dacapo
stream stay roller furling
any info on these old RF's?  I'm in need of a manual or knowledge on how to take this mother fucker apart...............I need to remove the forestay and  have no clue how the thing separated at the base where the threaded fitting connects................any info is appreciated
What forestay?
I was once told that there are two set screws at the top swivel, if those come out the whole thing comes apart. The foil is the stay.
I believe that was the "twinstay" for racing, it was solid with no stay inside but there was a furling kit available for it.
6 minutes ago, See Level said:
Then again, I could be wrong, it's been years since I worked on one.
Here is some info from sailnet, back when they were just old, not antiques.
https://www.sailnet.com/forums/gear-maintenance/9489-hyde-roller-furling.html
Thank you. The bearing housing was the bitch that I had to get off and couldn’t figure it out. Then yesterday I had to remove  the extrusions and the inner sleeves were a mother to remove as well. They built these things heavy duty (as in they didn’t want someone to take them apart :P
