barfy 1,052 #4901 Posted November 16, 2020 5 minutes ago, Ex-yachtie said: If it was a structural modification, wouldn’t you expect it to change in dimension along its length? If it’s some sort of stiffener there’s no reason for it to be that deep at the bow. And perhaps it wouldn't have vertical glue lines along its length if they were looking for a stiffener. 2 Share this post Link to post Share on other sites
Xlot 694 #4902 Posted November 16, 2020 @weta27 What’s under that tarp? Share this post Link to post Share on other sites
mikenz2 1,536 #4903 Posted November 16, 2020 2 minutes ago, Xlot said: @weta27 What’s under that tarp? Main sail. Share this post Link to post Share on other sites
Xlot 694 #4904 Posted November 16, 2020 Just now, mikenz2 said: Main sail. Nah, the flat blanket below it - hiding the “boom” surrogate, I suppose 1 Share this post Link to post Share on other sites
mikenz2 1,536 #4905 Posted November 16, 2020 Just now, Xlot said: Nah, the flat blanket below it - hiding the “boom” surrogate, I suppose Ah, it's a padded cover they put down to protect the deck when they're not sailing. It''s feature-less underneath: They have a foredeck cover too: 4 Share this post Link to post Share on other sites
JALhazmat 930 #4906 Posted November 16, 2020 1 hour ago, mikenz2 said: It arrived on the ship with Boat 1, it was wrapped and labelled "Rig 2". Seen 10th November: Sorry for being thick, the angle and light on the other pic made it look much shorter and messed with the shape a bit carry on snooping Sir! Share this post Link to post Share on other sites
mikenz2 1,536 #4907 Posted November 16, 2020 Just now, JALhazmat said: Sorry for being thick, the angle and light on the other pic made it look much shorter and messed with the shape a bit carry on snooping Sir! Don't be sorry - it was messing with my head big time too :-) Share this post Link to post Share on other sites
Zaal 313 #4908 Posted November 16, 2020 Funny, two 27 on board 1 Share this post Link to post Share on other sites
enigmatically2 462 #4909 Posted November 16, 2020 right hand one is 17, not 27 I think 4 Share this post Link to post Share on other sites
Zaal 313 #4910 Posted November 16, 2020 12 minutes ago, enigmatically2 said: right hand one is 17, not 27 I think Ooops, you're right ! Share this post Link to post Share on other sites
NZK 304 #4911 Posted November 16, 2020 2 hours ago, Xlot said: Nah, the flat blanket below it - hiding the “boom” surrogate, I suppose Looks like a big sling they use to crane the mainsail on/off the boat - kinda like a stack-pack/lazybag except removable. They use similar things a lot for superyacht sail installs/removals... Share this post Link to post Share on other sites
Zaal 313 #4912 Posted November 16, 2020 Three new videos by Justin Mitchell. Close racing with AM. At the end of video 84 there is a sort of "speed test". My opinion is that LR is faster in a straight line, but AM tacks and gybes more dry. LR sometime touch the water in the last part of the tack / gybe, after going on the two foils, when is back on one foil only. AM had more time on the water, so maybe it's just practice. Or maybe is a trade-off of the new LR B2, that seems also to fly even, not too much bow down, and not overheeled compared to B1. Strange, because what Max and Bertelli always said is that all the boats will have pretty much the same top speed, and the key element to win will be stability and maneuvers. Maybe they need just more time on the water. 1 Share this post Link to post Share on other sites
enigmatically2 462 #4913 Posted November 16, 2020 8 minutes ago, Zaal said: Three new videos by Justin Mitchell. Close racing with AM. At the end of video 84 there is a sort of "speed test". My opinion is that LR is faster in a straight line, but AM tacks and gybes more dry. LR sometime touch the water in the last part of the tack / gybe, after going on the two foils, when is back on one foil only. AM had more time on the water, so maybe it's just practice. Or maybe is a trade-off of the new LR B2, that seems also to fly even, not too much bow down, and not overheeled compared to B1. Strange, because what Max and Bertelli always said is that all the boats will have pretty much the same top speed, and the key element to win will be stability and maneuvers. Maybe they need just more time on the water. I'm not convinced. Initially after AM tacks, LR is faster yes. Then AM gets up to speed and they seem more equal, then the angles change, AM is pointing higher than LR so you can't judge. Then after they tack again, they both bear away for downwind bit and AM seems to be pointing more downwind. So although LR may appear at first sight faster, she may not be, and her VMG may certainly be worse 1 Share this post Link to post Share on other sites
buckdouger 235 #4914 Posted November 16, 2020 7 hours ago, weta27 said: Interesting detail with the deck hollows where the rudder assembly diagonal struts come down - similar issues of superposition for foil to arm juncture? 4 hours ago, mikenz2 said: Ah, it's a padded cover they put down to protect the deck when they're not sailing. It''s feature-less underneath: They have a foredeck cover too: Have we seen such nice foot camber on the boomed setups? 3 hours ago, enigmatically2 said: right hand one is 17, not 27 I think Larry.. 1 Share this post Link to post Share on other sites
