Kiwi Sailor in Europe
Seascape 18 outboard
Try the Honda 2.3hp 4 stroke air cooled short shaft. 12.7kg. A bit noisier than water cooled but saves the bother of having to flush it through with fresh water after use.
I use a 2 stroke 4 hp on the 24. It’s enough so 2 hp should be enough for the 18. They are noisier but we don’t use them much, do we?
Honda 2.3 is VERY reliable and simple. They have engineered-out many things that can cause trouble - no cooling system, no transmission, no gas mixing. Yes, they are a BIT noisy but remember it is really a small lawnmower power plant with a propeller. Happy Sailing
Very good motor.  The largest issue, which likely applies to most small outboards, is NEVER use fuel with ethanol.  The ethanol gums up the carb and makes your life a misery.  One season I cleaned the carb extensively and had good results.  The next season, I bought a new one it's run great ever since.  Very little maintenance.  The air cooling is a plus: easy to work on outside of the water, I can warm it up prior to launching, etc..  Others will likely disagree, but I'm not a huge fan of the centrifugal clutch.  Most of my issues stem back to when the carb was gummed with ethanol and the clutch would engage while I was trying to keep the damn thing running.
My Honda 2hp bought new in 2006 has never had ethanol free gas and still runs great, starting with one pull every time. But I do always use fresh gas (2 months or less old) to which I always add sta-bil fuel stabilizer. Downside with the motor are, like other 4 strokes, can only be laid down on one side, it's noisy and the top part of the shaft, right where your hand wants to grab it when stowing it below, can get quite hot. It's also extremely hard to change the oil without making a mess and the cover is not really suitable for lifting it. On the plus side, it's realible, lightweight (for a 4 stroke) and has a very conveniently located screw for draining the carb when storing it for extended. Never regretted buying it.
On 13/11/2017 at 7:56 PM, Kiwi Sailor in Europe said:
Hi there, thinking about changing my Torqueedo 1003 to a small petrol outboard for a Seacsape 18, preferably 2 stroke as it is lighter, but open to suggestions.
Has anyone had experience with a 2 or 3hp unit?
Thx.
Hey kiwi sailor,
if I was going to get a outboard I’d go for a 2 stroke as they are simpler motors for what you are looking for.
The Mercury/Mariner/Tohatsu  2.2-3.3hp are the same motor. The difference between the 2.2 and the 3.3 is a fuel restriction plate in the carburettor. Same weight. Inbuilt fuel tank and the 3.3 has forward neutral / gears and about 15 kgs
If you feel you can handle more weight in the motor about 21 kgs I’d go for the Mercury/ Mariner / Tohatsu 4 - 5 hp outboard. Again it’s the fuel restriction plate in the carburettor that is the main difference in the motors for the same weight. The bonus with the 5 hp motor is it’s fitted with a inbuilt tank as well as a remote tank option. This is great if you want to go cruising or are doing a longer race we’re you may need to top up the fuel tank.
Pulpit
have a Merc 2.5 for 10yrs runs great even at low speed for hrs on end just have to clean the plug, and yes only use Shell Gold gas = 0 ethanol
Br
I've owned all those engines- here is my 2 cents
The Honda is nice light engine- I had two things I didn't like-  very loud compared to others and didn't like the centrifugal clutch. When you start the engine cold it has to rev to warm up and that means the clutch will engage. I had to always start with the boat tied to the dock until I could idle the motor
The Tohatsu 3.5 - good engine- no complaints- quite a bit bigger and heavier with more power- comes in handy if you have to motor a ways against a 20 kt wind.
The Torqueedo-  loved that I could easily take it off after sails were up and store below.  Not enough power to motor against big wind and once you are out of juice no easy way to refill. But to get in/out of marina in normal wind worked really well. My battery has died now after 5 years and  will cost me $1000 to replace
Yamaha-  IMHO the best in quality of these. I have the 2.5 and the 4 HP models. Great, reliable, strong motors. A little heavier than the others but due to beefier construction. The latest 2.5 model allows you to lay the motor down on either side without oil issues.
I use ethanol free gas and run the carb dry after each use to avoid carb cleaning duty
Long time follower but here finally some input also..
Have Seascape 18 with 5 summers experience. Have 4hp Yamaha and that is lot of power for this boat. Had to change to lower pitch propeller from standard and still with very light throttle boat reaches very quickly 6 knots.
Issue is that even with lower pitch propeller I end up throthling when coming to pier - not very convenient but managable.
I have been thinking about switching to Torqeedo as range hasn’t really been issue in current use. With extra battery I believe I would get performance I need, but investment is high for very little use..
Seconded for the Yamaha 2.5.  I have a 2006 model.  Good little motor and I've had no issues other than someone mistaking the choke for the pull starter...
Congrats on the Seascape 18, looks like a lot of fun.
Another vote for the Honda.  Starting in gear was never an issue for me, and that was with a 65#, 10' RIB.  And it's only with a completely cold start.  Once warmed up, the engine will start at idle - out of gear - and tick over quietly.  It's amazing how many people never figure this out.
Also, I never bothered with non-ethanol gas, and never had a problem.  Maybe Honda's carbs aren't as finicky as Tohatsu's.
Enjoy your Seascape, it looks like a really fun boat!
I also had the Mercury / Tohatsu 3.5 HP on my SSC 18. Was nice to have some extra power in some conditions. Still only 19kg and Tohatsu also offered a sailing propeller for lower boat speeds.
Depends on your sailing area. Less might work out fine for you, more than 3.5 HP would probably be too big and too heavy.
I chose against electric engines since they seemed to be more like toys and you can not leave them attached permanently on the boat. But might also work on a small lake and if you don't care stowing it away every time. Pro electric is definitely the silence while running under engine.
The 3.5hp Mercury is a very good engine for the SSC18, but it’s a bit heavy to move. If you like to have a more mobile engine, the 2.5hp Honda or Torqueedo 1003 are good options. The 1003 in particular is easy to install/remove as it’s done in parts rather than as an assembly where each piece is easy to move and store.
(This is from U20 experience) The small gas engines get stolen- kind of like bicycles, so if you leave one on the boat in public, or in dry storage, or locked dry storage, even with a chain or more industrial restraint, it will be stolen. We had one Yamaha, 2 Hondas, and a Nissan stolen over the space of 6 years.  Shilshole Marina dry storage.
30 lbs is heavy after a frisky day of sailing, especially if you have to put it in the car with stinking things up, and then put it in the garage.  But if you're trailering the boat all the time, that's no big thing.  Make sure the Honda gas caps float.  The little chain they use to keep the cap from falling fails early and often.  The caps used to sink, at any rate.
We have a Torqeedo now, and agree completely with Svein- the way it comes apart into 3 light pieces and stows in a small spaces is worth the extra dough.  We have an extra battery, and the roll up solar cell blanky.
I wonder if an electric trolling motor might work for less $$$-  the batteries can be smaller, too, and secured remotely with a power cable to the engine.
One big plus for the Seascape 18 is a large lockable cabin where you can keep all your gear. Also big enough for cruising - several have done extended cruising as well as the R2AK.
