Mid
How to cut a tyre in half ?
What it says on the tin .
Use a power jig saw with a fine-tooth (metal blade). A sawzall will buck and will probably not work well. I have used a jig saw with reasonable results. The sidewalls cut easily (they have nylon cords). The tread is a pain, because you have to slice the metal cords. Go slow, take breaks, and let the blade cool. The rubber will smoke. You might try cooling/lubing the blade with water or oil. I did not but would try it again. I assume you are cutting radially (from one bead, thru the tread, to the other bead). If you are cutting concentrically, cutting the side walls is easy. I have not cut a tire (tyre) concentrically thru the tread. If I had to try again, I would also consider a circular saw with a chop saw (abrasive metal-cutting) blade or fine-tooth plywood blade. Abrasive blade would probably smoke like a rasta.
Don't ask how I know about this...
Snubs
thank you very muchly , you are correct , I wish to cut radially .
a couple of decent jig saw blades will be cheaper than a sawzall .
Find a textile radial.
Use a large sharp knife.
Get someone to drip 25% washing up liquid 75% water onto the knife as you cut.
arr , in an ideal world :)
reality is I'm dealing with a toss over the fence from a neighbour and it's a steel belt .
Sounds like an awful mess.
TQA's soap and water mix is good stuff for doing that kind of cutting, thru messy stuff with a metal jigsaw blade. I use this for cutting thru old fiberglass too. Rubber is either going to melt & smoke or jam against the blade (or both) so be ready to stop often.
Are you taking suggestions on how to return the favor?
nah , I asked for the tyre , want to cover a water meter before I brush cut it to death .......
Slow and healthy.
Sheet metal blade in a sawzall.  Has the fine TPI of the jigsaw blade, but better form factor and way faster cut.
Put some lube on it.
Fast and unhealthy:
Zip disc in an angle grinder.  Fast no fuss, gonna smoke a bit.
tyre shops cut the sidewall off the tread with a sharp knife then sawmill once across the tread so it lays flat in a skip.
I have seen scars from the knife slipping though, take care.
Sawzall, all purpose = metal blade.  make sure the tire is held in place first though.
Set the entire tyre on his frond door entry and light it on fire. Chanting will help. Using half a tire is pussy.
