Malaya
Navtec Norseman Replacement Cones
I have searched high and low for replacement cones for my 8MM Navtec Norseman fittings, and like others before me the results have not produced results. During the search it was suggested that a machine shop could produce them, perhaps a CNC could make the process easier.
So heres the deal, Im not a machinist nor do I have the equipment. I do have a couple of the cone still in original packaging which could provide dimensions and such. Further, I believe there is a market for these goodies, I came across quite a few sailors also looking for these, the 8MM seem to be very popular size.
Any thoughts, or machinists out there?
So let me get this straight ...
You're delusionaly paranoid about swaged fittings, but you're willing to reverse engineer a mechanical component with no understanding of tolerances on a public forum filled with uninformed hacks.
Help me understand, really, what you're thinking?
You really can't make this shit up ...
Good grief
Fuck off Moon
I'm a cruiser, like to be self sufficient. How do you swage a terminal in a remote location.
I must not be alone in my desire to make up my rigging as there have been mechanical terminals for years and there still many cruisers that prefer them. And theye are still made,just that Navtic has discontinued their line.
But thanks for your input
I would guess nothing more then commercial tolerances, someone is making it on a standard CNC. Bring it to a shop with a CMM, they can reverse engineer it, this ain't rocket science.
Jolie
Just trying to see if a group might want to share some of the setup costs. A dozen pieces might be a little costly. A couple of hundred would certainly bring the cost more in line.
Call Rigging Only in Fairhaven Mass.
when I used Norsemen swages to build up a forestay that could be disassembled should I need to replace a piece of track, they had spare cones.
http://riggingonly.com/Norsemanmechanicalterminal.htm
Jolie
Machine time for a CNC turning center isn't but $50/hr and they can probably make 10~15 pieces an hour. Time on a CMM is about the same, check material composition with a Niton and check hardness, you should be good to go. Material costs are negligible. Order a couple hundred and sell them. I really wonder how Navtek managed to go under from the position they once held in the marketplace. Contact DDW here, I believe he has a machine shop? Me, I would just send it to one of my Chinese suppliers.