The_Alchemist 1,086 #4915 Posted November 16, 2020 From one of Weta27 pics, you can see that they didn't extend the keel modification (blade) all the way back. Can you imagine the discussions that took place before they did this? How is the performance of the new hull? Great, but we need to cut it in half and add a few millimeter blade down the center... Share this post Link to post Share on other sites
Zaal 313 #4916 Posted November 16, 2020 What about this.... "holes" ? 1 Share this post Link to post Share on other sites
JALhazmat 930 #4917 Posted November 16, 2020 1 hour ago, buckdouger said: Interesting detail with the deck hollows where the rudder assembly diagonal struts come down - similar issues of superposition for foil to arm juncture? Have we seen such nice foot camber on the boomed setups? Larry.. There was on ineos b1 1 Share this post Link to post Share on other sites
Xlot 694 #4918 Posted November 16, 2020 48 minutes ago, Zaal said: What about this.... "holes" ? Turbulators, they copied INEOS again. Either that, or there’s an infestation of the dreaded Kiwi carbon-eating mole 1 Share this post Link to post Share on other sites
Zaal 313 #4919 Posted November 16, 2020 14 minutes ago, Xlot said: Turbulators, they copied INEOS again. Either that, or there’s an infestation of the dreaded Kiwi carbon-eating mole Yes, could be. Just 2 ? Ineos has 4 each side. Maybe is the caterpillar, magneto hydro-dynamic propulsion, like in "The hunt for Red October" Share this post Link to post Share on other sites
JALhazmat 930 #4920 Posted November 16, 2020 Stick on keel, turbulator/ion drive vortex technology... wonder if they are going to ask Ferrari to build some foils next Share this post Link to post Share on other sites
JALhazmat 930 #4921 Posted November 16, 2020 1 hour ago, The_Alchemist said: From one of Weta27 pics, you can see that they didn't extend the keel modification (blade) all the way back. Can you imagine the discussions that took place before they did this? How is the performance of the new hull? Great, but we need to cut it in half and add a few millimeter blade down the center... Doesnt the rotation point of the arms have to sit a fixed point above the bottom of the boat? “quick stick a bit on the bottom before the come back and measure it again... “ 1 Share this post Link to post Share on other sites
enigmatically2 462 #4922 Posted November 16, 2020 13 minutes ago, JALhazmat said: Stick on keel, turbulator/ion drive vortex technology... wonder if they are going to ask Ferrari to build some foils next Well if NYYC go down the same route their motorsport experts will be asking when the Kiwis are going to put the banking in on the corners so that the yachts can turn 1 Share this post Link to post Share on other sites
JonRowe 668 #4923 Posted November 16, 2020 53 minutes ago, Xlot said: Either that, or there’s an infestation of the dreaded Kiwi carbon-eating mole The kiwi carbon-eating mole can only be kept at bay by fencing around your compound with no 8 wire. Share this post Link to post Share on other sites
Southern Cross 44 #4924 Posted November 16, 2020 6 hours ago, JALhazmat said: Doesnt the rotation point of the arms have to sit a fixed point above the bottom of the boat? Figure 13.1 : Foil geometry ~ Foil cant axis 520 mm (+/- 3 mm) above measurement water plane (MWP). Cant cylinder mount 90 mm (+/- 3 mm) below MWP. ~ bottom (fairbody at centreline) of boat is is not measurement constrained. 1 Share this post Link to post Share on other sites
Horn Rock 1,186 #4925 Posted November 17, 2020 At least a dozen "No step" signs on LR. Bit of a minefield.......Structurally it looks to be all or nothing........Curious as to what the vertical ribbing in the forward cockpits are? They're symmetrical - on both sides. Does it imply there's heat coming from something?.......... Note the two temporary winches straddling the mast. Not there when sailing. So instead of a boom, do they have some sort of electromagnet system under the ramp to shape the main? 2 Share this post Link to post Share on other sites
JALhazmat 930 #4926 Posted November 17, 2020 The vertical ribbing? That’s just the carbon weave 2 Share this post Link to post Share on other sites
weta27 3,953 #4927 Posted November 17, 2020 JALhazmat is right, it looks like ribbing or a grill but it's just the carbon weave, vertical zig-zag pattern, all around the cockpit walls. 3 Share this post Link to post Share on other sites
weta27 3,953 #4928 Posted November 17, 2020 6 hours ago, Horn Rock said: At least a dozen "No step" signs on LR. Bit of a minefield.. The area just forward of the mast and jib track (above the FCS) is open during setup, and they place two or three flimsy-looking covers over it when done. 4 Share this post Link to post Share on other sites
