Airheader
J22 bottom & keel refinishing questions
I recently bought a j22 that is in pretty good shape.  Has what appears to be vc offshore that needs to be redone.  I have sanded everything to the  gelcoat but the bottom couple inches of the keel.  does not appear to be any barrier coat  presently. Plan on applying barrier coat and vc offshore by roller.   I have a coupe of questions if anyone can shed any light.
1. Is it safe to jack the boat up using the 6 point adjustable trailer pads to elevate the hull enough to get the keel  base above the trailers track to sand and refinish the bottom couple of inches? Looks line the easiest solution but not sure if the hull can take tge pressure or just deform .
2. Anyone know how much interlux 2000e is required for a  proper job on a j-22.
Thanks
I've raised the hull on the jacks with no ill effects, go slow and teeter totter it up keeping weight on as many pads as possible. I found it was still hard to work on the bottom of the keel but doable. Have no idea how much paint is needed.
Ive done this but always keep the weight on the keel use a block like 6x6 and move it to the front of keel then move it back work in sections
Thanks for the responses.  I will try jacking it with the trailer pad jacks and then lower onto a block to take the weight off the pads so it doesn't hand there too long
Agreed with the above. 1 gallon kit will suffice though the directions call for more. I've done two J22s with the one gallon kit, each.  You can jack up the boat on the pads. It's how a company like Waterline Systems would have done the bottom job on your boat, on poppets, though actually they would also hang it by the lift point. It wouldn't be a bad ideal to put the block under the keel between work sessions.
 How much barrier coat absolutely depends on how long you're going to leave the boat in the water and what the temperature of the water will be .
      If you plan on using the 2000 epoxy as a bit of a filler so that you can do a bit of fairing  on your biat, certainly you need a whole lot more epoxy that if all you're going to do is try to change the color of the boat .
     In my shop,  if we are attempting to create a barrier coat, we put on about 4 gallons of 2000 on a J-22 or we don't bother to put on any at all.
 We always tell our customers that they need to pull their J boats out of the water for at least a couple weeks during the hottest part of the summer to have any hope whatsoever of allowing the barrier coat to protect the boat
We have never successfully prevented a wet sailed J22 from blistering.  We have applied as much as 8 gallons of 2000 epoxy over 2 gallons of 1000 epoxy and the boat blistered anyway . I don't think it's possible to prevent blistering on A balsa core polyester boat bottom that lives for years at a time in water that gets to 86° in the summer.
I am certain it is less expensive including the cost of the hydrohoist  to maintain a boat that lives on one.
if you're going to put VC offshore over 2000 epoxy you need to wait at least a day before applying the VC offshore or it will crack like dried out mud
it is possible to spray on a particularly fine mist of the VC  offshore a few hours after applying the 2000 epoxy but if you can't see through the VC Offshore it will crack
Well, I am in PEI so the water temperature never hits 86F. I expect our summer water temperature would get to 70's max. We have our boats in for about 4 months June to September so I would think we are at much lower risk of blistering than southern boats in all year or for a long season ?
Absolutely . VC 17 over bare gelcoat may be adequate. Perhaps VC Offshore or Petit's new Black Widow
We are colder yet. Don't skip the 2000. As gouv says, fair the bottom with it. Use lots then top coat with VC whatever. Jboats blister regardless of temp.
Ôû
Our J22s are in for six months, never hauled, fresh water, temps in the upper sixties to low seventies and we've never had a blister.  Conditions are a major factor, especially warm water, but I put the barrier coat on to protect against blisters and to work as a better binder for the bottom paint, it's working just fine.
A couple of thoughts:
Jacking her up on the trailer pads will work.  I would not be walking around on the deck while it is jacked up.  Put a bunch of blocks under the keel, and lower it back down when you are not working.
If you need to do a lot of work on the bottom of the keel, stick some styrofoam on top of the pads-- the extra few inches will be a big help.
If you are rolling the barrier coat on,  you will end up sanding a lot off.  Even if you aren't going crazy fairing. I would use at least 2 gallons.
Don't wait too long until you sand.  Interprotect gets very hard after 24 hours or so.  Your arms and shoulders will thank you if you sand as soon as you can.  If the paint is clogging up the paper, it is too soon. but as soon as that stops happening..... go for it.  Not the worst idea to paint a hunk of plywood at the same time... use it to check if it is good to sand
Gouv,
What do you think of Black Widow?
1 hour ago, j34035 said:
Gouv,
I have my first gallon unopened on my shelf.
the owner of the boat for whom I thought I bought it decided he wanted blue.
So.... all I have is the opinions of others in places like this forum
Well i bought the vc offshore so that is what will go on.
I  bought a couple of old krebs 35T electric paint sprayers ( never used)from ebay as  I have read on a couple boat  forums that they work well for applying 2000e and the vc offshore.
Hoping they will reduce sanding. Weather here is still 0C so still a couple of weeks away from starting. If anyone ever tried the krebs sprayers would love to hear any pointers. My spraying experience has only been with air syphon guns  and car paint
Can anyone advise how much vc offshore is needed for a j22. I only bought 1 gal and thinking it probably will not be enough to put the recommended 3 coats
A gallon of VC Offshore on a J-22 is a HUGE amount.
That shoujd be enough to burnish to perfection without  going through.
Thanks Gouvernail . I Have 3 coats of 2000e on now one or two to go.
 One other question if you don't mind.
For the sanding prior to the vc offshore is this usually done with a power sander  or should this be hand sanded. Not that keen on hand sanding at this point so am thinking the R.O. is the way to go and just be careful not to go too far
We like to use both white and gray 2000 and alternate between coats.
When sanding it seems like we remove a ton of material but, even if we roll on the (usually about eight)  coats  of epoxy:
  we do not  sand away the entire last layer
we only go through the next  layer in a few places (and those are almost always high spots we knew about )
if there are known low areas we like to apply extra layers in those areas
if we are rolling, we smear a layer on low areas using a wide putty knife  then go back to rolling
generally we grab a DA and sand 2000 with 120 or 80 before adding antifoulant. It it sorta  important that the antifoulant sticks
Note.... you MUST wait at Jesse a day before applying VC OFFSHORE over 2000. The VC will attack tge 2000 just a Little then dry rapidly and leave a surface that looks like parched soil in acnajir drought.... and the grooves are nearly impossible to fix.
you can apply a thin very smooth coat of 2000 over your sanded surface and spray a VERY FINE mist of VC over that to guarantee fabulous adhesion but:
if you can’t see through that misted on paint it will crack and screw the  entire job.
i have never had VC Offshore peel from a sanded surface so we don’t do the misting stunt anymore
I finished spraying on 5 coats of 2000e with the alternating colors . Used 2.75 gal. Have a few runs that will be sanded out. Planning on sanding with the 6in bosch sander using 100 grit.  I did a test and It seems to level things quite easily.
due to work commitments It will be about 48 hrs after the last coat of 2000e before the first coat of vc offshore. Plan on 3 coats of vc
What's the weight on a 200e/vc offshore bottom job wind up at?
Looks like plenty have done this at home/on their own - but I can't say I've gone after a project this big before. Local boat work guy made it sound like I couldn't trust anyone in town to tackle this right, and got me all freaked out. Is this something a reasonably careful person could do carefully? The $5000 i was quoted isn't appetizing.
