Maiko
Hydrogen fuel cell generator
Hey guys!
We have been working 1,5 years on a hydrogen fuel cell electric generator, which would be perfect for maritime market. It is lightweight, quiet and since it works on hydrogen, emits nothing but water. Not to mention that there are no moving parts, therefore the generator is maintenance free!
Maybe you'd be so helpful to share your thoughts on the product, would it satisfy your needs, do you see any problems with it, etc. Would you see it as part of your gear?
Also, what alternatives are you currently using, heavy batteries, wind generators?
More information and pictures can be found on our partner's website: https://www.ropeye.com/fuel-cell-1/
Thanks
Jesus, where to start?
Ad, or no ad, this is pretty cool, but I wonder about the practical aspects.
Your website says hydrogen is "widely available" and invites you to google your nearest refill station. So, I did, and it came up with Truckee, California, 450 miles away.
It may be clean, quiet, and efficient but, clearly, refills would be a huge pain.
BTW, the website has many spelling and grammar errors. Get a native English speaker to proof it.
Locally I can get Hydrogen gas at the welding supply shop.
and consumption of g or Kg of Hydrogen per Kw hour ?? for "9 KG with hydrogen unit"... i guess it incudes a tank..
SUYT's
BAFA
with that being said I like the concept.
yep, hydrogen supply is a non-starter for me. Only place near me that supposedly has it as a 'consumer' option is at Logan Airport. I thought Mercedes Benz was working on a fuel cell that used methane or propane as the H2 source, which would make it commercially viable in more places around here anyway. looks pretty neat though.
Everything is wonderful about hydrogen fuel cells except finding the fuel.
If the hydrogen fuel cell system included the capability to make hydrogen gas (refill the tank) using externally provided electricity (from solar or shore power for example), then you have something.
Applying electricity to water makes hydrogen. If the tank contains a block of aluminum, then a small voltage causes the aluminum to absorb the hydrogen (essentially putting it under tremendous pressure), and reversing that voltage causes the hydrogen to come back out of the aluminum. You can't make the tank of aluminum, as the structural properties of aluminum are annihilated when the hydrogen is absorbed. So the aluminum can act simply as a sponge, but cannot be the pressure vessel. (I am pretty sure this is correct, its been awhile since I investigated it.)
How do you get the hydrogen for testing? Welding supply shop?
The normal usage pattern for nearly all sailboats is to be immobile the enormously vast percentage of time at a dock in a marina. Therefore, there is plenty of time to refill the tank using shore power.
The normal usage pattern for nearly all long term cruisers is to be immobile the enormously vast percentage of time at a dock in a marina OR at anchor. Therefore, there is plenty of time to refill the tank using shore power or solar power (or maybe wind).
If the tank could power the unit for a couple of days, then the vast majority of yachts could use your fuel cell generator.
If the tank could hold 60 days of fuel, and could be filled via shore power in a marina or lots of solar at anchor in a week, then almost every yacht could use your fuel cell generator.
Exceptions to the above patterns are so few as to be ignored when doing any sort of sustainable business plan.
Well shit I never heard of Atomic Hydrogen Welding till I goggled hydrogen in welding.  My first thought was WTF hydrogen explodes!  Still dont understand how they use it as a sheild gas.
make absolutely sure there's no oxygen?
To the OP why chose hydrogen instead of  methanol?  Seems the fuel availabity is a problem.  Not thats its a bad idea but right now getting fuel is a problem.
At the stated 9kg weight how many Ahrs of  power does it provide. This seems like something that could make sense for race boats as a weight reduction measure. If it could get rid of a genset and batteries that would be a huge weight savings.
Methanol is extremely toxic and emits CO2, hydrogen is the lightest element in the periodic table and in case of a leak, in an open area there will be very little if any danger as the hydrogen diffuses into the atmosphere rapidly. You're right, many regions do not have open access to hydrogen, but that is changing as hydrogen is making way to our everyday lives - cars, buses, trains, heavy duty trucks and even homes will be heated by hydrogen in the UK maybe.
Max charging power per day is 800 Ah. It is designed to replace any additional batteries on-board.
How many days will it provide power at 800 Ah/day with a 9kg quoted weight?
Like the concept but the big stumbling block is that a 10 liter tank of H2 produces roughly 800AH of power.  For any kind of offshore work that ends up being a lot of tanks to carry.  While methanol has it's downsides, the energy density is much higher than compressed H2
Unless H2 is readily available nearby wherever the boat happens to be when it needs fuel, I don't see this technology going anywhere in marine applications.
There was talk above about another system on the boat capable of making and storing H2 gas. But wouldn't that require a charger and batteries to power that system? Isn't it simpler, cheaper and more efficient to just grab that electricity off the batteries to provide 12VDC to the boat?
Good luck to you Maiko!
Apparently the most efficient way to transport hydrogen (in terms of energy density) is as ammonia.  No compression required.  Lots of work being done to real time extract hydrogen from ammonia, so maybe done the track, this is the way to go.  Now however it seems to be too many tanks and to hard to refill.  Kudos for the concept.
Interestingly, the company I work for abandoned H2 Fuel Cells for H2 Internal Combustion Gen Sets for our off grid power modules. I was surprised and pleased today to get an email from a potential client interested in a 'catamaran' application. Would never have expected an unsolicited inquiry for a boating application.
If you have clean water and a power source like solar, you can create H2 with an electrolyzer. Some can create the H2 under pressure so that a separate compressor device is not needed. Storage of energy at pressure is very effective from a weight perspective.
But to get a decent energy density the H2 has to be stored at high pressure (>3000psi) or cryogenically, neither of which is great for a boat.  I looked into this in some depth maybe 15 years ago, and it's hard for me to imagine that with the improvements in battery storage you wouldn't be better off just going with a big battery bank and electric propulsion if that's the path you're on.  The round trip efficiency for electrolyzing water (50%) times internal combustion (10-30%) is really going to hurt versus battery RTE (80+%) and electric propulsion (maybe 80-90%).  So you'll need a *lot* more solar, which most boats don't have.  Only way I could see that making sense is if you had a fuel-switching engine that could run on diesel or H2; you could fill up on diesel prior to a long passage, then survive for a long time (perpetually?) on solar+H2 if you are on the hook or daysailing/gunkholing.
Neither will hold a candle to diesel if you need to motor a lot. And the H2 solution involves a *lot* of pretty sensitive hardware so I'd be skeptical of real-world durability.
Socalrider. Agreed 200% H2 is not going to work. Right now, nothing beats the efficiency of diesel plus solar/wind and batteries on a boat.
and why exactly is it that we don't see ammonia refrigeration any more?
Ammonia is poisonous and incompatible with copper tubing. Before the atmospheric problems associated with CFCs were discovered, they were preferred for these reasons even though they aren't as efficient. That pendulum is starting to swing back.
