Tornado-Cat
Boats and foils comparison
The cups can read the same, but there is a bunch of voodoo between the compass speedo and wind direction that convert apparent wind back into true wind. If I remember, these were never done by a single formula, but each vendor had his own way of fudging it back to believable numbers.  I think the biggest problem was the “upwash correction” which is the amount the rig bends the wind before it gets to the mast.  On the wings, the upwash was dependent on the lift coefficient, which in our case went up and down something like 150%.     This means that TWD & TWS can be consistent within each program( and they have to be to make any testing valid) but may not correlate between programs.  I’m sure there are people here who know all about this stuff.
When the boats  are sailing side by side you would expect to see very similar numbers.  This never happened on Saturday.
SHC
SHC
I'm not 100%, sure but I have a feeling that the instruments providing data for virtual eye and broadcast are supplied equipment potentially running the same software with identical settings. If that's true, then the differences we see in TWS numbers may be caused by differences in sail design, size and trim. That would be an interesting challenge to calculate back from errors in TWS / TWA traces.
great screenshot of how low the surface area is for AM. Fast but not enough life in light air
2 hours ago, WindySurfer said:
After jerk come jolt and jounce, but after that we find some very silly physicists who liked rice crispees.  The 7th, 8th, and 9th derivatives of position are snap crackle and pop.
2nd derivative is otherwise known as acceleration. Of course, integral is actually what matters to get to the finish line first!
LR data. @X35 GER50, note the wind strength was different between two weeks, so vmg/tws might be better.
image.png.d9c6eb96c168d167c22211240489ca4c.pngimage.png.705f4900c39d35fec54ac5b818adcd97.png
Thanks Dorox! Can you add to the comparison the data from today?
I haven't implemented the height analysis in my code yet. Do we know where they measure it? Bow?
What's the theory behind correlating height with vmg? I think the height numbers could depend a lot on pitch and heel angles and the optimal height may be different for each boat.
I've done the height analysis as well, but I don't know how accurate these numbers are. I doubt LR sails 70 cm higher than INEOS.
1062213235_uwheight.png.89446ce51b60ff5c251f7f88e8884d98.png  534154244_dwheight.png.50702030fc9dd2f7f963101c4455161a.png
Height during tacks:
thanks erbd for looking at that. woul dbe nice to have LR race 6 vs LR race 8. But the numbers seems the same. Probably they have a different offset in the sensor placement.
Erdb,
Thanks for the very interesting performance analyses that I discover only now - great job!
Years ago we did a study for TackTick on the influence of the sail on AWA & AWS as measured in the top of the mast. There certainly is a noteworthy influence, and sail trim affects too like Steve Clark is saying, but could their sail trim be that much different? I doubt it.
Small wetted area means less drag in most conditions, but not all. Because lift force must be pretty equal for same conditions for all the boats, (weight being same and presumably heeling force from sailplan also very similar in identical conditions), small area must mean higher lift coefficient. That results earlier cavitation (lower boatspeed when cavitation begins being an issue), which is the opposite of being fast.
It's therefore not just the takeoff condition when small area is a hindrance.
Is their any collective sense here about who has used the most of their sail allocations? Is saving fresh sails for last a factor?
SHC
I might be wrong, and not that it matters much, but i thought "upwash" was reserved for the effect that occurs when the apparent wind is from behind, and the wind flows up and over the eased mainsail from behind, causing a zone of anomalously high wind speed, and change of direction near the sensor.
when the apparent wind is forward - as it always is on these boats, the airflow deflects to flow around the rig well ahead of the rig which causes an error in direction, but not so much in speed.
But one thing I read somewhere about the TWD/TWS calculation for these boats is that they have to use a tidal current model, which would be a whole new source of error.
The reason is that they are mostly using SOG, not BSP, as it's nearly impossible to measure BSP on boats like this. If SOG and COG are used in the wind calculation instead of BSP and HDG.., the calculation yields wind referred to the earth, which is usually called ground wind: ground wind speed and ground wind direction. By convention, TWS and TWD are referred to the water, which moves with respect to the earth. Supposedly, they are taking the calculated ground wind.., adding the model current - so changing from a coordinate system fixed to the earth, to one fixed to the water - and getting TWD/TWS.
