oceaneer
Turbo Etchells
Ok flame away..
But in another form I am looking for a good light air PHRF machine.
And Etchells keep coming up for sale in this are for great prices.
So can you turbo it? And what would you do?
I am leaning towards a large Assmy, mast head tacked to the bow fitting for light wind reaching.
(spectra runners when in use)
And a 145% genoa.
I know it will mess up my PHRF rating but where I race the first boat to the new wind wins.
If I could keep the rating 100+ that would be very good.
Ok tell me Im an Idiot now.
Oceaneer
Why would you turbo an Etchell.
Never plane and are plenty quick in light air anyway is set up right.
I club race an old Etchell as well as racing a newer one in one design.
I just take last years regatta sails and put them on the old boat each year.
Just update all the systems adjust the rig and you go fine.
Turboing is for lazy people.
very very light wind, and Im lazy..
In very, very light air you're not going to exceed hull speed even in a semi-displacement/planning boat. The trick is to get TO hull speed in lighter conditions than a stock E-22
replace the skeg rudder with a spade
move forstay up to side stay position and add bigger jib
Add jib inhauls
bow fractional zero
Not much point doing any more.
OK then, so what happens once hull speed is reached ?  Change jibs ?  Tuck in a reef ?  Sail around with the main inside out ?
Savior, we have for the most part light light winds.  This is like any other turbo, IT WILL BE OVERPOWERED in a breeze.
keep pulling the backstay on!
The problems, as I see it (my experience with Etchells is somewhat limited): The genoa will kill your pointing which is really the Etchells strong suite. The masthead spinnaker will threaten to invert/break the mast any time there is actual power in it. Etchells are not really light-air killers in the first place.
They are gorgeous boats and fun (challenging) to sail.
In 1984 one of my customers at horizon sailmakers did the ostar rave in a modified etches. His name was al Fourier and the boat was el torero. He cut the bow off to get it under 30' loa. Did the race in just 30 days. I still have the sailplane for the boat!
That is what reefs and smaller jibs are for.
I can understand the reasoning, i.e. picking up a cheap beater etchells and throwing some more rag on it. But unless you do it right, you will just end up with a lot of broken gear and a boat that you can't sell. And doing it right would be costly enough to make the exercise uneconomical. Would you be better off just getting a beater Melges 24?
4 hours ago, lydia said:
A properly set up Etchell is overpowered in 8 knots.
Dunno where you sail Etchells, but in Eastern Long Island Sound, 10-15 is just right!  Above that, I need help with the guy when trimming the kite downwind, same with the Atlantics.
Stop trying to fix what's already been figured out. The etchells was designed for Long Island Sound which is a sub 8-kts venue. Don't change it. Your PHRF rating will take a massive hit, you won't be able to buy cheap cheap secondhand sails, and you'll probably break your mast.
If this is the case why do people say that they are not light wind machines?
Something is odd here..
It looks like over 15 they are overpowered.
Add jib inhauls
bow fractional zero
There, fixed it for you.
Hmmm. Seems like the spin setup has been done before on an etchells mast
They have not sailed an Etchell maybe, not a well set up one anyway.
Carcrash is right, if your Etchells doesn't look like this when you have finished turbo'ing it,
Then EPIC FAIL...
Etchells don't really reach well anyway so putting a big masthead asym won't add that much speed.  They go up and down really well and they don't like to turn with their little skeg hung rudder.  Get a Soling if you like that kind of open daysailer/racer.  Probably even cheaper than an E22.
Hugh Treharne has turboed a Soling, which he does the twilights here on Pittwater sometimes. Cut away the deck, large roach main, etc.
Hard to say he doesn't know what he's doing, goes like a freight train!!
Ok you have me confused here..
Asmy kites are for reaching.. so how would this not help a Etchells reach?
Etchells are limited by hull speed. An A sail will only make it lean over more and suck up a bigger bow wave unless there is a big swell around.
Asso's don't "help" most displacement boats reach, other than being easier to set and trim. they have a hull speed, and unless you can pop out and plane or surf you don't exceed it, you just go sideways.
you can surf an etchells down waves but you need at least 15 knots and a decent swell, at which point you would have long since gotten rid of the masthead asso, intentionally or otherwise.
Ok its done, I have put a down payment on a Etchells
Now for mods,
I think that the rudder needs to be changed to make any turbo rig work.
