• Announcements
    • Zapata
zzarganas
Homemade small tri
I find this today and i really like it. It's a neat small tri that looks fast and fun to sail and camping. There are 2 videos one of the build and ine of the sailing. Enjoy.
Too much work! Buy a used Pulse 600. Spend your time sailing - not building. Happy Sailing.
  • Downvote 1
I think you are being unfair to the builders out there.  Like any craftsman/artist, the joy is in the creation.  It is a different joy than that of mastery over wind and seas.
Nice boat. Well done, and at a fraction of the price of a Pulse I would think.
a second hand pulse cost you 34000 euro
http://www.annoncesbateau.com/voilier/occasion-annonce-706018.html
I think you can build this in one or two year for much less than that.
O.K. you obviously suffered a brain stroke cause  i can't explain how the hell you could make this idiotic comment.
If one want to build boat - starting with a small project like this makes a lot of sense - that can be done by an amateur in home-facilities.
Building a 30+ft multi is a major job that should be left to pros or semi-pros.
Nice and fun boat that one.
Looking around for simple, economic, homebuilder multihulls - one overlooked designer is Gary Dierking.
He has an especially attractive design, Va'a Motu, that has the option to be built as a double outrigger (trimaran)  -- very nice, great sailing boat (see his videos).
Found at http://homepages.paradise.net.nz/garyd/vaa_motu.html
That's my boat. I started her way before corsair did the pulse. At the time my options were a Tramp or TT. For around 20% the cost of a pulse I think It was worth it. As for time involved, well the difference between an ordeal and an adventure is only your frame of mind!
hi three bags, have you got any more details/specs or build info on your boat? I think it is tremendous.
It looks like it is shifting along very nicely.
She a Franken-tri made from a nacra 5.8,a cobra cat with a F18  Main sail and cobra jib. No down wind sails yet. The nacra hull was cut down the centre and widened by 150mm at the transom. The halves where canted out slightly. The shear raised by 100mm The cobra hulls (3mm ply)were wrapped in carbon the boards removed and bows modernised. All up she weighs around 250kg. Two fit people can lift her unrigged. Length ended up 5.75m Beam is around 4.4m. Single rudder and board. Sleeps 1adult and child each side. Top speed 20.5 kts in flat water and 25kts, she does about 10 kts in around 14kts of breeze
Three bags you made an excellent work with this boat. Looks fantastic and most of all it gives you the pleasure of creativity. Respect.