I did see this interesting article about a Doppler device being used by INEOS to measure actual BSP during development., but I'm not sure it's on their race foils, or if any of the other boats are using it.
https://insight.nortekgroup.com/ineos
The data that Dorox is pulling, does it include very-precise GPS coordinates at 10 times per sec? The (freely available) Race Data sets during the past 2 AC’s did include that data, the mark positions too. It made for extremely accurate COG and VMG calcs.
I haven't seen GPS coordinates so far. At least not in the files I'm able to get based on his instructions. There may be a way, because the virtual eye display needs those coordinates, too. Maybe Dorox could figure out how to pull those as well.
I was also wondering about what technology the umpires use this time. I remember in SF and Bermuda there was an additional system on top of GPS that allowed getting boat and camera positions with 1-2 inch accuracy both for the umpires and for Stan Honey's graphics. I wonder if there's something like that now. The on-screen graphics did seem a bit jumpier, especially during the ACWS.
Here’s hoping, that data is basically the dynamite.
The ‘projection arrows’ were cool too, would have been very illustrative in for example the close-call on the last leg of ITA/GBR.
Funny, I was just looking at that. The boat images don't scale accurately on Virtual Eye when you zoom in, but the little circles showing the tracks of the boats seem to be 3 seconds apart. I scaled the image based on the circles and the speeds of the boats at that time and draw the dimensions of the boats on the image (with yellow lines of course). It seems the closest they got was 31.5m, which at those speeds was about 1.4 seconds. That was the true delta in that race. If LR gets there 1 second earlier, they win and we get to watch another race the next day in 20 kts of wind...:angry:
Nice work!
Still wish we had better data though, you’d be even sharper!
In the JSON file the positional data is:
> coordIntep
        > xCerp
        > yCerp
> coordIntep
        > xCerp
        > yCerp
Ha, you're right! Somehow I've missed that. It's not Lat/Lon, it's converted to meters, but we have positions with 20Hz frequency! I don't really know what to do with it, but it's cool. Let me know if you have any ideas.
I had thought a while back to look at the distance made good during tacks/gybes?
Deciding the period to examine may be a little tricky, eg they may bear away a bit for a few secs to pick up speed before/after the maneuver, so that time period should probably be included.
I've been doing that already using the TWA, speed and VMG data:
In a way it's more accurate, because it corrects for wind shifts (as long as the TWA data is accurate). From the GPS tracks, we could get radius of tacks and jibes by each boat and  G forces, but it's not that easy. We could also get minimum distances between boats. That'd be relatively simple.
Here is the distance between INEOS and LR during the last race:
The min distance between the two was 19.24 m at the start. The closest they got during that last cross was 30.9 m. Pretty close to what I got from the scaled screenshot. Of course, this is the distance between the GPS antennas or whatever reference point they calculate from that on the boat.
I thought the intent was to map height to boat speed rather than VMG to see what speed the boats took off
I made another web app with boat tracks and data side-by-side. It is better to use it on a PC, because map zoom doesn't seem to work on mobile.
https://ac36.herokuapp.com/map
So far it has only race 8 from Prada cup. You can scroll the slider at the bottom to change the time and see the race progress.
It seems like LR got really unlucky with wind shifts at the last upwind.
The boats are shown roughly to scale, but I didn't have a good image for AC75 from above. If someone wants to draw it, it would be really cool. It has to be .png with transparent background.
  • Like 12
This is awesome. I'm sure @MaxHugen could give you some beautiful boat images - maybe even team specific ;)
A little video I made... setting up for more detailed discussion on individual teams. I hope it's a good baseline for the 'design problem' discussion.
Thanks to all the anarchists, especially this thread!
  • Like 6
Good again @Mozzy Sails
One comment is that you forgot that the foils also have to have a void for this supplied transponder for the race committee usage
And it did remind of one question that has been at the back of my mind for a long time: why did they insist that the foils were symmetrical?
Since the sections are symmetrical, how much downforce do the foils produce when they are being hauled up out of the water?  How much drag is this?  Do the teams account for this when retracting foils?
If they normally supply lift, why would they produce downforce when coming up?
> coordIntep
        > xCerp
        > yCerp
Great find! Nice, nice, nice
Are mark positions available too?
They are symmetrical sections?  Or, when folks are talking symmetry they’re talking about bilateral symmetry?  At any rate, when the windward foils come up, there’s  a fair amount of water coming off, at least.
