Grande Mastere Dreade
sourcing long brass bolts
i've been trying to source some long brass bolts  flat head or oval head    around 12" in length or more..    1/4"-20 or such ..   i've searched but haven't found anything over 6"
mcmaster carr has nothing ...   any ideas?       I can't use threaded rod as the bolts will pass thru a 1" brass rod as the attachment point..
Maybe search for BRONZE instead. A brass bolt is about as useful as a plastic bolt.
yes thank you...  and it's probably   5/16-18   not 1/4
Not sure where you're located but I get bronze fasteners from K2 Fasteners in Burnaby, BC.  No account needed, just a $50 minimum purchase which is pretty easy since "5/16 flathead machine screws are about $1.00/inch.  Never needed something that long but you may get lucky as they've always had what I needed in stock.
Make your own, done it heaps but if want to buy them search for "bronze strut bolts" and make sure your wallet is nice and fat before ordering
yeah the strut bolts came up,   which led me to what I want,   slotted though,   I only need a couple ..  and they are pricey for sure..
Sounds like you need to check out Pacific Fasteners on 1st in Burnaby.
Definitely not for bronze.  Or service with a smile!
Get manganese bronze rod and a suitable die nut. Peen the heads and cut the slot, or get a mate with a lathe to help out. If its only a few just buy them.
thanks for the suggestion,   but I thought bronze was too brittle to pound on with a hammer and i would hate to weaken the connection because it keeps an important part of the boat on..   ( rudder to rudder shaft)   it's an old boat..
Assuming its to an external flange then copper bolts are fine in that application but I wouldnt use one with a nut (if you do make sure its bronze) you can make a what is essentially a giant rivet and peen the heads over, much more streamlined and neater
Have you ever seen copper bolts? Maybe in electrical grounding applications. Bronze is appropriate. People suggesting he do a bit of blacksmithing when he can buy bronze bolts off the shelf....?
