Guerty
Loose Gooseneck - J24
Hi,
not much of an expert in J-24. I have a loose gooseneck, with the pin almost coming out. Please see the pictures and advice a way forward. Your help is much appreciated .
Gerardo
   Go to "rigrite" and look at thier J-24 parts. The early masts had a ss bracket that attached with pop rivets, which could be used in your case after failing welded on unit is ground off. They also list a welded on unit, which could be yours.
  After you do what longy says, add nylon spacers to reduce metal on metal wear. Also DO NOT go back with bolts, ( that's putting a file in the middle of a new repair ) use pins.
