• Announcements
    • Zapata
Kirwan
Volvo MD7 - Combo Starter / Generator issues
My old MD7 runs quite well... once it gets running.
Recently, I had starting problems; swapped batteries, checked the solenoid, first the starter was weak and I could help by pushing the flywheel with my foot to get a start, then it became no-go at the starter (measured voltage at the terminal).  Was able to wrap a rope around the flywheel and get it started (but not after I'd sailed into Benicia, with a very narrow and shallow entrance channel).
The starter is removed, and I'm figuring I'll have to have it rebuilt. I'd appreciate any other troubleshooting or repair ideas.
- It doesn't look like this style starter/generator is used anymore, I've had no luck with a replacement. (they are all car-style now with a bendix/throw out gear). Mine is belt drive - see the photo, the 'dynamo' is above and to the right of the flywheel.
- Anybody have a good rebuilder or shop to recommend in San Diego or SoCal?
Don't know anyone in SoCal, but I bet you could get it rebuilt just fine South of the Border.  And enjoy some great fish tacos while at it.
As long as the windings are OK?  The things that usually wear on those are the commutator, brushes and the bearings.  The commutator can be "cleaned up" several times, new brushes/springs and bearings in the end caps can breathe new life into an old generator.
