toddster
The down side of "barn find" Zodiacs... I know, you told me so.
Argh! Well, so much for "like new."  I've put maybe 20 miles on this thing - mostly skipping lightly along over mild wind ripples at 15 knots.  (It had never had a motor on it before.)
And, the front fell off.  Well, the bottom at the front.  The floor peeled away from the tubes along the glue joint. All across the bow, where the high-pressure floor and the keel exert the most force against it.  Fortunately, it didn't happen on the water - just sitting on the trailer, under a tarp.  (I think I would have noticed that, at least when putting it up on the trailer...)IMG_1984.jpg.39abe1b1d01aac5e6f5982c1ef0937fa.jpg
So... a plan for fixing it.  Clean off, all that old glue. Should be a joyful exercise... Re-glue.  Add an external tape all along the floor/tube seam?  Got some time to ponder, because I'll have to send away for that much glue and tape.  (Where to buy PVC seam tape, anyway?  Defender has some long thin pieces, but nobody seems to have rolls.)  Not exactly sure how to clamp it up, either.
Nothing more expensive than a free boat...
It is PVC.  Now that I look closer at it, I’d guess that the internal tape, in sheer, provides most of the support for the keel and gear weight.  Adding an external tape layer at right angles might not help much.
I had a middling quality RIB that came with my last boat. All the "hardware" like the oarlocks and rub strip was either off or coming loose so I cleaned everything with MEK (made it look almost new) and stuck everything down with 5200.
Worked like a charm.
My dad used Gorilla Glue on his old Zodiac.  Looked like shit but worked.
This
that happened to me once. I bought the PVC compatible 2-part stuff from Locktite off mcmasters. Comes in small 2-tube packs with a mixing nozzle. Pretty slick system. The bitch was getting everything in place and camping it. Had to do in sections with the boat deflated and concrete blocks as the clamps
Using 5200 it works better if it's inflated. The goo holds everything in place so no clamping is needed.
When I stuck the rub strip back down it was only loose in spots so I deflated it, cleaned out underneath the strip, squeezed in 5200 and inflated it tight.
if it's the floor separating though, inflating it just pulls the tubes away from the floor even more.  It's tricky.
5200 would work and might be cheaper than the Locktite stuff, but the locktite cures relatively quickly, so you can hit more of the glueing each day.
Well crap - I'm still trying to finish a couple of other projects, so I have a whole bay to lay out the Zodiac in the garage.
Wrong parts came for the old Evinrude - maybe I can just put it up on Craigslist as "a box of parts" rather than as a motor.  :(
The front falling is not so bad. It’s when sea catches fire that things really go south.