MastaVonBlasta 97 #4929 Posted November 17, 2020 1 hour ago, weta27 said: The area just forward of the mast and jib track (above the FCS) is open during setup, and they place two or three flimsy-looking covers over it when done. Great, sneaky photos! I wish we could have a more top-down view and see all the secret goodies down in there! Maybe @weta27 would be interested in deploying a mini-drone? With so many no-steps looks as if the hull & deck have plenty of non-structural fairings and covers and the inside is quite hollow. Must be difficult to achieve a good stiffness without any continuous and deep bulkheads aft of the mast. Surely that box-ramp below the main is structural and contributes quite a bit to the the overall torsional stiffness. Share this post Link to post Share on other sites
barfy 1,052 #4930 Posted November 17, 2020 9 hours ago, Horn Rock said: So instead of a boom, do they have some sort of electromagnet system under the ramp to shape the main? Again with the magnets . Would strangle the boys with the gold chains. 3 Share this post Link to post Share on other sites
Horn Rock 1,186 #4931 Posted November 17, 2020 3 hours ago, barfy said: Again with the magnets . So how are they controlling the main Barfy? Share this post Link to post Share on other sites
JALhazmat 930 #4932 Posted November 17, 2020 very small hamsters sandwiched between to carbon skins that chase small bags of sunflower seeds that are moved by hydraulics to get rodentto move to teh correct location dragging the sail into position. 6 Share this post Link to post Share on other sites
enigmatically2 462 #4933 Posted November 17, 2020 17 minutes ago, JALhazmat said: very small hamsters sandwiched between to carbon skins that chase small bags of sunflower seeds that are moved by hydraulics to get rodentto move to teh correct location dragging the sail into position. Fake news. Its guinea pigs Share this post Link to post Share on other sites
buckdouger 235 #4934 Posted November 17, 2020 4 hours ago, barfy said: Again with the magnets . Would strangle the boys with the gold chains. I'm gonna agree on the basis that the required forces would be very hard to come by with any air gap. Gold isn't an issue but it certainly would make things harder if anything ferrous was around. Share this post Link to post Share on other sites
RMac 293 #4935 Posted November 17, 2020 If you wanted to do a true boomless setup that would tension both leech and foot, there's a way to do it with 2 tracks and 4 cylinders. Mainsheet track would be located just below std leech location and have the same radius as foot length. Have a pair of rams facing upwards controlling leech tension. Rams are attached to toggles on the traveler cars to be able to tilt fore and aft. This is your mainsheet/leech tension. Have a smaller radius track located ~.5m ahead of that track. 2 cars and 2 rams again, but these rams extend aft and up, and attach to the mainsheet rams with a sliding collar. These rams affect the fore/aft location of the top of the mainsheet rams, so essentially move the clew mostly fore/aft with a little up/down as well. You'd need some serious metal in the mainsheet ram pistons, but this would give you 3d control of both clews on the main. Just a thought. 1 Share this post Link to post Share on other sites
mikenz2 1,536 #4936 Posted November 17, 2020 Tuesday: 7 Share this post Link to post Share on other sites
mikenz2 1,536 #4937 Posted November 17, 2020 9 hours ago, MastaVonBlasta said: I wish we could have a more top-down view and see all the secret goodies down in there! It's been tricky to get good shots of the secret goodies in there. 4 Share this post Link to post Share on other sites
Priscilla 2,087 #4938 Posted November 17, 2020 18 hours ago, Horn Rock said: So instead of a boom, do they have some sort of electromagnet system under the ramp to shape the main? Just loose footed. 1 Share this post Link to post Share on other sites
Kate short for Bob 226 #4939 Posted November 17, 2020 4 hours ago, RMac said: If you wanted to do a true boomless setup that would tension both leech and foot, there's a way to do it with 2 tracks and 4 cylinders. Mainsheet track would be located just below std leech location and have the same radius as foot length. Have a pair of rams facing upwards controlling leech tension. Rams are attached to toggles on the traveler cars to be able to tilt fore and aft. This is your mainsheet/leech tension. Have a smaller radius track located ~.5m ahead of that track. 2 cars and 2 rams again, but these rams extend aft and up, and attach to the mainsheet rams with a sliding collar. These rams affect the fore/aft location of the top of the mainsheet rams, so essentially move the clew mostly fore/aft with a little up/down as well. You'd need some serious metal in the mainsheet ram pistons, but this would give you 3d control of both clews on the main. Just a thought. How would you control twist with that arrangement? Share this post Link to post Share on other sites
barfy 1,052 #4940 Posted November 17, 2020 5 hours ago, Horn Rock said: So how are they controlling the main Barfy? Loose footed from the pictures we've seen. Some special sauce of rams to provide at least 2d control of the track point, plus sheeting. There is no evidence of any other sheeting up the foot. Magnets are heavy, and would require electro magnets to have control, electricity is not available. If after a run many small items are stuck to the sail foot, then it's magnets. Share this post Link to post Share on other sites
