and also i think there will be plenty of potential buyers who don't want the put up with the compromises to the interior that water ballast entails
We'll see. The J/brothers have a good track record with market research. Not perfect, they have a lot of market successes behind them
i'm not saying they got anything wrong - just that the boat will probably be offered in more than one configuration
if someone comes along and says "I love it.., but I don't want the water ballast".., do you think they will say "take a walk"?
Another j one design with five versions.
that we all know you'll take the first opportunity to sail on, should one arise.
realistically.., one-design is hard to sustain at this size
how much one-design 122 racing was there?
there were a few less than several boats on LIS for a minute.
We'll see.
How feasible would it be to omit the water ballast without adding some keel ballast?
We'll see.
the water ballast replaces the crew, not the keel bulb
or at least that's the way they should be thinking of it
the boat should be designed with an acceptable stability, even with the ballast tanks empty.
right... the bulb weight only becomes useful as the boat heels, the water ballast is most useful when the boat is flat.
From what I am told the water ballast on the J/121 would be better served by being called liquid crew replacement technology. The J/121 has a very stable ballast ratio.
So how long until we here about the first asshole who takes a crew weight credit on account of the water ballast but still sails with eight fat dudes on the rail on windy days.
Bring it on.
If somebody who doesn't use water ballast is willing to boost the viability of series production of a water-ballasted boat ... then please encourage them to sign the cheque.
That's not how water ballasted ratings work...at least not in my part of the world.
The fuzziness comes when the water weight is accounted in the ballast ratio or when the water weight is not part of the ballast ratio.
Schrodinger's ballast?
Haha, brilliant.
BTW, the rating rules I've encountered are perfectly capable of rating water ballast as a separate entity (vs normal ballast vs crew). If its rated fair or not will naturally be part of the usual debate :)
J121*/Pogo12.50
Base price $385k (USA built) / $235k (French built)**
The pogo is 254000 Eur.
I recently sourced several numbers on various class legal production boats for consideration. The U.S built boat is about 20% more expensive than the offshore built boat with extensive U.S dealer network and the most consistent world championship winning streak. The U.S built boat is 50% more expensive than one built in Europe (the only one AFAIK) without extensive dealer network. Right now the Euro is at least 30% devalued from its more normal pre-2015 high. Maybe it won't get back there, but this makes purchasing boats from Europe fairly attractive even with the shipping and import tariff problems; they know how to build a quality boat generally and support any problems.
I asked for some specs since they're not listed. Was told these are subject to change...
She's only 0.4' wider than the 122. Considering the modern ocean racer premise, I figured that she'd be wider.
LOA - 40' LWL - 35.78' Beam - 12.3' DISP - 11.500lbs DRAFT - 7.8'
J 121 Vs J 105
Here's a quick and dirty scaling of the J/121 to a J/105. J/105 in the bottom right of the picture. As you can see, max beam is farther aft on the 121, and more beam is carried to the stern. But not a huge amount more, and 121 is actually (relatively) no beamer or less beamy than the 105...
A bit disappointing, for a short hander more form stability would be nice. Disp is pretty amazing though, thats pretty much the disp of an all carbon Andrews 39.
3K heavier than a J125. Hmmmm
And pretty much the same weight as an Aerodyne 38.. I'm not hyper impressed.
The key missing spec is ballast. Is it just light because the keel is lighter, or?
Regarding beam, J Boats have always been on the narrow side of average and they have a philosophy that seems to work for a little of people. Can't see them changing it for this boat.
Will be very interesting to see how the performance compares to the Aerodyne 38. My suspicion is that it will sail circles around it, given the relative performance of the J/122 and the displacement of the J/122.
J125 is not a fair comparison. Its completely stripped out and much lower freeboard and zero amenities. Aerodyne, is fair, still impressive with 2 ft longer.
I mean when we're comparing fast J boats then the 125 has to come into the conversation. I assume it will be faster than the Aerodyne as well(especially upwind) but I don't think it will be revolutionary. We sail boat for boat with the 122 on the Aerodyne. They're a little quicker upwind, we have them downwind.
