do the best you can.
The RYA Portsmouth system stores data for all the catamaran classes that are reported to it, not to mention many dozens of other classes and configurations that don't get a published number. Don't confuse what is published with what is recorded. Numbers are only published if there's enough reasonable quality data to be happy that the numbers are sufficiently representative of the active fleets out in the clubs for the numbers to be useful to the clubs. If SCHRS is used and the results not entered into the RYA database then there's a bit of a downward spiral there.
Worth noting that RYA PY is simply a representation of the observed performance of the active fleets out in the clubs. This is achievable. People get very hung up on thinking (and older PY documentation is guilty of this too) that there is such a thing as a perfect performance, and handicaps should reflect the relative speed of boats if sailed perfectly. Apart from anything else, this is a statistical nonsense. You cannot really find outliers with statistics. But what you can do is look at what is really happening. The other dodgy area is when people start talking about skill levels and variations between fleets. It might become possible to evaluate that in the future with enough data, I don't know, but its pretty much impossible now. But the main thing is its better to do as good a job as you can with the possible, and produce something that works bearably, rather than aim at the stars when you can't get there. Better to drive around in a truck and actually travel than end up as a crater where the launch pad used to be.
I should have been more careful about the UK process..   The point is... that the UK is using data from the last 3 years.. the USA is using data from the beginning of time.   The UK process has integrity.   If fleets are not actually racing... then you don't publish a fleet rating....  The data are collected and time stamped... but...  If you don't meet the standards... they use a SCHRS based solution..  They don't undermine the integrity of the RYA Portsmouth process.  The UK catamaran sailors get a functional catamaran table that has complete integrity as a hybrid solution for the real world.  The USA process is a complete failure.
For a 2018 USA Portsmouth committee to operate the USA machinery with integrity  they will need data which to my knowledge simply don't exist.
So, what should the USA Portsmouth Committee do?  The sailors and clubs want a complete table that is "accurate" aka fair,  Moreover, the table is transparently generated, has authority of the national sailing authority behind it and is robust enough to deal with new designs rapidly and fairly.
I think they should rebrand the ratings table and use PHRF principles to update the table  (eg Moth ratings) and complete eg Weta ratings.
What are other alternatives for US Sailing to manage  small boat racing in the USA?
Quote
This is the US system.   Race Returns only want the first place boat in class....  I agree with you about the statistics... but I can't make that explanation clear to anyone!  (When did the RYA rethink the underlying statistics?   At least we know when mast a beam became out dated)
Quote
The UK considerations about relative fleets are VERY Different then the US considerations about relative fleets because the underyling statistics differ between the two tables.   The critiques often sound alike but are really critiques about apples being compared to critiques about oranges.    Almost meaningless to compare or debate this issue.  But boy oh boy are they similar sounding in the bar.
To my knowledge the RYA system has only ever had evolutionary change. I don't ever recall hearing of anything like the first boat in class only analysis that I've heard said is used in the US. I must say that sounds very eccentric to me.
If anyone at US PY is reading this, your opposite number at the RYA would be Bas Edmonds. I'm sure you could have a very productive dialogue with him.
If I were in charge of rejuvenating US PY? I'd talk to the RYA about their PY online system. As well as producing national level data it also gives clubs some analysis of their own data. Uploading data is usually done directly from results programs without analysis at the club side, so may not be too onerous depending on how well the classes etc are recorded. It is improving steadily. The clubs would be getting some value immediately from the analysis side.
If clubs can be persuaded to upload their race data then there will start to be some fresh data that can be used alongside the legacy system, so numbers reflect what is coming from both sources.  This would probably be a manual process, but not that much worse that what happens now. After a few years there would hopefully be enough data flowing through the on line system that it would dominate the data, and the old system would gradually tail off. The RYA is thinking about pulling the plug on old style returns now - they are down to single figures I think.
The big question is whether there is enough handicap racing in the US for a statistically based system to work. If not its a bit trickier. We're of the opinion over here that a measurement based system is not possible at the current state of the art. The catamarans are a bit easier.
Quote
I agree that a measurement based dinghy system would not work.  The Cats have seen great results with SCHRS/Texel.