barfy 1,052 #4941 Posted November 17, 2020 10 minutes ago, Kate short for Bob said: How would you control twist with that arrangement? Top control zone twist plus sheeting? How do any of the teams control twist? 1 Share this post Link to post Share on other sites
Horn Rock 1,186 #4942 Posted November 17, 2020 2 hours ago, barfy said: Some special sauce of rams to provide at least 2d control of the track point, So rams to induce that curve in the foot batten? Share this post Link to post Share on other sites
barfy 1,052 #4943 Posted November 18, 2020 42 minutes ago, Horn Rock said: So rams to induce that curve in the foot batten? Foot tension and some voodoo flex material in the batten? Seems easier than big fo permanent magnets..they would have to be cripplingly strong. And how would they release? Drop down into the bilge on little carriages? Seems too hard. 1 Share this post Link to post Share on other sites
Stingray~ 1,222 #4944 Posted November 18, 2020 Magnets is a ridiculous idea! 2 Share this post Link to post Share on other sites
barfy 1,052 #4945 Posted November 18, 2020 3 minutes ago, Stingray~ said: Magnets is a ridiculous idea! So are almost all of your thoughts spewbot. Share this post Link to post Share on other sites
barfy 1,052 #4946 Posted November 18, 2020 12 minutes ago, Stingray~ said: Magnets is a ridiculous idea! Tell us more about the app for this cycle please. Share this post Link to post Share on other sites
Stingray~ 1,222 #4947 Posted November 18, 2020 18 minutes ago, barfy said: So are almost all of your thoughts spewbot. Fuck off, Herbfy! Lmao! Share this post Link to post Share on other sites
pusslicker 247 #4948 Posted November 18, 2020 47 minutes ago, barfy said: So are almost all of your thoughts spewbot. A bit rich coming from you of all people. 1 Share this post Link to post Share on other sites
Zaal 313 #4949 Posted November 18, 2020 On 10/23/2020 at 12:29 PM, Zaal said: Just found this interesting interview by sailor / journalist Bacci del Buono with Pietro Sibello, mainsail trimmer of Luna Rossa. - The softwing / double mainsail is an hybrid of the wingsail and a traditional mainsail. It takes the best of both. The mast (26 mt tall) has a D section. The two mainsail are hoisted on it, continuing the two profiles of the D. The sofwing is more performing than a traditional mainsail and it's a lot easier to manage than the wingsail. If you have any issue during the training you can always lower the mainsail and go back home, without having to take off the entire mast. - Asked by Bacci on what's inside the two sails, Sibello answer that the Rule is open about this, every team is free to design their own system to control the shape of the sails. The softwing can be controlled in two parts of the mast. In the 4 mt at the top of the mast and in the 1.5 mt at the base. Between this two sections you can only choose where to put the battens, and how many of them (although there is a maximum limit on how many battens you can use). You can choose also how to connect the battens to the mast. You can connect them directly to the mast, so they rotate with it, or you can put something between the mast and the batten in order to make it move less when the mast rotate. - The mast rotates, and the spreaders are connected to it with a ball, a little sphere that allow the spreaders to keep their position while the mast is rotated. - They sail at more than 30 knots upwind, with 15 knots of wind. The apparent wind is more than 50 knots, so the aerodynamics is a key element of this boats, and that's why you have to seal the lower part of the mainsail (or the boom) to the deck. You have to be very "clean" very essential, in that part of the boat, and having a boom makes it difficult. He confirms that the current boomless setup is achieved with two semi rigid battens. He adds that of course removing the boom it's not easy, but he's happy about their solution. - American magic has a traditional boom, while ETNZ has a boom that is not 100% structural, they use ut to control the camber of the mainsail. - The main purpose of closing the gap between the lower part of the sail / the boom and the deck is to avoid the passing of air between the deck and the boom. This could disturb the main air flow creating turbolence. Every team do this, with different solutions. Teams that have the boom put a sort of apron under it and close the gap. He adds that it's difficout to cover the boom without having defects in the shape of the mainsail and in the air flow. If the sail is sealed with the deck it's more clean and more performing. - He would choose the wingsail over the soft wing for performances, but the sofwing is a lot more manageable. - Asked about the possible future use of the double mainsail in other boat classes, he answer that it's possible it will be used in top races circuits, but not in less competitive environment. Bacci jokes that it will be used in the Sidney - Hobart but not in the Alassio (a small italian city) Winter Regatta. In this interview with Pietro Sibello (mainsail trimmer) he confirmed there are semi-rigid battens at the foot of the mainsail. He can't say more about the control the camber of course, they must "push" or "flex" the battens somehow. 2 Share this post Link to post Share on other sites
