Mr. Squirrel
Understanding Tidal Flow - Biscayne Bay
HELP!
This fresh water sailor is going to be spending a fair amount of time in Miami this winter and I am struggling to understand tidal flow on Biscayne Bay.  I found numerous tide charts, but I can not find anywhere that shows tidal flow direction.  I understand it is a bay so water flows in to the bay during flood tide and out of the bay during ebb tide.  My problem is the "bay" is actually open to the North, South, and East.  So the question is: during Flood tide is the water flowing North to South, South to North, East to West, or some combination of the three?
In other news, we are doing J/22 Worlds next year at Annapolis Yacht Club, so if you have suggested resources for the Severn/Chesapeake that is appreciated as well
Thanks in advance
MS
Dude, he's asking for data in a very general way, so I gave a very general answer.
Note that the CMAP cartridges have current vectors, presumably the PC programs do as well.
A reasonably astute individual can take the tabular predictions and figure out the deltas and derive the basic direction of the flow.
More precise question of where to position vs state of tide requires either detailed current maps which I did not locate or as noted in the CMAP the calculation and prediction of currents based on a model.
Assuming a J/22, the idea of a chart plotter is probably a stretch, but reviewing the CMAP PC data might be a good plan.
My experience (3 years of doing mark set / pin boat at SWC Miami) is that the tidal flows are relatively slow in the race areas inside the northern part of the bay.  (The tides are only about 30 inches.)  The depth is uniformly shallow, so what current there is is fairly uniform.
Do what the big boys do, though - no sooner than we had a mark in the water, there would be a gaggle of coaches by it, dropping current sticks in.
It's comparable to Lk. St. Clair around GPYC.  Something you might have to account for when judging a lay line, but nowhere to escape it.  Everyone is on the moving carpet.
No kidding, but it’s a resource. He can use as he sees fit. Trying to help somebody who seems challenged to find even basics
For max semi uniform currents of less than a knot, I’d probably not worry, we sail in very divergent slows on SFBay with 1 kt differences across 100 yards.
Do those regions have tide atlases?  The ones for Puget Sound and the Strait of Georgia are really helpful to me.  They show a lot more detail than you can get with a few NOAA current vectors.  I attached one as a sample (this the south end of Vashon on a large flood).
For buoy racing I agree that it is even better to watch the tides effect on buoys.
The bay is not like rivers and other freshwater estuaries and bays that are confined by land masses. Pretty consistent 10’depth and not much tidal flow. You won’t have to throw an anchor at slack tide to keep from sailing in reverse in a 10 knot tide like Jenn and the Samoan lady did in the Devil’s Triangle.
Excellent question : one I'll need the answer to in the coming weeks. No idea why it is so difficult to find local flow charts and, no, the local boys don't always have the answer either!  Problem is there are fresh-water currents, weird underwater configurations, and no detailed current charts. Mapping the sequence of high-tide times doesn't work to indicate flow (anyone know why?). So good luck! All you can do is watch the moss on channel markers and buoy lines as you go out to the line. Ignore snarky answers to your questions. And keep out of my wind!
well wind is the other biggie in the bay
as noted the bay is open to flow on three sides sorta but mostly east west in mid south bay where the races are
north with the beach strip to key Biscayne is more north south except right by the inlets
and Eliot blocks the south end the same way
so wind can help or fight tides and currents esp long winter winds
but most races are mid bay with little current with no real flow obstructions or effects
unless very near the end of Biscayne channel and flats finger channels where there is a bit of funnel effects
but they seldom go that far out
the tides/currents are worse  rowing out to an anchored boat near dinner key spoil islands
then out in mid bay
Are those on line or paper?
The Canadian Atlas is paper only.
The Puget Sound atlas can be found online.  The better quality scans are for sale (but cheaply) at Starpath.com, and come in an encrypted PDF that works well on my iPad and phone.  Here are the free ones: http://nsgl.gso.uri.edu/washu/washuc77001/washuc77001index.html
The scan above came from the paid PDF version at starpath.com: http://starpath.com/catalog/books/1986.htm
It has two different sources in the same book, with slightly different renderings.  It's helpful to have, and I've also used it on more than a couple of very light wind races with good luck.
