tony.collins
J70 Rudder Slop
Hi
Looking for some advice, I have had my J70 for a few years now, The steering was extremely smooth when I got it and recently has become more rough. It's fine in flat water but in the waves you can feel it clunk back and forth which is not confidence inspiring at speed. The pins were replaced a little over a year ago - http://store.sail22.com/j-70/rigging/j-70-rudder-pins-bronze-sail22/
I understand the bronze pins will wear faster than stainless ones. Is my best option to continue replacing them every year? Are there any more permanent solutions to this?
FWIW I am in So Cal and willing to bring the boat or just the rudder/pintle/gudgeon to a local shop.
Thanks,
Tony
Not a permanent fix but works great.
 Take a piece of thin spectra line. ( just scrap line.)
 fray the end and pull a single strand from the line. Ideally long enough to span both gudgeons.
 Put the strand through the gudgeons w the rudder in place then tap your pins through.
 You may need to add strands if there's still play.
  Really works well.
  Really works well.
Thanks I will try this! It sounds like a great short term solution until I can get something more permanent in place.
7 minutes ago, Blitz said:
Sounds like you need a new carbon rudder. :ph34r:
Carbon Rudder guy is still racing in our fleet, we almost got him at Long Beach Race Week this year!
We have used teflon plumbers tape for this, takes out the slop and eases friction. Cheap and easy to reapply. Might be against your class rule? Just wrap as much tape on as you can and still get it to fit. Start at the top of the pins and spin overlapping the layers down so the pin just barely fits. You may need to help the pins with some gentle persuasion.
J-24: I used to wrap a couple plastic grocery bags over the pinntios and shove them in.
Then we discovered out gudgeons could be made slightly misaligned by tightening the bolts....
because the transom  core was rotted.
Whennwe fixed ttevrit we put onntge gudgeins just actsx crooked .
Works great
Works great
Holy shit, I did not know you spoke Snagg's, Gouv!