Your proposal of evolutionary change using on line returns could deliver a PN table in several years assuming a decent level of handicap racing.   Of course,   racers want a fair and final result 1 hour after they put the boat away... not 3 years down the road.
So... what to do...   Do you Fix the issues in the US Table and call it portsmouth and flim flam the underlying statistics.... OR do you rebrand and implement the returns system that a PHRF like Small boat committee would need as well.
In either case... clubs are going to have to organize and send in returns....  I think that is the hurdle... not the technology.... email is 25 years old....   Not a great solution  but it worked for Darline.  Nevertheless....  a returns app would move the ball.    PHRF small boat committee or a Portmsouth Calculation would be better served.
We had six boats out today (5 lasers and 1 thistle) for a rainy, variable 10-15 with gusts up to around 20. Got a few races in, although some boats went in early.
I love the diversity of boats in this clip.  Personally I would much prefer to race in this kind of low key, fun looking, event where you can admire the boats than do a Laser regatta.  What's the tri at the end by the way?
I heard that there was supposed to be something happening with USSA.  Then there was the article on page 006 of the December issue of Sailing World.  I wrote to Dave Reed but there was no reply, I'm guessing he and others are running into the same old problem, USSA is not interested unless the dinghy is an Opti or a Club 420.  I'll talk to the new board at CBYRA and see if there is interest and if so, work to adopt RYA PN, recalculate D-PN into RYA PN, and then start begging for results to be entered.  Or maybe I'll just do it, at least then I can enjoy the work.  The hard part will be getting it online and begging clubs to enter numbers.  I'm not an interface IT person, I only do security, infrastructure, and back-ends, my stuff will look like stick figures trying to draw stick figures.
Oh for pete's sake... read the thread...  This is not a simple problem of US Sailing did it to us!!!
Quote
Yes,   its been moved to the off shore committee ...  Nate Titcomb announced at the USSA meeting that they would be working on updating the system for collecting returns.   Don't call an editor of a magazine...  Call Nate if you want to volunteer.
Quote
Well that's pretty ignorant...   Those would be JUNIOR Boats.... And THEY DON'T Race handicap.      The adult dinghy world mostly sails ONE DESIGN....   (surprise surprise)  ...  One design classes don't give a FIG about handicap racing...   Their theory is...  sell your dead boat... buy our boat and come racing.   It doesn't  matter if the class is local, regional or national..... one design classes don't do Handicap and don't care about their rating....  end of story....   So...    Find a group of adults who care about handicap dinghy racing in any club in america...  I defy you to come up with more then a handful of clubs.   Most of them prioritize their one design fleets.    You should know the local scene... Severn Sailing  in Annapolis does not do ANY Handicap racing by policy choice..   Likewise West River Sailing....   They are ONE DESIGN Dinghy clubs.  You can't join (in general) unless you bring one of the approved classes.  They don't do handicap!
You can't blame US Sailing for not responding to NO activity in the rank and file...  much less at the national scene.
Quote
Why?         Read the thread....   The UK sailing scene has a FLEET of boats in a class actually racing a FLEET   (more then one boat) in another class on handicap time..     Show me ONE REGATTA in the states where this is the order of business.   This is not the US small boat racing culture....   Bottom line..   the UK system is useless to the states...  If you don't have fleets... they collect the data but don't  issue ratings.. They maintain the integrity of their system...     Begging for data is useless... You need to change the culture of small boat racing in the states from one design with 3 boat  minimums to handicap racing of two fleets of three boats each!   Once you have that reality... then you can debate RYA versus USA portsmouth engines.
Quote
Hmm...    5 races in the regatta..    5 classes represented in the 10 boats in the PN regatta..   you report 5 lines of data in each  race... so 25 lines of data  total (first in class).    data to report are elapsed time. windspeed start middle and end of race  and boat class of course.   So really that is  report   Race 1,   Windmill   23 minutes 20 secs   Laser 30.50 and so on.