enigmatically2 462 #4950 Posted November 18, 2020 16 minutes ago, Zaal said: In this interview with Pietro Sibello (mainsail trimmer) he confirmed there are semi-rigid battens at the foot of the mainsail. He can't say more about the control the camber of course, they must "push" or "flex" the battens somehow. Why "must"? Battens can bend with the sail pressure, just like on traditional sails. They are just made to be flexible enough. Without a boom it is of course harder to control that bend, but perhaps they think they have enough control from the mainsheet. Given that the AWA is always much the same it is possible. Yes they lose the fine control for wind conditions that a boom gives with the outhaul, but maybe they think that the gains from a smoother end-plating are worth it :shrug: Share this post Link to post Share on other sites
RMac 293 #4951 Posted November 18, 2020 20 hours ago, Kate short for Bob said: How would you control twist with that arrangement? Twist of the mainsail leeches would be done with the vertical mainsheet ram, very much the same as with a "standard" ac75 mainsheet ram(s). Kind of picture the mainsheet and "outhaul" rams coming together to make an inverted y, with the vertical ram sliding on the end of the more horizontal ram. You get essentially infinite clew positions inside a box, and you can define the box with piston and cylinder body lengths. The only hassles here are the lateral forces on the mainseet ram piston, and the weight of essnetially doubling the tracks, cars and rams. Way back when there was an argument about whether the below deck mainsheet could also be acting as an outhaul (hint: no) or whether the foot tension was being done with battens (hint: yes) but if you wanted to make a totally belowdeck system to do both, this is how you could do it. You would just likely bend a bunch of pistons before getting the spec right! Again, I don't think LR has this, but it's an idea that could accomplish what some people thought LR was up to. Share this post Link to post Share on other sites
RMac 293 #4952 Posted November 18, 2020 Twist and trimming of the mainsheet/leech would be pretty much the same. The only difference would be that you could also push that ram with the double acting "outhaul" cylinder to angle the mainsheet ram aft, tensioning the foot. The controls would be more like a 3d lead, unless you wanted to change the actuators move both cylinders at once to fake having only outhaul or mainsheet acting at once. The "outhaul" track and car would need a race of bearings above and below the track flange to handle the loads in both directions, but that's been done. Share this post Link to post Share on other sites
Ex-yachtie 1,459 #4953 Posted November 18, 2020 20 hours ago, Priscilla said: Just loose footed. Is that Rita 1 in the background at about 1:15? Share this post Link to post Share on other sites
RMac 293 #4954 Posted November 18, 2020 Just picture most of that below deck, with the mainsheet piston sticking up through a wide slot. How wide depends on how much travel the outhaul cylinder needs Also, I know most boats have one single cylinder for the mainsheet, this system needs two since you're positioning both clews seperately via the outhaul rams. Bet the total system weight is still less than a boom though. Share this post Link to post Share on other sites
atwinda 87 #4955 Posted November 18, 2020 5 hours ago, RMac said: Twist and trimming of the mainsheet/leech would be pretty much the same. The only difference would be that you could also push that ram with the double acting "outhaul" cylinder to angle the mainsheet ram aft, tensioning the foot. The controls would be more like a 3d lead, unless you wanted to change the actuators move both cylinders at once to fake having only outhaul or mainsheet acting at once. The "outhaul" track and car would need a race of bearings above and below the track flange to handle the loads in both directions, but that's been done. Or if you put both the rams below deck, and operate it as a floating jib lead, you'd probably have the solution. Conceptually, you need to control in 2 dimensions, and that's what you've diagrammed out. I just don't think this is how they have implemented it. Share this post Link to post Share on other sites
Sailbydate 2,387 #4956 Posted November 19, 2020 On 11/17/2020 at 8:39 PM, weta27 said: JALhazmat is right, it looks like ribbing or a grill but it's just the carbon weave, vertical zig-zag pattern, all around the cockpit walls. Side mount intercoolers for the hydraulic fluids, obviously. ;-) 1 Share this post Link to post Share on other sites
I14RACER 176 #4957 Posted November 19, 2020 On 11/17/2020 at 9:45 AM, Horn Rock said: So how are they controlling the main Barfy? For magnets to handle those loads they’d need to be electromagnets and that couldn’t be powered given the restrictions. Also unnecessary weight. Absolutely no way they are controlled by magnets. Probably, controlled with simple lines, blocks, and winches that adjust the tension on the battens. Much like a leach line would do. 2 Share this post Link to post Share on other sites