Flame away.
Oceaneer
no....  don't get an etchells
get a soling
didn't you see the pictures above
you could probably do a turbo rig for a soling and still be able to revert easily to one design compliant, as it has a deck stepped rig.
the soling with the rack and traps is inspired,  and it already has a rudder that works.
Have to agree on the comments about Etchells rudder probably too small for a serious turbo'd ride.
Congrats
Now you could do an r2ak :D
2etcheĺl have completed the full course  both well sailed. One other etcheĺl DNS.
On 7/19/2017 at 4:54 PM, Wandering Geo said:
Wimps,
Not an etchell, but a few ideas Hughie_on_Gwen.thumb.jpg.a186c7e2ae3ace0921a1bfba86965876.jpgHughie_s_Soling.jpg.5b9e3d32cac4cb7a1541b8989289934e.jpgStart_plus_3.thumb.jpg.73d0d257f3ca447db8822d0b390e71fc.jpg
That's Hugh Treharn's Soling in the Woody Pts.
Ok so we have a kite for the boat from a M24.
Now we need a genoa,  dont think that will be to hard to find.
But the rudder modification, this one has me thinking.
The current rudder post is angled forward at the bottom, to allow it to interface with the skeg. I am not sure if I will be able to add some to the bottom of the current rudder, or just start over.
It would be nice to be able to allow the boat to revert back to OD with out to much trouble..
Thoughts?
Its an old etchells, its never going back to OD. Cut the skeg off and do a proper rudder.
You may have to build a a new custom genoa, with such a wide shroud base unless it is designed to fit, you will never go upwind properly.
Good luck with the project, sounds fun!
8 hours ago, Fleetwood said:
Will need a paint job too.....
or at least a good clean, its been sitting for 4 years.
Our fleet got one donated a year or two ago, a 500 series boat.  It was in the donors driveway, in shrink wrap, for around 13 years, IIRC?  Cleaned up pretty well, with a good powerwashing.  Had a guy in Marblehead also offer us a FREE Etchells, but was not really competitive with some deck core being soft, so nobody wanted it.  Anyone in New England wants an Etchells for free, PM me, and I will find out if it's still available.
I was talking to Hugh some years ago about his Soling, he was playing with a canting keel on the boat. He must have done something to the RM to handle that main.
The San Diego Soling fleet allowed the use of a trapeze back in the '70s. It seemed like a great way to get more people in the fleet and lighter crews to be competitive.  Of course racing out of town required a regular set up and even town, the heavy guys just put a heavy guy on the wire and were still faster.
Don't know, it goes past so quick......
The Mighty Decrepit!  I gave it to a kid who helps me step spars in the spring and runs the gas dock in the summer.  He's having all kinds of fun with it.  I miss her, but Mrs Nettles is enthralled by the decidedly low tech of the catboat.
Glad to hear your Etchells found a good home!  And there is nothing wrong with Catboats.  Mom had a Nonsuch 30 in charter our of Nanny Key, Tortola.  We could usually beat most 35 +/- foot sloops (same waterline) at any point of sail down there.....
So the turbo has started... Lessons so far
1) Masthead kites are fun
2) Steerage is optional
3) We need a bigger jib
4) Damm, there is a lot of string on this boat
We have named the boat Squidzilla.
Oceaneer
Ironic, by spending more money with a budget basement sailmaker for a laminate sail just to look cool you cold have probably gotten a north Dacron sail with a much better shape for the same amount of money.
doubt it... and we have made some shape changes. But have a great day.
An Italian madman called Vasco Donini converted both an Etchellls and a Soling to race IOR.  This was in the late 70s.  One of them rated half ton, and one was a three quarter - I can't remember which.
Seriously deranged - imagine doing a 120 mile offshore in a Mediterranean blow in either of them.  But they did pretty well.
25 minutes ago, swangtang said:
lets see em up in the air flying!
Have you decided anything for the a kite?
Lol...
Yes we have 2 Melges 24 kites, one reacher and a runner...
The boat is really fun with the kite up, not so manoeuvrable, and we have had some very exciting round ups, but hey this is supposed to be fun right??
Just now, oceaneer said:
Lol...
Yes we have 2 Melges 24 kites, one reacher and a runner... They are mast head and tacked to the very tip of the bow. when flying you cannot see anyting to leward.
