• Announcements
    • UnderDawg
      A Few Simple Rules   05/22/2017
      Sailing Anarchy is a very lightly moderated site. This is by design, to afford a more free atmosphere for discussion. There are plenty of sailing forums you can go to where swearing isn't allowed, confrontation is squelched and, and you can have a moderator finger-wag at you for your attitude. SA tries to avoid that and allow for more adult behavior without moderators editing your posts and whacking knuckles with rulers. We don't have a long list of published "thou shalt nots" either, and this is by design. Too many absolute rules paints us into too many corners. So check the Terms of Service - there IS language there about certain types of behavior that is not permitted. We interpret that lightly and permit a lot of latitude, but we DO reserve the right to take action when something is too extreme to tolerate (too racist, graphic, violent, misogynistic, etc.). Yes, that is subjective, but it allows us discretion. Avoiding a laundry list of rules allows for freedom; don't abuse it. However there ARE a few basic rules that will earn you a suspension, and apparently a brief refresher is in order. 1) Allegations of pedophilia - there is no tolerance for this. So if you make allegations, jokes, innuendo or suggestions about child molestation, child pornography, abuse or inappropriate behavior with minors etc. about someone on this board you will get a time out. This is pretty much automatic; this behavior can have real world effect and is not acceptable. Obviously the subject is not banned when discussion of it is apropos, e.g. talking about an item in the news for instance. But allegations or references directed at or about another poster is verboten. 2) Outing people - providing real world identifiable information about users on the forums who prefer to remain anonymous. Yes, some of us post with our real names - not a problem to use them. However many do NOT, and if you find out someone's name keep it to yourself, first or last. This also goes for other identifying information too - employer information etc. You don't need too many pieces of data to figure out who someone really is these days. Depending on severity you might get anything from a scolding to a suspension - so don't do it. I know it can be confusing sometimes for newcomers, as SA has been around almost twenty years and there are some people that throw their real names around and their current Display Name may not match the name they have out in the public. But if in doubt, you don't want to accidentally out some one so use caution, even if it's a personal friend of yours in real life. 3) Posting While Suspended - If you've earned a timeout (these are fairly rare and hard to get), please observe the suspension. If you create a new account (a "Sock Puppet") and return to the forums to post with it before your suspension is up you WILL get more time added to your original suspension and lose your Socks. This behavior may result a permanent ban, since it shows you have zero respect for the few rules we have and the moderating team that is tasked with supporting them. Check the Terms of Service you agreed to; they apply to the individual agreeing, not the account you created, so don't try to Sea Lawyer us if you get caught. Just don't do it. Those are the three that will almost certainly get you into some trouble. IF YOU SEE SOMEONE DO ONE OF THESE THINGS, please do the following: Refrain from quoting the offending text, it makes the thread cleanup a pain in the rear Press the Report button; it is by far the best way to notify Admins as we will get e-mails. Calling out for Admins in the middle of threads, sending us PM's, etc. - there is no guarantee we will get those in a timely fashion. There are multiple Moderators in multiple time zones around the world, and anyone one of us can handle the Report and all of us will be notified about it. But if you PM one Mod directly and he's off line, the problem will get dealt with much more slowly. Other behaviors that you might want to think twice before doing include: Intentionally disrupting threads and discussions repeatedly. Off topic/content free trolling in threads to disrupt dialog Stalking users around the forums with the intent to disrupt content and discussion Repeated posting of overly graphic or scatological porn content. There are plenty web sites for you to get your freak on, don't do it here. And a brief note to Newbies... No, we will not ban people or censor them for dropping F-bombs on you, using foul language, etc. so please don't report it when one of our members gives you a greeting you may find shocking. We do our best not to censor content here and playing swearword police is not in our job descriptions. Sailing Anarchy is more like a bar than a classroom, so handle it like you would meeting someone a little coarse - don't look for the teacher. Thanks.
Followers 0
valtro45acp
Laser 2 spreader advice/help please
15 posts in this topic
Hi, I have an old Laser 2, but am no sailor. It had one piece cast spreader on the mast and I broke it. It appears to be so out dated that no one I have found seems to be able to help or advise on it. The mast is 2" wide and 2.5" long. Can someone please advise me with a way to replace the spreader or add a new spreader bracket that will fit, or even a similar boat that uses the same size mast that I can get parts for. I need to bring this boat back to life.
Thanks for your time
Dry and Depressed.
Was the old one pinned/screwed to a bracket? I have used just plain aluminium tubing in place of a bespoke spreader. Drilled a hole for the pin at mast bkt and cut a slot for the wire at the tip.
The original spreader was riveted in place with four rivets, it was a U type shape of cast aluminum.
post some pictures... you need to resize pretty aggressively or use a third party host (google: image hosting)
Afaik, Laser 2s had diamonds, not spreaders, the original rigs had a tube that went through the rig perpendicular to the CL. Your best bet might be to try and use an off the shelf spreader fitting, cut the arms to length and rake them well forward.
Don't seem to find a pic of the spreader, will have to dig deeper, this is the mast size.
One of my masts has a double diamond spreader setup.
First one is a Ronstan set (no longer in the catalog)
and the next is a homemade set
Pretty simple just a carriage bolt with a slot cut in it for the wire, a nut for adjusting tension and 1/2 inch copper pipe for the spreader.
You'll have to manufacture some base bracket to attach to the mast or maybe thru bolt it.
Forget all that crap - get two diameters of tube that fit snugly inside each other - cut two of the bigger diameter to length for the spreaders and put slots in one end of each, insert the smaller one through the mast and spreaders over the top, done. Choose diameter to match the hole in the mast.
Don't go mixing as many metals as Luigi Galvani above.
Another nice DIY solution for the OP.
I've had the mast for 3 years and never noticed that the spreaders were copper till last week, 38 years of galvanic corrosion and still mint.
Snapped a picture of a friends 87' Laser 2 diamond spreaders.
Not cast but tube n' tube as the other Duncan described.
Should be easy to fabricate.
Pic of the original one pice cast with a very rough weld repair and a similar spreader from another mast. I am not excited about drilling a giant hole in the mast to shove this rod through. I would be happier with a few rivet holes like I had before, but maybe it's just me.
Have you tried asking Fogh Marine in Toronto, ON, Canada?
Or maybe there's a dealer in Ireland who can replace the spreader for you...
Another option:
The Laser 2 rig is a bit of an odd duck with some very strange Ian Bruce features.
The diamonds are one such oddball thing.
Most dinghies of this size use swept spreaders between the shrouds and the mast instead of the diamonds to support the mid panel of the mast.
Look at a 420 mast.
You could probably buy a 420 spreader bracket and spreaders and replace the diamond struts and wires and never know the difference.
SHC
Hi,
On my laser 2 there is a plastic insert that fits into the spreader tube, to capture the diamond wire.  This one looks like metal.
Does anyone know a part number for such an end cap?  My boat is missing one.
thanks.
Followers 0