Nutta 206 #4958 Posted November 19, 2020 Magnetic monopoles might require less power... 8-) Share this post Link to post Share on other sites
barfy 1,052 #4959 Posted November 19, 2020 1 hour ago, I14RACER said: For magnets to handle those loads they’d need to be electromagnets and that couldn’t be powered given the restrictions. Also unnecessary weight. Absolutely no way they are controlled by magnets. Probably, controlled with simple lines, blocks, and winches that adjust the tension on the battens. Much like a leach line would do. And the top control zone is playing a huge part in the shapes we see. Problem is it's all hidden from sight. Share this post Link to post Share on other sites
Mozzy Sails 423 #4960 Posted November 19, 2020 Jesus, controlling camber in a sail without a boom is not a new thing. Everyone has seen a jib. If it's on a track across the boat (mainsheet traveller), then most systems adjust the twist and foot depth by altering the clew board position (or sometimes tack height). It would be easy to have an adjustable clew board between the twin skins. So it's most likely that. If you want to adjust the sheeting angle at deck level, then you need cars that move forward and aft (see RMac post). But that soon takes up lots of deck space and I don't think the deck opening at the traveler is large enough for this. The downside to this is the mainsheet carries enormous load as it's doing the job of both mainsheet and outhaul. This is why boomless cat's end up with massive purchase systems. The other disadvantage is the sheeting angle changes as you ease the sail, so to replicate the easing characteristics of a boom set up you would have to be co-oridnate traveller, mainsheet and clew position (similar to moving jib cars forward as you ease the sheeting angle to retain leech tension). This is quite dramatic and it it logistically difficult to get enough range of movement at the clew to ever compensate for this. The feedback from INEOS was that they couldn't get the sail flat enough with the boomless set up. Then you also have mast rotation. I think the boats with booms are pushing off them to rotate the mast, like the tasar spanner. With luna rosa this has to be done below deck. And again, it won't automatically change as it's not physically linked to boom movement, so it's another system you have to co-ordinate. But, the benefit is you can have a nice camber in the bottom of the sail. But with the other taking the booms so low, you have to wonder if it's worth it. 3 Share this post Link to post Share on other sites
RMac 293 #4961 Posted November 19, 2020 14 hours ago, atwinda said: Or if you put both the rams below deck, and operate it as a floating jib lead, you'd probably have the solution. Conceptually, you need to control in 2 dimensions, and that's what you've diagrammed out. I just don't think this is how they have implemented it. I don't think so either, seems like they just use a batten with some kind of variable tension. That I think would be cool to see. Could be tubular telescoping battens with a ram. 1 Share this post Link to post Share on other sites
Zaal 313 #4962 Posted November 20, 2020 Nice videos by Roger Mills and NZSP. In the first video seems that LR is trying to not go down with the hull after completing the tack, when is again on one foil. At 2:52 there's maybe a hint on what they're doing. Seems they change the angle of attack of the foil to prevent the hull going down, "pulling up" the boat. Then they have to change again the angle of attack, and sometimes they change it too fast it seems, so they go down. Any thoughts ? Share this post Link to post Share on other sites
minimumfuss 103 #4963 Posted November 20, 2020 I think all are realising its better to kiss with their skegs after slowing in turns than wheelie to stay dry, and crash stop. Weird bottom designs now seem more obvious? It's like running a drunken three legged slalom race with dwarfs in high heels. Share this post Link to post Share on other sites
Zaal 313 #4964 Posted November 21, 2020 New videos by AirflowNZ Travel and Justin Mitchell. 3 Share this post Link to post Share on other sites
Priscilla 2,087 #4965 Posted November 22, 2020 Just came by the Handbags compound plenty of noisy grinding going on. Share this post Link to post Share on other sites
Horn Rock 1,186 #4966 Posted November 22, 2020 1 hour ago, Priscilla said: Just came by the Handbags compound plenty of noisy grinding going on. I wonder which boat they're chopping up to look like Te Rehutai - B1 or B2? Share this post Link to post Share on other sites
Zaal 313 #4967 Posted November 23, 2020 No sailing today for LR ? Share this post Link to post Share on other sites
Nutta 206 #4968 Posted November 23, 2020 24 minutes ago, Zaal said: No sailing today for LR ? They're practicing racing required for their participation in the AC36 match. Share this post Link to post Share on other sites
Forourselves 996 #4969 Posted November 23, 2020 9 minutes ago, Zaal said: No sailing today for LR ? Doing what they did the last time they competed in the AC in Auckland, chopping the bow off and making a new one lol Share this post Link to post Share on other sites
