Wedgie 0 #1 Posted May 6, 2019 I understand that most if not all of these Carroll Marine built boats had problems with skin and keel/rib issues in the bow. Nearly 20 years after being built and most owners having addressed these issues; how are they holding up? Are they still having structural issues after repair/upgrades? Any other common build issues develop? Looking at Old School....... Share this post Link to post Share on other sites
Robyn Banxx 1 #2 Posted May 6, 2019 Gotta watch the core. Whatever genius put foam above the waterline and balsa below the waterline needs to be sternly dressed down. The modded ones are very fast boats Share this post Link to post Share on other sites
Hitchhiker 802 #3 Posted May 6, 2019 What modifications have been made to make them faster? Share this post Link to post Share on other sites
doghouse 123 #4 Posted May 6, 2019 3 hours ago, Robyn Banxx said: Gotta watch the core. Whatever genius put foam above the waterline and balsa below the waterline needs to be sternly dressed down. The modded ones are very fast boats This isn't uncommon. Balsa is effective at handling compressive loads. Share this post Link to post Share on other sites
J-T 1 #5 Posted May 6, 2019 I bought hull #35 12 years ago; bottom was significantly re-skinned/ encapsulated by Waterline Systems at the time as part of the purchase. To be fair, I have no idea if the bottom core has stayed perfectly dry since then (who knows that until they sell their boat and the buyers' surveyor tells them? ), but in my experience the hull and rig have been rock solid and very tough after hard use. So yes, important to get a good survey with a focus on the damp core which has been an issue-- I'm sure this was addressed on Old School. On the other hand I never had any keel/rib issues and frankly the ones I have heard of were following brutal groundings; I don't think this has ever been a 395 flaw, despite the rumor-mill. Yes, there are numerous ways one can tell the 395's were "built to a price"-- hatches, stantions, interior fit-out-- but this stuff can either be lived with or upgraded over time in the normal course. I think these boats are great value, simple set-up, easy to sail, and perfectly competitive with any new racer/cruiser.... particularly in a lighter-air venue. 1 Share this post Link to post Share on other sites
left hook 5 #6 Posted May 6, 2019 Old School is very much not a stock Farr 395 below the waterline. They went with a low vcg keel like five years ago. I’m not sure what they did with the balsa but the work was done in Rhode Island so presumably it was done well. Share this post Link to post Share on other sites
sshow bob 321 #7 Posted May 7, 2019 Do you know if they have the new rudder? Share this post Link to post Share on other sites
left hook 5 #8 Posted May 7, 2019 Unsure. Can’t find the listing to check. New rudder is primo though. Share this post Link to post Share on other sites
Roleur 281 #9 Posted May 8, 2019 Ace in the PNW looks brand new and sails well with a PHRF of 39. Share this post Link to post Share on other sites
ROADKILL666 309 #10 Posted May 8, 2019 Thank god he is not building any more boats Share this post Link to post Share on other sites
Wedgie 0 #11 Posted May 10, 2019 Old School is junk! Don't waste your time looking at it. Share this post Link to post Share on other sites
Lightfoot 11 #12 Posted May 11, 2019 Any tips on Long Distance racing a 395? I just got on one for this summer. The boat has an interesting hull shape, with the narrow, light displacement bow, with a slight concave on the hull sides, The keel seems really far forward on the hull, then a literally flat bottom between the keel and sail drive where it’s at the widest, and then a narrow stern with a shallow angle to the transom. I’m guess that weight forward in light air, doesn’t help that much? Also what the best way to get over a wave with it? Seems like burying the bow into the wave might be the way to go, with so little buoyancy forward (as opposed to taking it side on and getting life’s over) Share this post Link to post Share on other sites
jackolantern 449 #13 Posted May 12, 2019 I hear the north 395 sails are slow and prone to having holes poked in them Share this post Link to post Share on other sites
Lightfoot 11 #14 Posted May 12, 2019 First problem avoided. Boat doesn’t have a single North Sails’ sail. What else? (Or share the story behind that comment, cause I’m assuming it’s a person putting holes in the sail, not the rig/boat) Share this post Link to post Share on other sites
Fiji Bitter 1,442 #15 Posted May 12, 2019 25 minutes ago, Lightfoot said: (Or share the story behind that comment, cause I’m assuming it’s a person putting holes in the sail, not the rig/boat) I think that was just a Witty comment... Share this post Link to post Share on other sites
port tack 12 #16 Posted April 11, 2020 Curious on how the keel was lengthened on Old School? Or is it a whole different keel? Farr 40 Keel? Any other big issues other than that it is bound to have wet core? Share this post Link to post Share on other sites
jackolantern 449 #17 Posted April 11, 2020 New keel Share this post Link to post Share on other sites
Greyhound37 72 #18 Posted April 11, 2020 On 5/8/2019 at 3:58 PM, Cristoforo said: Building boats to a price point is one thing. Claiming the class is going gangbusters, backorders, fleet is building, etc. when you are about to close the doors was, well, Trumpish. Share this post Link to post Share on other sites
Hitchhiker 802 #19 Posted April 11, 2020 3 hours ago, port tack said: Curious on how the keel was lengthened on Old School? Or is it a whole different keel? Farr 40 Keel? Any other big issues other than that it is bound to have wet core? If the boat has the original rudder, check the shaft for corrosion. It will be visible at the interface of the blade to shaft, but likely worse inside the blade. Share this post Link to post Share on other sites
Navig8tor 1,155 #20 Posted April 11, 2020 WTF, did they melt a Toyota and use the metal for a rudder shaft and grid? That looks primo dodgy. Share this post Link to post Share on other sites
port tack 12 #22 Posted April 13, 2020 Yeah, I have heard about the rudder issues. Looking like Old School may not be worth the trouble. Share this post Link to post Share on other sites
