sailsandsales
best paint to use for a thistle centerboard?
I want to paint my centerboard.    What's the best paint to use that will won't chip/rub off?
Gasoline and Match ~  Just kidding
If it is wooden , apply 2 to 3 coats of epoxy to seal the wood grain, sand 220 to fair and then apply Interlux perfection orsimiliar - I assume you are dry sailing
I think perfection will get abused pretty quickly - need something harder.  VC underwater epoxy is pretty hardy - at least it is an absolute bitch to sand if it has fully cured
So what's the window for sanding before the absolute bitch presents itself? Inquiring minds...........
As soon as you can wetsand without getting rollies.  Spray a couple of  test panels at the same time as you spray the item at hand so you can test sand.  As far as I remember it is a window of 12-36 hours after spraying
i would go w Awlgrip 545 epoxy primer and call it a day...
 very hard,  easy to fair and re-apply, long lasting barrier coat. polish to mirror finish if desired.
