Dirty Oar
Catalina 27 motor help
So, I'm a marine diesel mechanic, and work at a boatyard so, more than handy...
I got a Catalina 27, and, my motor doesn't fit. I tried a Honda 15 power tilt, and traded it for a Suzuki DT15 2 stroke, and can't get the cowling off to access the oiler.
Gonna trade the Suzuki for something else
I want a 15 because sailing in the northwest can suck and we have lots of tides
The icing on the cake is I have an Edson binacle that everything is controlled by/from
Really wanting a motor that can tilt up into the well, function over form...
Get a long 9.9 - that's what was intended when the boat was designed. It'll be lots. You can't buck the tide here in a small sailboat so......
If you're gonna go with an ob on a sailboat, Yamaha T9.9 is the way to go.  Swings an 11" prop with a lot of blade area and 2.92:1 gearing.  They produce a lot of thrust - probably better than a 12-15 hp ib diesel.
Keep in mind that the well was designed for old style 2 stroke engines so fitting a newer emissions compliant motor is hit or miss as you have seen
http://catalina27.org/ is probably the best source for what works with motors available today. They were pretty active a few years ago but they might be fading out.
I don't think any outboard sailboat from the GOD's was ever designed to handle 15's and such - 9.9 and less was all that was ever thought of.
Gotta go with the old long shaft 2-strokes. Johnson Sailmaster 9.9 with the super long shaft is basically the way to go.
Too long, a standard long barely clears the rudder
Yeah, old sailboats are what's keeping the old 2 strokes alive.
A low geared 2 stroke 9.9 is what I'm after, but considering I traded a Honda 15 4 stroke powerhead/upper with a working power tilt for the Suzuki, I don't have much into this, i got 1000$ into my Catalina tall rig, and like 200$ into the outboard for parts for the binacle...
Whatever I get, I hate doing glasswork and would rather not have it African American engineered onto the back of the boat