I don't think data reporting are the big issue.     Back in the day... email of any digital race result was collected by Darline (EVEN PAPER was collected).   Who knows... I bet half the clubs insist on using java score for handicap racing...   getting something more then a digital copy of the race results will be a huge undertaking.  Sure Sailwave can score the regatta and make reporting returns automatic in the UK ... BUT you have to get the clubs to upgrade their skills.  Not to mention the online scoring options by regatta networks or yacht scoring.
YMMV but try to focus on the real problems.... it is NOT the lack of support by US Sailing.
Second point... I don't think you want to order the PN committee to use flawed data to recalculate the tables just because that is the only data available.
Last point..   US Sailing  supports  a number of handicap rules    They FOLLOW the wishes of the  sailors/users and provide support..   eg boat measurement data to rating organizations,  .... They don't see their job as LEADING.... it is a support role to OAs, ratings groups and sailors  around the country..  Not a leadership role.
They are NOT going to tell clubs to use RYA portsmouth anymore then they would tell a club to use USA Portsmouth..  They are NOT going to tell a club to use a NEW national PHRF small boat table either.
This is a bottom up problem..    So... What will clubs do?
Use USPN as is"
Demand a bogus fix to the table using "limited data"
Create their locall PHRF small boat table based on the existing PN tables and rebrand the thing.
I suggest  small boat clubs generate a  PHRF small boat table. ....  Down the road, get together a few clubs and normalize the tables around  a regional PHRF rating table .   So, on the Chesapeake bay.... you create a table that includes Chesapeake 20's.   No actual PN rating exist for this class.... even tho its what 40 plus years old on the bay!   Down the road... if the demand is there... you can create a national PHRF table.
Its a bottom up solution driven by dinghy sailors who view Handicap racing  with the same sense of competition as they would a one design class and support  the handicap fleet in the same way they would a one design fleet.
Read the thread, multiple times.  USSA is handicap sailing, or is supposed to be, and does not offer any support to small boat sailor.  Clubs in larger areas in the US are the same, they want to, if you sit and talk to boards they express desire but admit they cannot or will not.  Putting up the flag via the YRA to USSA also generates no response and this is from the in house staff that attend the yearly meetings.  It is not on the agenda and has no support.  OD is different but if zero resources are being put into a big part of sailing and USSA holds most of the cards, then they are responsible for being part of the problem.  D-PN is theirs and it is losing its value due to stale data.
D-PN is out of date and has very little data on boats designed in the last 20 years unless the boat was considered for the Olympics.  Give it any name you want but that's not support.
And getting something into a format that can be easily put on line and then used by others is important.  No one in this age is interested in a .csv to web text page, you might like it, I might find it functional, but most will find it useless if they cannot re-sort and view the data in different ways without downloading it and manipulating it on their own; they will never look again.  Ease of use is important.
Bottom up?  With what money?  What volunteers? What structure?  I've been involved with clubs and a YRA long enough to know that without big tent support little projects die the moment the one person driving it gets bored, loses focus, becomes old, or dies.  Without a larger structure it's a short term effort that will putter out like every other one before it.
But don't let me dissuade you, do push at the bottom and when you get somewhere, please consider this thread and find a different way to put a foundation under your work.  Otherwise it will stop when you do.
Quote
Ummm  Earth to Foredeck.....   You must PAY a YEARLY FEE to your Local PHRF performance rating PRIVATE organization!   US Sailing doesn't do PHRF ratings...   and this is the CHEAPEST handicap rating you can get for big boats.    You paid for your PHRF service...    Demanding more/new  service for new additions for what is FREE and entirely depends on valid data coming in the doorway  seems unreasonable to me..
Quote
Look...  the hard part is on the back end....  sorting through the returns ...  and getting the data into a usable form takes the hours of work....   crying a river that its "hard" to stick a stamp on your score sheet.... or email the scoresheet seems unreasonable to me.
Quote
TRUE this... So, it comes down to how much do sailors VALUE a small boat rating table that has the national authority behind it.     Would you pay for it?..   eg...   have to show your Portsmouth class membership to register for a regatta?
Would your club pay a fee to use such a table for handicap racing?    Saying there is no free lunch and then saying...  Include this service for us just because  Well it is US Sailing....they should do it for us....    seems unreasonable.   Yes, a lead volunteer and lots of club volunteers. made it happen in the past..   So... what is the story today.
