George Hackett
Clean Machine
sweet looking boat.  like how the mainsheet winches are placed.  the only thing not sitting well for me is the grinder in the rear.  kind of an air brake profile?  knowing Mortie, she will clean up!!!  congratulation on the new boat.
Was expecting a longer thread already...
To me that grinder in the back is likely in turbulence, so aero doesn't matter much. That is where you want the heavy guy who is grinding, so that's good. That tiller looks like it would let people step over it, which is good, but what if they try to step over it when it is being moved? Perhaps not a big deal. In my dreams I even get to see that boat in person...
40 minutes ago, peculier said:
Trick tiller? No, that's just good design. I would love to drive even smaller boats with that...
you could actually put the tiller under the deck and just have an arc shaped slot in the cockpit sole.  Much better for moving about in the cockpit.  In fact with a bit of cleverness you could just have a straight slot across the cockpit.
i remember some Dubious IOR boats with that setup.  actually looked real cool then.  but it allowed people you did not want around you, access to your space. especially the ones that sneak up on your rear end!!
On 6/19/2017 at 3:58 AM, ITA602 said:
Poor throttle lever :-)
That lever is removable, leaving a flush socket.
Didn't the dutch use something like that back in the early sailing ship days? a vertical lever that just moved across the boat instead of a wheel or tiller?
Yep, called a whipstaff
More Seriously, a modern version with a tiller attached could be quite a clean option for some of those boats with the forward tiller position
24 minutes ago, Rawhide said:
You'd need a airlock on that companionway to do the fastnet
and it should come equipped with the sound of the doors in the Enterprise on Star trek!!
Many small Marina launches have that, but mounted inside the side gunnel and moving fore and aft, instead of athwartship....
Interesting that the primaries are so far aft, might be tough to see the top spreader- jib leach
Looks cool and would not turn down a chance to go for a sail
Pulled out of racing in 25-30kts yesterday due to pump failure and 2 tons of water in the boat, this thing is a fucking pond yacht, not an offshore racer.
Should not be allowed to race if that's indicative of its watertight integrity. Do they have to drown a crew to see where this is leading?
You couldn't work that out from looking at the pictures?
IIRC, there was a ?Dubois? boat in the early days of IMS with a whipstaff.
Are you looking at the primaries? They are only just behind the pit winch, so about 2-3ft behind the mast.....
Are you looking at the mainsheet winches?
nope - mainsheet winches are forward of the primaries (which are on the "pods", aft of main trim & helm positions)
certainly gets the weight aft... "them and us"?!
DDAB_q2XUAAYXdL.jpg:orig
On 6/24/2017 at 5:43 PM, Gorn FRANTIC!! said:
Update: not a pump failure, all pumps in place and working but had not been plumbed in yet, work being done overnight to get it sorted.
Tell me how a boat can race and comply with safety requirements with non-operational (not yet plumbed = non-operational) bilge pumps? Great respect for Morty who has put together some amazing boats and campaigns over many years but this looks to be a serious infringement of the rules.
The video I saw only mentioned electric pumps, most likely with that amount of water downstairs they decided the manuals would take too long to empty it out.
The boat is fully rules compliant with manual pumps but we had an issue with the seal on the fore hatch which let a lot of water in the bow. It would have taken a long time to manually pump it out as the electric pumps were not connected. I took the decision to call it a day in the last race to gets all the little jobs done as this was our first ever sailing day in not perfect conditions.
I am not planning on any more Fastnet Races, I'm sure the boat would be OK but not my back. I think you will find that all these boats and the TPs racing in the Med have a number of small electric pump as they do ship a lot of water in a breeze. Good fun though!
Cheers Morty, hope you keep her a whole lot dryer in future.
Really interesting to see how visible the slewing is in the wake track right at the transom - the steering adjustments for the waves slide the stern so easily side to side on the water.  Same in any planing boat, I suppose, I just hadn't noticed it in the same way.
