• Announcements
    • Zapata
GregHman
Radar on a small boat
Hi guys,
I was gifted a Furuno DRS4W over a season ago, but I didn't put it on thinking my Hunter 25.5 was too small to bother with it. This time I'll be doing some much longer stretches across Lake Michigan and now I'm tempted to put it on as an extra safety device (I intend to do a fair amount of single handing).
I think it would look fairly goofy if it were stern mounted. I'd prefer to see it on the mast, but I'm unsure where. I see most radars above the spreaders, but I'm wondering if I could put mine lower within easier reach form the deck. Maybe it would be nice to not put so much weight up so high?
Any thoughts?
Amazon says it's 25 lbs.  That's a lot of weight to have up a mast on a 25-footer.   If by "safety", you mean not running into land or other boats 12 miles away or less due to darkness or fog, a transom mount above eyeball-cooking height (research how a microwave oven works...) should do fine.
It looks easy enough for a skinny actress to use.  Note the mount.
For your money, a chart plotter and AIS will do 99% of what you need.  The big boys will have AIS and it'll just be the little troublemakers that you'd want radar for.  I'd take my chances as it's the big boys I worry most about.  Small (our size stuff) can usually be avoided with a little situational awareness and a hard pull on the tiller.
Im about to buy a gx2200 vhg with gps and ais. This is why i hesitate bothering with it. Maybe i should resell it.
I haven't done enough sailing on lake michigan to know if there is much fog.
Why not do the same height on the mast? Pole mounts may look really silly on the hunter 25.5 unless i added more doodads like a wind generator and solar
I agree about the AIS idea, but make sure the VHF with AIS that you're thinking about is a transceiver and not just a receiver - you want them to see you and you them (transmit and receive), not just receive for the safety aspect to work.
Greg
+1, I find AIS to be more useful (where we sail) than radar for offshore collision avoidance.
AIS Transceiver and Chartplotter - big boys off the entrance of NY could see me very easy in 10-15 ft swells at night.  I am adding two PLBs this year to my boat for crew on deck.
12 hours ago, IStream said:
The higher the better and well above head height in any case.
Yah..high is good .  Dont know your boat and dont know your radar size
google "class 40 " for pictures...these race boats  rely on radar and gimbale  mount the radar for best reception and best sailing performance
I would. Put the money towards AIS (and I agree with gcutter about the desirability of a transceiver rather than a mere receiver).
You would be surprised how many small and midsize  boats who are not fit with AIS.
radar is a beutiful tool if you need all weather navigation
if I had to choose the most important tool...gps, chartplotter, ais , radar ...it would always be the radar.
This is exactly what I as thinking. I would mount it just high enough for me to reach to take down when I step my mast each year. I wasn't planning on a gimbal out of cost and I don't need to see much past 3 miles... I plan ahead and look up for weather...
I'm pretty fond of sticking with the GX2200. Hailing features are nice and navigating to a waypoint and using traditional charts seems like all I would need to sail on Lake Michigan. My tablet and phone are backup and they do as good a job of any chartplotter for getting around.
Is there a "low cost" transponder out there? I'm thinking I could just slap a small stern mounted antenna on my stern.
I'm fond of reducing the amount of permanent electrical items on my 25ft boat, staying economical, and being safe as I start to single-hand more. I was going to buy a GX2200 and I have a backup mounted VHF, backup handheld HVFs, and a PLB that stays attached to my PFD.
Your boat - your choice, Captain. You asked for opinions.   The net result either way will be that you're better off with the extra safety gadget than without, assuming the same set of skills with or without it.
As you've said since this post that you're mainly looking at 3 miles out, whatever you do that's safe, should be fine.
If you do go and mast-mount it within reach for ease of seasonal mast stepping/unstepping, just know that our warnings about mounting a few watts of pulsed, microwave transmitter RF are not idle suggestions.  If it's too convenient to reach, it might be too low for safety where near-field RF exposure is concerned; I guess this supports your mast placement preference after all....