I don't know this for a fact...  but.
Consider....  I don't think they have any  VALID data that meets the Portsmouth guidelines for publishing new ratings.   So, Demanding that they (a volunteer OR a staff member) blow up the integrity of what rating table exists seems unreasonable to me.
What IS REASONABLE is to PHRF the ratings for the boats in your club region.... publish it... and go from there..   Don't call it Portsmouth and life is good!
This thread is interesting but mud on a wall is better than a 84 page thread like the Laser or Sunfish moan-fest.  I've sat down with the local YRA prez and discussed this and will see if we can get this idea moving for our area.  One of the local clubs I'm at is interested as well.  Hopefully a few of you do the same and have something to post here in 1-2 year's time.
Just don't give up.  I'm a US Sailing paying member, YRA paying and volunteering member, and multi-club volunteer and paying member.  What that has taught me is that everywhere you go there will be people trying to stop you, sometimes even when they have no interest in the matter at hand.  And while I've not found US Sailing to be helpful when it comes to small boats and thus I don't expect anything from the organization in the future, I'll support them because the absence of a national body is worse.  Same goes for each organization below, each has its issues but none of them are some faceless organization, just more volunteers and why they do or do not take some actions is not always obvious but I doubt it is ever malicious.  Go volunteer.  Please.  It only gets better when people volunteer.
Hope I and others have something interesting to post here in the future.
Amen to that.
If there were more people with this attitude, sailing would be in a lot healthier state today than it is.
Sailing as an organized sport (especially racing) only exists because of all the volunteers who get involved in organizations at all levels to make the sport work and to fix stuff that needs fixing.
I know people who refuse to join their class or their local club because those organizations aren't perfect. They drive me crazy. There would be no sport of sailing at all if everybody took that position.
If you see something in sailing that needs doing, and nobody is doing it, then get stuck in and do it yourself.
If you can't think of anything that needs doing, then be the guy who brings the beer.
We had a great winter series day yesterday - 23 boats in mild (3-8 kts) and shifty wind, 50 degrees and sunny. If I counted correctly, we had:
- 14 lasers
- 3 Thistles
- 2 Flying Scots
- 2 Wayfarers
- 1 Windmill
- 1 Aero
How did you index the Aero? We used a 91.5 in light wind last year.
On 05/02/2018 at 11:34 PM, hoofhearted said:
The tri at the end is scissor, a custom deal by Randy Smyth.
Thank You! So much negativity about sailing in the US, but plenty of reasons to be optimistic, just needs someone to drive it forward.
On ‎1‎/‎26‎/‎2017 at 7:41 AM, Tcatman said:
...Maybe... "simple is best" does not work when you try and rate a brand new UFO (foiler at breeze) against a laser in a club race or try and rate a Moth... vintage 1980 versus a Moth vintage 2017.
Like this?
(Figure from Ian Ward)
Great chart!  Much better naming game then the A class has ever managed.   Do you guys kick the I14 name game  ass as well?   I think the I canoes had some good names in their history....
I am sure the club scorekeeper will know the rating difference between a Moth imperium and  the Hungry Tiger!
He just sees MOTH on the yardstick printout. and MOTH on the entry form.  ... (and of course the Imperium sailor will continue to race with a rating equal to a classic tornado against his laser buds).
Moreover, I am sure you can put your hands on those regatta results where you have that fleet of imperiums competing against a fleet of lasers to give you the statistics for a solid imperium rating under portsmouth (at three windspeeds for dinghies)..
Portsmouth was not designed to handicap development classes....   Now of course you can make up a number relative to the current table and go racing...    We call that PHRF .  If the local fleet thinks your Imperium rating is fair against the lasers.... that is all you need.
(You guys should really put out your own "Portsmouth table" with all the fun names and ratings included....  good marketing move!) (grin)
Which book?
  • The Code of Competition
    by Stuart Walker and Thomas Price
    $13.52 $ 13 52 $25.00Prime
    FREE Shipping on orders over $25 shipped by Amazon
    Only 2 left in stock - order soon.