uflux 571 #4970 Posted November 23, 2020 1 hour ago, Forourselves said: Doing what they did the last time they competed in the AC in Auckland, chopping the bow off and making a new one lol I guess that is slightly better than waiting for it to fall off again Share this post Link to post Share on other sites
nav 471 #4972 Posted November 23, 2020 ^ Confirms they helm on the same side they drive on Share this post Link to post Share on other sites
Zaal 313 #4973 Posted November 23, 2020 Just watched an interesting Instagram Live with Max Sirena for GQ Magazine. He talked about the Cup in general and he added something cool: - Every boat creates a "vortex" of air under the bow, an air cushion visible in some pictures / video ( @weta27 @mikenz2 did you ever noticed this ?) - Sailing in the Ocean is more difficult than in the Italian sea, where they could see the foils underwater and control them accordingly - B and C race courses are the most shifty. Some days ago during a session wing angle changed by 34º in four seconds - Crew ability can improve boat performances up to 30% - They'll prefer average speed vs top speed - They have some ideas about where they stand against the other challengers, but you don't know for real until you line up in a real race 8 Share this post Link to post Share on other sites
buckdouger 235 #4974 Posted November 23, 2020 11 minutes ago, Zaal said: Just watched an interesting Instagram Live with Max Sirena for GQ Magazine. He talked about the Cup in general and he added something cool: - Every boat creates a "vortex" of air under the bow, an air cushion visible in some pictures / video ( @weta27 @mikenz2 did you ever noticed this ?) - Sailing in the Ocean is more difficult than in the Italian sea, where they could see the foils underwater and control them accordingly - B and C race courses are the most shifty. Some days ago during a session wing angle changed by 34º in four seconds - Crew ability can improve boat performances up to 30% - They'll prefer average speed vs top speed - They have some ideas about where they stand against the other challengers, but you don't know for real until you line up in a real race Thanks for providing these summaries Zaal, much appreciated. 2 Share this post Link to post Share on other sites
Ex-yachtie 1,459 #4975 Posted November 23, 2020 50 minutes ago, nav said: “Our daily pace is changing” Slowing down? Share this post Link to post Share on other sites
Ex-yachtie 1,459 #4976 Posted November 23, 2020 14 minutes ago, Zaal said: - Crew ability can improve boat performances up to 30% I reckon, given the chance, I could reduce it by way more than that. 3 Share this post Link to post Share on other sites
laser 173312 27 #4977 Posted November 23, 2020 32 minutes ago, Zaal said: Just watched an interesting Instagram Live with Max Sirena for GQ Magazine. He talked about the Cup in general and he added something cool: - Every boat creates a "vortex" of air under the bow, an air cushion visible in some pictures / video Yer well a Vortex is a low pressure area, not an air cushion. Max Sirena is not any expert in this area. And yer there are plenty of vids and pics showing spray being lifted by the low pressure areas. It's called the Venturi effect, named after the man that discovered it Giovanni Battista Venturi was also Italian https://en.wikipedia.org/wiki/Giovanni_Battista_Venturi. Like most managers Max Sirena knows Sweet FA about physics. Share this post Link to post Share on other sites
Zaal 313 #4978 Posted November 23, 2020 This time it wasn’t a recorded interview but an Instagram Live. I try to be as accurate as I can in my translations but it’s a lot easier when I can listen again what people say. I used the wrong word, sorry. My mistake, not Max’s. Anyway, thank you Laser ! Really interesting, I watched again videos and pictures and I saw it. 2 Share this post Link to post Share on other sites
Zaal 313 #4979 Posted November 23, 2020 42 minutes ago, Zaal said: This time it wasn’t a recorded interview but an Instagram Live. I try to be as accurate as I can in my translations but it’s a lot easier when I can listen again what people say. I used the wrong word, sorry. My mistake, not Max’s. Anyway, thank you Laser ! Really interesting, I watched again videos and pictures and I saw it. Sorry to quote myself, I’m sure Max talked about ground effect talking about the boat flying so near to the surface, and than he talked about the air cushion created by the bow of all boats 2 Share this post Link to post Share on other sites
laser 173312 27 #4980 Posted November 23, 2020 No worries, and no dig intended. Lost in translation, the bane of science, but possibly the making of humanity? 1 Share this post Link to post Share on other sites