The only revolution J Boats is trying to introduce here is needing fewer crew on a big boat. Not a performance revolution. Personally, my feeling is that is where the revolution needs to happen. If you want a faster boat, buy a faster boat. Simple. If you want to race at J/121 speeds with 4 or 5 crew, what are your options, particularly offshore? If you want to cruise at J/121 speeds at this price limit, what are your options? To me, this boat fits into a gap in the market.
Unless I'm missing something a J/111, J/122 and Aerodyne 38 are pretty similar on the water (1.090ish in IRC).
The J/121 will probably be 5-7% faster than that trio.
This will be Ker 11.3, Landmark/Mills 43 and ClubSwan 42 territory :)
Fair point, curious to see how many they sell over the next 5 years.
I'll bet 150 over 5 years globally
i sailed on a boat 20 years ago with water ballast - so i'm not sure it's very revolutionary...
Not sure anything J/Boats does is revolutionary...what they are really good at is taking things that were revolutionary, and making them easily usable by the average performance oriented sailor...
Right now there is no production 40 footer that is easily raced with a small crew...I ran a 12 or 15 person crew list to try to make sure I had 6 or 7 folks to race my 30 ft PHRF boat. If they can make all the systems work in an integrated way to let 4 or 5 crew race a 40 footer, well, that's revolution enough in my mind....And lets me dream of racing a 30 footer with 3 or 4. That would be huge, and make crew management/recruiting a lot less distasteful/brdensome than it is today.
Like a J92! :rolleyes:
Or J/88 :rolleyes:
While it would be easy to race a 92, 92s or 88 with 3 or 4, (I used to race my 109 with 6 on occasion and I did a frostbite series on my S2 9.1 with 4...took 3rd overall in a 5 race series too) without a set of class rules limiting crew to that number, and then having a PHRF OD rating, means some other guy is out there on his 92 on a breezy day with a PRHF max of 8 holding the rail down, and he goes upwind with his genoa, while us guys with on 4 aboard would have to switch down to the 3...
I know, minor complaint...
Or J/88 :rolleyes:
j92 is a fair point....j88 thats more an inshore toy imo
Aren't all these comments about 30 footers with 3-4 people missing crash's point? His point, as I understand it, is that if there were a 30 footer with a design brief like a J/121 (i.e. efficient water ballast and furlers) that you COULD sail the 30 footer effectively with 3-4 people. Obviously, you can't do that with a J/92 or J/88 as they don't have the design features of the J/121.
We have a 28 footer. 4 people needed to sail it around the buoys, 3 long-course, and 6 to go upwind effectively. 2 people are nothing but ballast and in the way going downwind. If we have effective water ballast we would never sail with more than 4 and be faster overall both upwind and downwind.
Or J/88 :rolleyes:
Of course the whole exchange was clearly tongue in cheek, but go for it...
This...I needed 5 to race the 9.1 effectively around the bouys...but PHRF allows you 8. So 3 are there to be ballast upwind...and while they all can "have" a job, it's mostly to give them one to have them be involved, rather then needing them to do it...
but I got that Mid's and BTL's points were a meant tongue-in-cheek..
3-4 people missing? While a J/92 or a J/88 might not be optimal with 4 people, there's no reason you couldn't sail race either effectively with 4 in any reasonable condition (LT 25 knots). The J/88 only allows 6 OD, and many of the best owners consistently sail with 5 in all conditions.
But again, you missed the :rolleyes: 's?
I'm not sure what I missed. The original comment was sailing with 3-4. The J/88's, it sounds like, sail with 5 or 6. The point is that a waterballasted boat like a J/88 could sail competitively with 3 or 4 and be faster both upwind and downwind. That would be a much better boat, in my opinion, but then I don't like people.
Also, I didn't say 3-4 people missing. I said the the comments about 3-4 people are missing crash's point. Totally different meaning. Missing people, missing point.