On the nomenclature side, are the foils that come off the side of the boats officially foils, or are they called struts, and only the two foils on the ends are foils?
Only the bits that stick out of the arm are foils, and they have to be symmetrical about the arm. So they both produce lift (unless flaps are lived to do otherwise)
I think to give the foil arm manufactures (one design supplied equipment) some chance of predicating loads. Any asymmetry in load either side of the arm can only come from flap position, which is again limited by flap size (and competitors willingness to have that much drag).
Arms.  OK.  And the sections of the foils can be anything?  So the arms are streamlined, and  lift neutral, even if aoa changes?
How much does load change going through waves?  (Does wave circulation change aoa as the arm goes through or meets a wave?). Are the arms a particular section?  Are the horizontal stripes on the arms anti ventilation fences?
Most of us refer to foil arms and foil wings. The arms do have different trailing fairings across the different boats and there’s been some speculation that those designs might be inducing ‘crabbing.’
Like Laser crabbing?  I’m trying to picture that.....
Where the boat (and therefore rig too) are at a lower AWA than the hull and its course.. We’ve seen glimpses of it but the ‘upwind drift’ could have been tidal.
> coordIntep
        > xCerp
        > yCerp
Can you please show an example of this data? If it’s not lat/long to the nth decimal but meters instead, then presumable it is X and Y using some reference grid?
the data is in UTM format for zone 60S. If I understand correctly, these are x, y coordinates in meters relative to a specific point. Mark data is there too, but is arguably harder to pull out. There is also wind data for buoys and committee boat and race boundaries.
You can actually get the leeway angle from the available GPS velocity vector and heading. Alternatively, you can see it for yourself here https://ac36.herokuapp.com/map. The boat heading data is used to rotate the boat icon independently of GPS. So if you zoom in to see the boat icons, you'll notice their heading is not always aligned with GPS track. This is especially pronounced on downwind legs.
Awesome!
Would make for brilliant Course-VMG calcs if based on mid-gate reference points, and/or based on the mark ultimately rounded so as not to skew the last part of the leg’s VMG.
Interesting! So how did you figure out what the reference point is? You were somehow able to fit the tracks on the map. Really nice work!
The leeway is interesting. I would have thought they get the heading from the GPS, but if it's separate as you say, I may be able to analyze the leeway angle for each boat the same way I analyze all the other parameters.
The problem is that often times the left and right side of the course have very different wind direction and speed. If you just use one buoy somewhere on the course, it won't really tell the story. I guess the question is, what you'd like to know. If you want to compare boat performance, then the local TWA, TWS measured by the boats is better (as long as they reasonably accurate) to get a VMG against local wind direction. If you want to evaluate how well the teams position themselves on the course, you could use the axis of the course or buoy data or just use the average TWA from the boats. That's what I'm using for those "on favored tacks" graphs (I should come up with a better name for those).
Video of ETNZ practice today, January 26, shows them sailing with both foils down.  They seemed to be doing as many maneuvers as they could manage and still stay on foils.  This makes sense as they have just shipped the smallest set of foils seen to date.
I had been wondering about using both foils for trying to get out of the water.
SHc
Yes, exactly, but need it be an either or VMG measurement?
Perfomance-wise, VMG to the Wind is great but tactics-wise, VMG to the course (mark or mid-gate) is brilliant too.
SHc
I'm wondering if they are practicing "stay up on manoeuvres at all costs" moves. Even if you slow drastically through a tack on both foils, the drag on two would still be no where near drag on even a small hull kiss. And there's stability gained on exit that would aid precise sail trimming.
Certainly both are interesting. The problem is that if a boat has a better performance/VMG to begin with, they'll look good on the VMG to course, too, even if they aren't following the best tactics.  Something about how a fast boat makes the tactician seem like a genius.
That's why I came up with that method of analyzing tactical choices in degrees x seconds. Basically, for every second a boat sails on the favored tack, the angle of the shift in degrees is added to their "on favored tack" total. For every second they are on the wrong tack, the same number is deducted. This gives a number that's more or less isolated from boat performance. I've never seen anything like this used before, so I'm sure there are a lot of issues with it, but so far, it seemed to mirror what was happening in the race and matched the commentary from NO and KR.
I absolutely love that measure and yes, it’s novel and very clever!