    More Buying Choice
    Stuart gave several talks about the psychology of racing and competing around this time.   Had a chance to speak with him at a party as well.
    More Buying Choice
There's also a report on Earwigoagin about a lecture that Walker gave in 2009 in which he discussed  the psychology of group dynamics in sailboat racing fleets with some interesting ideas on what a fleet needs to do to be successful.
I may regret asking this, but has US sailing made it obvious how to submit race results?  It wasn't obvious to me when I looked.
We had 25 boats competing Sunday. A 505, a Musto Skiff an RS Aero7, 2 Wayfarers, 2 Thistles, 3 Sunfish, 2 420's, a Flying Scott and 12 Lasers. The weather helped, 62 deg. We also always have chili after sailing.
Next race day Jan. 20th at Crosswinds Boating Center.  Anyone in the central NC area, or anywhere else for that matter should consider joining us.
Nice turnout.     The Fleet is best described as January dinghy  sailors in 62 degree weather...
Now what that means for a Portsmouth fleet  development is the answer to the question... "What happens in MAY when the temps  is also 62?"
I suspect that its gonna take more then a pot of chilli to keep the PN fleet together.
Hopefully, some in the fleet experienced new competition from good sailors in other classes..  That would be a start to PN Fleet Development year round..
We run strictly Portsmouth in the winter.  In the Summer series we run one design and all boats also compete on Portsmouth and since we started doing this 3 years ago our turnout has doubled.
Sunday was the best turnout the winter so far but we have yet to see fewer than 17 boats.
Now THAT is a message that should be shared  with and copied by all clubs in the country... .
turnout doubled !!!...
Congratulations!!!
Congratulations!!!
+1.             dburchfiel, Do you use any scoring soft ware or longhand? Where can we see results?          eyeshotpar, Congrats on your par. If you have any interaction with USS re: reporting results please pass it on.
Having read this thread and noting the comments about UK Portsmouth numbers, I thought I'd just add a bit on how it's implemented or not in clubs I know..
I should point out that not all clubs in the UK use the UK Portsmouth system, On the Norfolk Broads many clubs use the Broads Handicap, which is a straight percentage off of your finishing time. This includes Dinghies and Keelboats (Keelboat = open boat with a lump of lead on the bottom).
A Star normally rates 0%,  so boats faster than that get a percentage added to their time.
However like UK portsmouth , clubs are permitted to vary the handicap should the need arise, So our Summer club has different handicaps for open waters, river racing round the cans, and river racing toa pub and back. .
No club I know of uses different handicaps due to wind speed,  most of our races are for a series, and it's assumed the wind speed will average out over a series.
Most clubs if a new boat turns up that is not in the Norfolk system, will first look at the UK PY or Provisional PY for a figure to relate to the Norfolk Handicap. if there isn't one then a look at the manufactures estimate (which often claims it's faster than it is). The Club handicapper will take a guess and allocate a number, then there will be several races to establish if thats correct.
IF the boat owner has been deliberately sailing slow, and then he starts winning everything, then his handicap will rapidly take a hit..
We, in the summer have up to 8 starts at 5 minute intervals, it's possible for you to be in a class start for a class trophy, but all the times could be aggregated to produce a winner for a Handicap trophy
The Winter club uses UK Portsmouth, and a couple of weeks ago, we had a Yeoman class start (Yeoman 3/4 ton 20ft keelboat) and two allcomers dinghy starts, again at five minute intervals. When the results were calculated, Laser first. Yeomans 2nd and 3rd, laser 4th, Splash 5th.
Personal handicaps at the clubs I've belonged to were generated, from the results using PY, and are generally used in persuit races where the slowest boat starts first and in theory everyone should finish at the same time..
Some events have a special version of the Broads Handicap, The Three Rivers Race heavily handicaps superfast boats, as because they are so fast they can get round the course before the night time lull in the wind.
And then there is the Broads river cruiser class, 427(and counting) sailing boats practically all of them different, some well over 100 years old some brand new with carbon fibre masts. handicapping that lot is a nightmare. Reading the guide lines on this page http://rivercruiser.org/index.php/rcc-handicapping
may be of interest to you...
