Bruce T. Shark
Flicker Construction
Gonna put a flicker on the boat this year, as a trial, since the backstay is synthetic and has a heat shrunk UV cover I want to use a rolling block, anyone know a source?  Would like the block/padeye to bolt to the flicker.
I wonder if one could just put a dyneema bight through a hole in the flicker and then tie a knot in the two loose ends so it can't pull back out.  Would dyneema chafe the backstay?
what happened to attaching a block to a length of 'glass batten? who knew backstay flickers had become a prebuilt system to be purchased not a home made mod...
After cutting my hands to shreds on an old UV-degraded batten flicker while trying to reattach a block to it, the new powdered coated flicker I got from North for $20 or $30 was the best money spent on the boat!  I'm pretty sure the little Harken block from West Marine cost more...
Get your binoculars and look at Diablo's set up...RBS flicker and harken block but we'll replace the block with a low friction ring this winter.
Cheers, Greg
Nice. Hate those fine fiberglass slivers
Please sign in to comment
You will be able to leave a comment after signing in