1 2 1 a cool boat ....or at least i think it will be.
but for half a million....better be.
i was saying 92 is closer to the purpose than 88.... all three of them and every other boat ever built r all toys so iron
any panties that might have become bunched.
oh ok emojis .....sorry here's one
^_^ i dont know wtf it means either.
also i think 4 is optimal in a 92 with 3 my next choice. Then 2.
Latest J/Newsletter shows the boat popped out of the mold. Looks like quit the departure from standard J/Boat design language. Very wide in back for a J/Boat.
The marketing copy seemed a little over the top, even for a confessed J/Boats fanboy!
(Newport, RI)- Air space, that is, at CCF Composites in Bristol, RI! It is an exciting development in the new J/121 offshore speedster project. She looks sleek and very fast!
Elon Musk’s Space-X or Jeff Bezo’s Blue Origin projects have nothing on the hypersonic capabilities of the latest sailing machine evolving off the drawing boards from the J/Design Team. Optimized for short-handed sailing, you can see from these photos the J/121 has a knife-like bow to cut through the seas with minimal resistance and powerful stern-quarters that will permit her to race down the waves at 20+ kt speeds all day long offshore.
LOA - 40' LWL - 35.78' Beam - 12.3' DISP - 11.500lbs DRAFT - 7.8'[/size]
For some reason I hadn't realized the 112e was a different hull than a j111....it's a foot more stability....I have owned a couple j boats and really like them...I have been disappointed in their short handed offerings and the 121 is really cool in that direction but too much boat for me. If they gave the 112e some of the 11s treatment and added water ballast...I'd sorta get uncomfortable....
It seems like it would be easy...
On 7/26/2017 at 3:55 PM, JL92S said:
It's awfully quiet over here...
Yes, but there has not been any news on it lately. Isn't the launch of hull no 1 was projected for this August? Im really looking forward to see it already.
pretty sure i'd rather have a Pogo 12.50
Its a really tough choice. If for cruising, then Pogo has so much more boat to offer without a doubt, but if racing,  its so beamy with so much wetted surface and a punishing rating. Just last weekend it came in about 1 hr before a well-sailed Hanse 375 after 190 nm. Phrf 6 vs. 114. Im sure 121 would have kicked ass.
mostly what that observation proves, is that single number rating schemes don't work very well
if the race is in light wind.., and/or has a lot of beating, then a boat like the 12.50 will probably not sail to its rating.., and that's more of an indictment of the rating system than of the boat generally.
if i was going to sail across an ocean short handed.., i think i'd rather have the pogo than than the hanse
I agree with you 100%. Horses for courses. Handicap rules suck. Across oceans shorthanded and cruising, Pogo no question. Racing in any handicap system, i'll have to pick the 121.
Any insider information on when this thing is launching?  Looking forward to seeing the finished product.
Test sails with customers in September, so I guess we'll see a splash soon.
On 12/6/2016 at 3:32 PM, CrushDigital said:
Won't that just make it a J122 with two wheels, kinda kills the whole "less crew" thing, which features prominently in their advertising / design brief.
122 like 109 is an IRC optimized design. 121 seems more in the lighter, faster, damn the rating family like 111 & 88 to a certain extent.
Nobody at J-Boats has sailed a well tuned and sailed 125 in the ocean, so I don't think they realize how quick they are.
At least that's my assumption when I read the silly advertisement for this new boat.
the 121 will cruise too - a big factor for about 90% of people buying 40ft sailboats.., and they will sell 10X as many 121's as they sold 125's
so, it's not "silly", if you are making boats as a business.
and, if the 125 molds are still around, and usable, you could probably get a new 125 built
Yup, also 125 built in carbon would be a few hundred grand more. Tough sell in a tough market. How many production (non-custom) builders of sailboats are left in US? Even Sabre is building motorboats now.
Does it have active water ballast (as in you can pump leeward tanks into windward tanks for extra rail meat)?   Is that even legal in PHRF?
