• Announcements
    • Zapata
dogedog
Removing hard scale on gelcoat
Time to tackle the scale build up from hard lake water that’s around the A/C through hulls and gelcoat. Tried CLR and similar products w no change. Heard about vinegar -anything else?
I don't know if it's even available anymore but we used to use Tang - the orange drink crystals - to clean the deposits out of our dishwasher in the Okanagan. Very hard water and it worked great - we'd just run it empty with the Tang in the soap dispenser about once a year.
I imagine any citric acid substance or cleaner would do the same.
Muriatic acid from a swimming pool supply store will clean this right up too. Note, add the acid to the water to dilute to the proper strength...not the other way around.
Yes acid, but not Muriatic. Phosphoric acid or something sold for ceramic tile cleanup. Muriatic forms problematic chloride compounds that tend to be insoluble or very bad for metal fittings....especially bad for stainless.
Would vinegar work? I've used it on everything that gets crusted up around our house. I use it on the vehicles when the hose water dries leaving hard spots on the glass. Kind of reluctant to try it on the paint...
I've used Barkeepers Friend on the boat for stainless and stubborn stains on the deck. Haven't had to deal with any issues on the topsides yet. They do show it being used on Fiberglass Bathroom fixtures. Three kinds, Spray, cleanser and Soft Cleanser. Here is a link to their website: https://www.barkeepersfriend.com/
"The Works" Toilet Bowl Cleaner. Spray it off with water after wiping it on. Use gloves, eye protection etc. Dilute hydrochloric acid (aka muriatic acid) is main ingredient. About $1.78 at Home Depot
+1 brown or yellow waterline  stains are gone using this stuff fast. The works bowl cleaner not as good..
White vinegar works for rust and some deposits depends we also use baking soda (kitchen calcium carbonate) +wetted hard brush+elbow grease and works.
Clorox Clean-Up works really well on grime, rust & scum lines - way better than diluted bleach so apparently there are some secret ingredients.
Just spritz it on and leave it. A real miracle product.
Full disclosure - I've never tried it on deposits.
We go through gallons and gallons of muriatic. The lake is in a limestone valley in an old ocean bottom.
muriatic is diluted hydrochloride acid.
We use fuzzy bowl cleaning wands that look like a bunny tail on a stick. Most any janitorial supply has them for a buck or two apiece
stand upwind .( it is really onvious if you are downwind as the fumes will cause an instant gag reflex.)
we pour some in a small bucket ( kiddie beach sand buckets work great) we hold the handle above the bunny tail at all times.
we try to catch the drops in the bucket ( this translates to both shoulders burning in just a few minutes and therefore giving an excuse to rest)
we gently and repeatedly "paint" the acid on the deposits and watch the deposits bubble away like magic. When the bubbling stops, you know the deposit is gone.
DO NOT LET THE ACID DRIP ON A GALVANIZED TRAILER... it makes nasty spots
rinse , rinse rinse .... maybe even use some detergent to finish the rinsing.
A couple minutes of contact with stsinjess steel doesnt do anything to the stainless. We acid wash lower pintles and gudgeons all the time.
Bronze fittings turn pink on the surface.
Certainly there is a bit of damage to that bronze but  it is nothing compared to bumping that same surface with a sanding disc.
Gloves?? Not just no but hell no!! You WILL get occasional bits of the mild Muriatic acid on your hands.
As you are not a total dumbass, you will immediately rinse it off and do no harm to your skin.
if you wear gloves, you WILL dribble some inside the cuffs and even siak your whole hand and,  an hour later, when you finally remove the gloves you will see your yellowed skin. It will heal in a couple days but if you hadn't had the gloves giving you a false sense of security you would have kept the acid off yourself.
A good hose that is always ready and within reach is something only a damned fool idiot would be without.
