George Hackett
Adhesive Recommendations
what strength is desired (what's the application?).  Why not a compatible two part resin & hardener based on what the deck is made from (epoxy, vinyl ester, etc.)?  You need to properly prepare it for bonding (e.g. sand and clean to expose the base material).
epoxy with high strength additive from WEST- it what I use for critical bonding of hardware, but, you need clamping pressure of some sort until it's cured.
Rubber toughened epoxy adhesive is sort of a generic term for what you want. Avoid peel in glued joints. Direct tension is good.
I plan to use Ropeye padeyes for tweakers and block anchoring points. And a bunch have been used in the stern as tie down points. And these were not through deck, rather glued on deck. And they hold real well. But the guys at the boat yard are tight lipped on what they used.
the stick on loops are only good to 500 KG max working load  Ropeye recommends sikaflex or spadbond.  For use for tie downs and inside cabin not for rigging loads
If you use them for tweakers and anchoring points, they can be under pretty strong tension .  On my J/109 I installed Wichard folding padeyes through deck bolted  near the rail to use for tweakers.  When using the Code zero they see a pretty significant load I wouldn't want to trust to something just surface bonded.  The Ropeyes are pretty cool from looking at their catalog.  You could use the through deck type for those that see significant loads as shown in their catalog, which also provides the recommended bonding technique the Overboard provided.  That is one nice looking boat!
9 hours ago, George Hackett said:
Thanks WHK. She is a Mills43. I have ordered the through deck pad eyes setup. When finished, I will post some photos.
I've used self-made rope-eye bonded eyes on the interior before, mostly for securing items (spare liferaft, ditch kit, storm sails) and hard points for pipe berths. Bonded with Plexus, thickened West System or G-Flex. Worked very well but surface prep is critical.
HW
No offense but tweakers on a J/109?  That's what the boom is for.
You obviously have never flown a code zero on a J/109......