Maybe you're rounding up because the rudder wasn't designed for the loads imparted by the turbo Hackjob you did.
Next thing you're going to tell us is that you heel a lot more going upwind with the big Genoa and the stock keel.
  • Downvote 5
What's with the hate? He's having fun and experimenting, when he break's something your not paying for it. Is it a good idea no not really, but again HE is having fun.
Lol...
Sounds sweet would love to see some videos when you get a chance.
Turbo rig sounds like fun to me.  Agree with O40, why the trash talking? The guy is not spending your money.
My best friend many years ago put a Star rig on a Fireball hull, of course it exploded but it was fun while it lasted.
Wow.. who pissed in your corn flakes? I hope your day got better from here.
Of course its going to heel more, it has more sail area.. But I dont get why you are so down on this, it was an old etchells, pretty end of life, it was never going to race one design again.  And it was pretty boring to sail in stock configuration in the light winds we have. So whats the problem??
Anyway at least have a great night...
Oceaneer
47 minutes ago, pudge said:
I just threw up.
Why?  Owner stated: "it was an old etchells, pretty end of life, it was never going to race one design again.  And it was pretty boring to sail in stock configuration in the light winds we have."
Would you have preferred they sawzall it up and dust binned it, for scrap value of the metal?
So I notice from club racing results that your Turbo Etchels rates level with the O30 in your club. That's going to be a challenge. That said, the O30 doesn't appear to be properly rated, unless they are  NFS or something.
27 minutes ago, pudge said:
That's an excuse to mod it out beyond repair? I. For one. Would gladly take that and race the shit out of it sans turbo rig, traps and whatever else. There is beauty in appreciating history.
then you should buy one and do it.. lots for sale for cheap. Go for it!
Yes rated NFS, and the O30 is a great boat. Also, the owner is great.
We are deep into figuring out what the Etchells likes and does not like.
Our first 2 races were stock configuration with 0 wind, painful. The small jib was hopeless as the fleet sailed away. Also the old main really did not help.
Last one we sailed was great, more wind, lots of shifts. We made one really stupid tactical call and got stuck in the current. But after that one I am more hopeful.
Reaching with the big masthead assmy is just too much fun.
We will see what the other new sails do next week..
1 hour ago, RKoch said:
Turbo Etchells sounds kind of lame compared to a foiling Star.
yup... wow I am not worthy..
15 hours ago, Ross said:
We're gonna need so many more pictures after a tease like that!
It appeared on my FB feed from Butch Dalrymple-Smith. Only the one pic...not sure if it's a joke or real.
edit: apparently real, and he's building it. Another pic:
We put an Etchells rig in a 1981 Quarter-Tonner and added a full-size (420sqft) A-sail for light air running and reaching in Hong Kong. Great fun, and performed much better than the usual Etchells VMG kite. The A-sail sets off a 3ft piece of scaffolding U-bolted to the foredeck. We put a new sheave in the front of the mast for the halyard, about 2ft below the masthead - reckoned the mast might break when reaching if we put the halyard all the way at the top. The boat weighs about the same as an Etchells.
wow thats is pretty...
Great job.
for upwind, do you use the stock etchells jib,,, or??
Great job.
No. We use the original Etchells jib as our heavy jib. Because the mast bury is about 3ft more on the Quarter Tonner, we had to splice on 3ft to the bottom of the mast (just used another broken Etchells mast as section AND splice) so we made a new jib about 3ft longer on the luff.
Edited by wanchaibelle
The Soverel 27 owner, that  I crew on was talking about using an Etchells mast, for more bendy and controllable rig than the stock mast, for better shaping the mainsail. He said the measurements were quite close. Instead we got an Assym kite off of a ????, and when we tried it, tacked in front of the headstay, and behind the pulpit, it was really fast in light air, and tight angles, so that is the plan for next season.  Soverel 27 is nearly the exact same weight as the Etchells..
Nope, Etchells main for delivery sails.
Are you sure? I guess I mis-remembered!   Hate it when that happens!
EDIT:  Actually, I think I dreamed that!!
3 minutes ago, Rumor & Gossip said:
Toby was going to use it for one of his boats.
Probably for the scaled down version of Matador.
So we finally got the new main.. and wow what a difference.
The boat actually goes in light wind now!!!
So the boat now only needs to point in the right direction, I think you cannot buy that! lol
Oceaneer