Best wishes in the coming season.
before you get too wound up on mounting the radome, though the cautions are MOST APPROPRIATE,  where are you going to place the display ?
If you are single handing, you will want to be able to see it while at the helm, and reach it to change ranges etc.
The obvious locations are either the cabin bulkhead, or a panel in your companion way.
Make sure you can operate with one hand while steering and making a radio call with the other 2....
Below is a photo of a setup on a Hunter 25.5 (not my boat or photo; it is taken from an advert on Sailingtexas.com).
A few comments, for what they may be worth: (1) all this kit on a small Hunter seems a bit much; (2) while I appreciate that it is possible to drown in a bathtub, Lake Michigan is not a hugely challenging sailing environment; (3) safety is generally achieved not by stockpiling electronic gadgetry, but rather by prudent judgment and seamanship.
If I were the OP, I would eschew radar, chart plotter and AIS. All are certainly nice to have features, but really unnecessary for his intended application.
Here's the deal.  IF you're going with radar, it just doesn't make sense to have a separate display.  A radar 'should' overlay on your chart plotter.  Since you're already 'gifted' with the Furuno,  get a chart plotter that will take the radar signal if at all possible. If it doesn't, you've added extra electrical consumption and extra bulkhead/pedestal real estate for a 2nd display.  I 'might' even just go with the chart plotter and AIS and only add the radar if you find that you 'missed' having it.  After all, it was free anyway and sometimes free, well, really isn't....
An overlay is fine, but to make it work reasonably, requires a “good” rate compass so that the heading changes are nulled out.
An sufficiently large daylight viewable MFD with $800 heading sensor, E charts, AIS input, DSC VHF link etc quickly gets into $1000s.
Installing the gifted radar standalone, with an eye toward future system use is sensible, just plan on it so that you have a functional system that meets your needs.
I was just comparing the height of the two common mounting methods: mast and stern pole.
Your problem is that the boat is so small.
difficult to over come.
you might consider a radar,   mast mounted on a spinnaker track car.  In normal mode radar down ,  on deck.
In broadcast navigation mode radar hoisted to top on spi pole track .
a stern pole, mast, tower,  can work .  But on a twenty five footer they would be an eyesore and complicate docking maneuvers.
the mast mount is exposed to tacking jibs.
That's an interesting thought. Sounds like a lot of holes and I would need to do something clever with the wiring. It seems like I should be able to fix it to one point and get the best of both worlds without being in the microwave beam.
I guess I need to look the beam angles and figure out the minimum heights to keep people in the cockpit from being in the path.
Be very conservative with the nominal beam angle and the resulting minimum height you calculate. There's diffraction effects, reflection off nearby metal surfaces, etc that also come into play. Yes, it's just a fraction of the power but still. If you mount it directly overhead or close (i.e. on a pole behind the wheel), you can safely ignore those issues. If you mount it forward of your head, add a very generous safety factor to the minimum height you calculate. As I said above, the higher the better for reasons of both performance and safety. If the weight aloft is unacceptable, I'd second the idea of selling the unit and investing in an AIS transceiver.
Vertical beam is 25deg. There is 15ft from mast to stern. Tan(12.5deg)*15ft=3.3ft or more conservatively 7ft if all of the beam was pointed down (25deg). Lets add 7ft to that for someone standing on the transom and you get you get 14ft.
Thoughts?
Keep in mind that the nominal beam angle is generally defined at the half power point, so your increase of 3.3' to 7' isn't a bad thing but also isn't really conservative. Standing on the transom with the unit mounted 7' up would still expose your head to something approaching half the power of the beam. Adding the factor of two by moving it up to 14' sounds reasonable.
The one i saw used the spi pole track..the radar was mounted on a composite sadle with a spi pole car and could travel up and down the track
the wire was inserted into a rope cover...one end spliced to the bottom of the radar saddle ..one end spliced to a deck pad eye  at the mast base .
the radar was hoisted until this wire core rope down haul was tight
the wire penetrated the deck near the mast with a gland
the system looked like it worked