JALhazmat 930 #4981 Posted November 23, 2020 1 hour ago, laser 173312 said: Yer well a Vortex is a low pressure area, not an air cushion. Max Sirena is not any expert in this area. And yer there are plenty of vids and pics showing spray being lifted by the low pressure areas. It's called the Venturi effect, named after the man that discovered it Giovanni Battista Venturi was also Italian https://en.wikipedia.org/wiki/Giovanni_Battista_Venturi. Like most managers Max Sirena knows Sweet FA about physics. And you know sweet FA about wining the cup so I recon he will sleep easy after your stinging criticism. and actually vortex is correct as it describes the rotation of air following interaction with a surface (the bow) the air if of sufficient velocity will tumble and rotate into a spinning vortex, it’s that that is seen lifting water from the surface. go read up on F1 aero and the use of vortices to aid aero performance Share this post Link to post Share on other sites
laser 173312 27 #4982 Posted November 24, 2020 8 hours ago, JALhazmat said: And you know sweet FA about wining the cup so I recon he will sleep easy after your stinging criticism. and actually vortex is correct as it describes the rotation of air following interaction with a surface (the bow) the air if of sufficient velocity will tumble and rotate into a spinning vortex, it’s that that is seen lifting water from the surface. go read up on F1 aero and the use of vortices to aid aero performance Yer I started reading about it in 1978 I can recommend https://r.search.yahoo.com/_ylt=AwrJQ6CLrbxfQ30A5h5LBQx.;_ylu=Y29sbwNpcjIEcG9zAzEEdnRpZAMEc2VjA3Ny/RV=2/RE=1606229516/RO=10/RU=https%3a%2f%2fwww.amazon.co.uk%2fLotus-78-79-Ground-Effect%2fdp%2f1847971431/RK=2/RS=XTC9s2qwNYbaOJQSEq_dt2quJNc- which explains all about the low pressure systems. "air cushion" my ass. Share this post Link to post Share on other sites
JALhazmat 930 #4983 Posted November 24, 2020 Great, then you can see the lack of Side skirts that would affectively Seal the sides creating the pressure differential Between the air flowing under the boat and the surrounding it to make that work on a boat. The Vortex of spinning air is it trips off the hard edge of the keel around the nose area on the boat Is what’s being seen and is 100% not what is being described in the 1978 lotus ground affect link you put up Share this post Link to post Share on other sites
barfy 1,052 #4984 Posted November 24, 2020 14 hours ago, Zaal said: - B and C race courses are the most shifty. Some days ago during a session wing angle changed by 34º in four seconds Brad, do you see any angle where we can drop these tracks off the menu? They give us the shits and Barker will hammer us. 2 Share this post Link to post Share on other sites
laser 173312 27 #4985 Posted November 24, 2020 7 hours ago, JALhazmat said: Great, then you can see the lack of Side skirts that would affectively Seal the sides creating the pressure differential Between the air flowing under the boat and the surrounding it to make that work on a boat. The Vortex of spinning air is it trips off the hard edge of the keel around the nose area on the boat Is what’s being seen and is 100% not what is being described in the 1978 lotus ground affect link you put up It was the phrase "air cushion" that I thought was stupid, Stupid. Share this post Link to post Share on other sites
JALhazmat 930 #4986 Posted November 24, 2020 32 minutes ago, laser 173312 said: It was the phrase "air cushion" that I thought was stupid, Stupid. Na. you recon max knows fuck all and described the wrong phenomena stupid. you ever try describing stuff in a second language? 1 Share this post Link to post Share on other sites
Zaal 313 #4987 Posted November 24, 2020 Just watched again the Max Sirena interview in the GQ IGtv channel. Here what Max says: - Wind shift was 28° in four seconds on B/C course - They have three PLC on-board, and one thousend sensors - They started with 20 knots take off speed, now they are at 16.5 knot - Pitch angle of the boat is balanced with the angle of attack of the foils and "elevator" (the rudder foil) - Sailing windward you want the hull to be as close to the surface as possible (he call this "kissing") creating a ground effect and closing the gap between the hull and the surface, because you need power and righting moment. Sailing downwind instead you have to be a little more high, you want the boat to be as light as you can, and with less wet surface, so arms and rudder stay more out of the water. The boat's trim also change, you are more flat and less pitched down. (edit: here he talks about the vortex you can see in some pictures/videos. "Air cushion" was a phrase of mine) - They have different configuration for every wind condition - Crew can improve the boat performances up to 20/30 % in a single week. Every team will improve a lot during the Prada Cup. - There's an issue with the Defender. ATNZ wants to increase the number of practice day (edit: with the other Challengers? Or alone? Is Max talking about the ACWS or about something new?). Whoever will win the Prada Series will be a serious competitor for the Cup. - Every team has been radical with B2s, not only ETNZ. Making big changes on B2s is risky, they're not always improvements, and if a team change a lot maybe they weren't so happy about B1. - Boats are crucial, but the ability of the crew is essential, and control system are a big part of the overall boat speed. Top speed won't win races, average speed is more important. 4 Share this post Link to post Share on other sites