Looks like it's on the trailer and splashing soon.
looks nice
i hope they sell a lot of them. from what i know it probably wouldn't be what i would buy at that price, but i guess it will be just right for some people.
1 hour ago, Spin Echo said:
The bobstay is I think a new idea for a stock J (I've seen attachments bobstayed half-ish way along the sprit). Is this for increased luff tensions on Code Zeros and the like, or is it a way of reducing the layup (and thus weight) of the sprit itself?
1 hour ago, woodpecker said:
Rating is up. Looks like it is 30. Only 3 sec faster than a 122?
122 - 121 = 1...  so 3 seconds faster sounds pretty good, no?
For those not really paying attention, the idea wasn't to build a boat faster than any previous J in its size range.  The idea was to build one that only needs half the crew of any J in its size range...
I hope this isn't a classic jboat case where they have a great recipe with all the best ingredients and then slightly undercook it
The boat is a lot lighter than the 122, not sure about sail area but it has the advantage of using full crew + water ballast upwind and dumping the water downwind in PHRF.
I thought with lighter weight and more movable (and removable) ballast the rating would be much lower?
well, given that it's a "PHRF" rating.., and that the P in PHRF stands for "performance"..., and that nobody has had a chance to observe the performance of the boat yet.., the rating has to be viewed as provisional - a best guess...
anyway.., they didn't set out to build the fastest 40ft boat they could
they know that their buyers are looking at the total package, and that speed is only one part of that package.
there are already 40ft boats for people who rank speed at the top of the list - say the melges 40 - and i haven't heard that they are selling very many of them.
the aim for this boat seems to be more like that of the  pogo 12.50 - and i understand there is a pretty long wait for one of those.
Does the 30 rating allow for water ballast use?  I didn't think phrf Narragansett bay allowed water ballast.
I asked that earlier and got no response.
In the comments of the cert it says that it is for fully crewed.  PHRF-NB does allow for water ballast but that is not reflected on that cert.
On 8/22/2017 at 5:45 PM, Geronimo said:
Yikes on the main flake job...although probably not easy on brand new 3di's
roll the damn sail  ;-)
Curious what PHRF-NE is going to give it as I guess they are doing the Figawi next year
Not sure why the big discrepancy in ratings between the 120 and the 122, 9 sec a mile.
            NB      NE
120      45        51
122      36        33
121      30         ?
125       -3        -3
41 minutes ago, A-NU-START said:
Because the J/122 is a significantly faster boat than the J/120?
122 is 9 sec a mile faster then a 120 in new england only ..wonder why?
8 minutes ago, woodpecker said:
You better have your glasses checked...
Copy and paste from the list :
J 120 ODR CARBON RIG   51
J 122   33
I didn't come here for an argument. That is not at 9 second difference. It is a an 18 second difference, or a 21 second difference to the J/120 ODR.
Yes, My point is that the 122 takes a extra 9 sec a mile hit in NE vs if they were racing in NB.
Why would one boat be 9 sec a mile faster in one body of water vs another that is 50 + or - miles away?
Sorry, My fault I should have explained it clearer.
I am on the Lake Champlain PHRF Committee, so I look at a lot of PHRF numbers from around NA. We have also rated the J/120 (in two different configurations), and a J/122, both before my time.
LC PHRF:
30 J/122
48 J/120 CF
51 J/-120 AL
J/Boats provides rating suggestions, which help us rate J/Boats vs J/Boats, and give us reference points.
http://www.jboats.com/resources/j-sailing-phrf-performance-sailing-analysis
US Sailing is now providing National Reference Ratings for a couple of hundred boat models. I think this is a good development to help regional PHRF committees.
33 J/122
48 J/120 CF
51 J/-120 AL
In PHRF NB, I see:
36 J/122
48 J/120 CF
51 J/120 AL
I think the base rating for the 120 in NB is 45?
That is great that US sailing is trying to get the whole country on the same page with ratings.
Do you have a link to the full list of what US Sailing is proposing for ratings?
