• Announcements
    • Zapata
Training Wheels
Firefly Oasis G31 Charging Questions, Help Please!
I finally got 3 Firefly batteries, and have them installed. They specify 14.4V bulk and 13.4V float voltages. My solar controllers don't do that. It can do lead acid: 14.25V/13.25V, traction: 14.45V/13.25V, AGM: 14.25V/13.8V. Which would be best? I'm thinking the lead acid setting, as we're headed south so will be in warmer temperatures. Thank you for your expertise!
Best to check with the manufacturer. Failing that, I think your best going with traction as it seems closest to the recommended voltage. If these function similarly  to AGM type batteries they will never get fully charged unless they get to max acceptance . If you want a really well designed controller, check out Genasun: https://genasun.com/all-products/solar.../for.../gv-10-pb-10a-solar-charge-controller/  \
They may be able to custom build you a  controller for these batteries if needed.
The set points for Firefly's more closely resemble Gel and I assume could be easilly and similiarly damaged if too high. For 10 degrees C increase in temp from say 30-40 degrees the setpoint needs to drop around 0.25v so all but the AGM setting should work well with maybe switching bulk setpoint down from 14.45v traction to 14.25v FLA setting when ambient temperature is up.
If you ever need to change MPPT controllers Victron make a programmable one that works well.
Thanks, sounds like I'm on track. We're headed to Mexico soon, so the temperature will be up. Unfortunately my controllers are relatively new. I've got the Mastervolt SCM 25's. Got a really good deal on them, thought they'd be good, now not so sure.....
