• Announcements
    • Zapata
Bearley
Tasar Specs
Hello,
Can someone provide the (rough) dimensions of a Tasar centerboard and rudder? I'm thinking height, width, and depth (thickness).
Thanks
I have one--next time i go to my storage facility I will try to remember to take measurements . Are you planning to  build your own?
Hi Ed,
Yes, I'm planing to build both the centerboard and rudder from layers of high-density plywood. I adopted a '95 Tasar....literally the hull only. I'm hoping to put some kind of mutt sailboat together. Purist I'm not, nor do I have unlimited funds, so we'll see what happens.
Bob
Bearly - I suggest you see if you can buy that daggerboard from Edward M. Tasars are great boats, and one of the reasons is the foils design and shape. Shaving a hunk of plywood is less than ideal. And don't try to make your own sails either...
re: Tasar daggerboard--  Sorry for the ambiguity---when I said I have one--I meant I have a Tasar (complete). I could'nt sell sell my daggerboard even if Bearly wanted it because then I would have to build one  to replace it -and I'd rather not. Bearley you have a gigantic task ahead of you to turn that hull into a usuable sailboat. I understand that your're not a purist (neither am I ) but I hope you're not going to be disapointed in the result.The building of a reasonably functional daggerboard and rudder while not easy, can be done--but that is the least of your problems.The mast, sails and rigging are, in my experience, the majority of the cost in a sailboat. If you purchase those items youre going to find you could have purchased a good used boat--( not necessarily a tasar) for less money. I've cobbled boats together out of various parts several times and I have  been most sucessful when I have an intact rig (mast, boom and sails) even if I had to build the entire hull itself. I would say if you have just the hull you have about 5% of a sailboat.
I'm also putting, or rather trying to put a Tasar together myself. Between having to get new sails and bunches of rigging bits, all spendy because class specific hardware just IS that way, it's another fucking sailboat money pit.
I SHOULD have known better but I'm not too bright when it comes to boats. It should be a fun little boat when it's finished. If I ever finish.
Tune in to the next exciting episode of Stupid Is As Stupid Does.
Thanks for all the warnings and other suggestions.
Ed, if you could just send along the height and width of the dagger-board blade, and rudder,  I'll be good to go. I do have the thicknesses of both. I also have a pattern for a NACA foil that I intend to use. Thanks for your help.
Bob
Hey Bearley--Just got back from my storage facility (had to do a batten pocket repair) and I have your measurements: Rudder--from the bottom of the blade to the top of the rudder head is 37 & 3/8". Width of rudder at the waterline is 7 & 7/8 tapering down to 6 & 1/2 at the bottom. Daggerboard: total length is 52 & 13/16".Width is 11 & 1/4 at the top tapering down to 6 & 1/12" at the bottom. If you have time, I would be interested if you could post photos of the finished product. Good luck with your project and if I can help in any other way  just let me Know.
Ed
Hey Ed,
Thanks very much for doing that - I really appreciate it. I will definitely post pics of the finished products (maybe some in-progress ones, too).
Thanks again,
Bob
Just realized you're in Manchester NH.  I'm in Spofford NH. Since I've got so much work to do on my Tasar I won't be using my blades for a bit. Wanna borrow them to use as precise templates? If you SWEAR to return them promptly. I hate lending stuff out and then having to chase it later. Let me know.
Hi RB,
Thanks for the offer. How about If I bring some cardboard and trace them at your place? Then you won't have to worry, and I'll save a second two-hour round trip?
If OK, what's your schedule like?
Bob
