Bastiat
What is This? How is it Used?
Looks like a transducer for ether a speedo or depth sounder that does not require a through hull.  I have a similar setup for a speedo that requires a wheel be stuk on outside of hull and the end stuck to inside of hull directly over wheel.  It never worked real well and since we ramp launch a bunch ended up loosing a couple and giving up.
50 minutes ago, longy said:
iT'S AN ACTIVE ANTENNA FOR A GPS UNIT.
Yup, and an old one at that (circa 2000).
25 minutes ago, SENDITBOYS said:
It's a "mouse" type GPS receiver. Probably runs serial, you can get em on Alibaba for 5 bucks.
Not with that BNC connector!  As longy said, it's an active GPS antenna: it puts out RF, not NMEA.
