• Announcements
    • Zapata
That's how much my keel is offset from true center.  I've measured it several different ways but from the chainplate to the bottom of the keel to the exact same spot, its about 5mm (< 1/4 inch) offset to starboard.  Two questions:
1.  Is that enough to matter or notice from tack to tack?
2.  Assuming Yes to #1, which side should the boat do better on?  Starboard or port?
Just go sailing. Try to forget which side its canted to or it'll drive you nuts.
You you are some type of engineer, right?
Keel offset, or keel not plumb?
Mast in line with keel?
Rudder and keel in the same alignment?
Sounds like your talking out of plumb.
 have you considered that the chainplates are assymetric?
  It's only important that the keel lines up w the rudder and mast.
don't worry, the Coriolis effect will take care of that  ;-)
On the moore, that were built 2" wider on the port side. We line the mast up with the keel. We can find any notable difference tack to tack.
Unless you are a champion level competitor this will not make a damn bit of difference.  Are you in the top 5 in regattas regularly? If so modify the boat. If you are not a stud then worry about other things on your boat like sail trim, tactics, and understanding current and weather patterns.
And here's me wondering what discussion of your new gun in a weird caliber was doing over here rather than in GA...
That is a very difficult measurement.  I would be surprised if the measurement error was smaller than 5mm.  The biggest problem is deciding what the reference is and knowing that whatever you pick as the reference is in fact worthy of being the reference.  Perhaps your keel in perfect and your reference is off 5mm.  It will drive you crazy.  I went through this because my wood mast was not straight as the opening in the cabin top was an inch off to one side.  The general advice was so align the mast with the keel.  In the end I said no more measurements.  Put the mast over the center of the mast step and center the top between the chainplates and forget about anything else. The mast guy said some Santa Cruz boats have the mast step off to the side 2 inches.  What you really need to do is decide what you are trying to accomplish and then do that without worrying about 1/4 inch.
Do mean the entire keel is moved 5mm over, it is twisted 5mm out of line, it doesn't go straight down, or ????
I remember measuring a Hunter 54 and finding out the cabin was 1/2" off center for some reason :rolleyes:
ditto...
My boat was 1 inch higher on the port side than the starboard side.  To put that in perspective, that is like moving 50 pounds from one side of the boat to the other.
Boat builder are lucky to get it to the nearest mark on a tape measure with a number, That is if they use one.
The guy that built your boat is still talking about the boat that he built that was only 5 mm off.
It's a good thing these bloody boats aren't designed to fly.  Sometimes I'm shocked they even float.
I'm amazed an American knows what metric is..... well done.
1 Which chain plates?
2 How do you know your chain plates are installed evenly?
3 How big is your boat?
Sounds like too small of a discrepancy to be considered.
5 minutes ago, Snaggletooth said:
Thet smackes of arrogence...... you weeney!
Well the next time you go to Home Depot, ask for metric Robertson screw driver........   :o
ok maybe not....
ok maybe not....
Hoser.
:lol:
ok maybe not....
I dointe go to teh Depot, do realle hardware storres carrey them to?  I'lle checke them outte.
Canadian Tire will ship them to you. Make sure you order them before NAFTA is summarily cancelled by Royal Proclamation.
Damn, where am I going to get my metric Crescent Wrench?!
By placing the beer cooler to the starboard side equalibrium will be achieved.
Counterintuitive inn'it
You can find airplanes out of rig too and by more than 5mm. We had one that would NOT fly straight and it drove me nuts. I bent the rudder trim tab until it didn't turn, but it flew slightly sideways which sucked in IMC.
(a good rigger that gets the wings lined up exactly and the control surfaces set exactly with no slack in the cables can gain you a few knots)
You can modify a standard wrench, but it takes some time to adjust. A little more complicated than recalibrating a metric hammer.
Lots of answers to the op .
1. As stated above there are generally many ways a production sailboat is asymmetric.  ( your boat could be an inch more "round" on one side than the other in any of a number of measuring stations. One side could easily be 5mm taller. )
 2. Assembly of molded decks to molded hulls at production plants is amazingly inconsistent. ( The deck bedding material could have been hardening on one side before the fasteners were drawn down. The deck could be off to one side. The deck could be crooked. The hull side could have sagged out or be drawn in too much. )
i could on but it would  be silly.  You took one measurement and it may or may not even hVe any significance. Are they precision Laser measurements made with an accurate machine or are Trey measurements made with a hunk of nylon twine you stretched around the hull and ten measured by pacing off the two lengths?
Summary?? I don't give a flying fuck about this question and only answered it so I could stay awake while my dogs, who insisted on going outside at 3 am, relieved themselves.
Have I missed it or do we still not know what kind of boat this whole thread is about. Are we talking about a racing dinghy or a 40 ft cruiser here?
21 hours ago, Gouvernail said:
What is Jeff?
Your deity to worship and give praise* to.
* Send praise in the form of cash or money orders only.
Hey, I've gone fully metric.  And prefer the shit out of it to fractions and other stupid measurements.
I figured, you would know exactly what 9 mm is for........:)
:lol:
Bloody spot on!
Try taking a few diagonal check measurements, port & Stbd in the same areas, note them down, study......and then drink!
You may feel better after that.
Jim B)
How many ten thousandths is it out of line? Have you checked it with an electron microscope? Done the quantum entanglement calculations to determine how many molecules it is off?