TE posed a question on FB today asking (am not sure why, but) if there has been noticeable difference between when JS is on the helm and Bruni doing flight control (starboard) versus on the opposite side? Are you set up well enough to differentiate?
in old-school something like
select C-VMG where
boat=‘ITA’ and
Race = 2021011502
group by direction, tack
Awesome job mate! I had some suggestions - but when I went to your app you'd already implemented them - the slider and sync'd chart!
Sent you an SVG file of boats by email before realising I could have attached it here. :D
Is animation also on the to-do list?
You guys are amazing !!
As long as you do not provide spinbot with some stats that he can use to prove AM was fastest even though they did not win the cup?
12 hours ago, dorox said:
It seems like LR got really unlucky with wind shifts at the last upwind....
This is something I've found in my club racing to be a really unfair part of the whole sport of sailing.  The better sailors get a disproportionate amount of the lucky wind shifts!
  • Like 10
That's something I've thought about too. Especially as they get closer to the gates, VMG to the mark can be quite different to VMG to the course as a whole.
No doubt the teams know every optimum angle to sail from every metre of the course! :)
10 minutes ago, MaxHugen said:
Awesome job mate!
+10! Awesome is right
Damn, I ran out of Likes today! :)
9 hours ago, Mikko Brummer said:
Setting up Luna Rossa for an aero-simulation, to compare the double skin to a small wing mast+regular sail. . Original model by LCurreriDesign at https://www.turbosquid.com/Search/3D-Models/ac75
Look forward to seeing your sim results.  Been dying to see some airflow sims especially over the hulls, hull/sail intersection, etc. (there's a long list of wishes actually)  ;)
Mozzy...this makes so much of the analysis accessible...thank you!!!
+10... thank you!!!
SHc
Yes, we've seen them doing this quite some weeks ago too. Taking off and staying on foils must be quite a challenge for all teams in the light stuff.
Haven't yet seen any video of a team trying to take off with both foils down, I guess at lower boat speeds the drag is too much of an acceleration penalty.
Interestingly, although opportunities for measurement with any accuracy are very limited, I haven't yet found any significant difference in boat speed required to take off, despite substantial differences in foil area. Perhaps parasitic drag evens things out?
Personally I think there is some sandbagging going on???
Pls. present your list and I will see what I can do. I realize I posted this in the wrong thread, it should have been in the twin-skin setup. Anybody knows how it can be transferred, or maybe I will just continue posting there when I get some results.
No probs, see you on the other side topic. :)
I think it is a good idea but may not be the whole story for these boats. With displacement sailing boats  (at least upwind) they quickly get to hull speed and any more wind doesn't make a great deal of difference. With these boats it does, so they may go a lot quicker. So a smart tactician might (and I believe) has give up a lift or header for more breeze. Especially in the light stuff when it can make the difference between foiling or not of course
More wind doesn't make the boats go much faster, but it does affect the angles they sail
Good illustration with 2 boats as close as it can be, slight difference in TWD but big one on TWS. Notice that delta is usually consistent, one boat is measuring more than the other most of the time and that seldom revert.
On 1/13/2021 at 2:00 AM, erdb said:
I'm still going through
257831033_uwheel.png.8d85db92a5fad945e431d55ad2832e5b.png  254502351_uwpitch.png.026c11450e4e3cc5cfbb364710abc023.png
Downwind:
1697625613_dwheel.png.d8c2f2b9045657a3df39d0af7bb0f3bb.png  11468258_dwpitch.png.a4b0b53df23d7eb51a0a835b1581329d.png
AM heels more to windward and pitches more forward both upwind and downwind.
Up- / downwind foil cant angles:
788743555_uwfcant.png.a59fe4ab23525bb4619cd3a33f0ee30f.png   62521715_dwfcant.png.0f1d7f0992c9b95a2f3c067023ffbd35.png
Have you produced these upwind and downwind pitch histogram plots for GBR and ETNZ?
Also, would be interesting to plot pitch V speed for each team
 A little late asking this question but can anyone explain the thought process behind Patriot being so bow heavy??   How does Patriot get a speed advantage by heavy a heavy bow but light stern???? I am not understanding the major keel kink.
All good points, but we can only play with data we have. The TWS data doesn't seem reliable, the difference between boats just seem too big. If it was accurate, we could compare which boat sailed in more pressure in general. On the other hand, if a boat sails in better pressure on average than the other, it may show up as having better average TWA or VMG. So yeah, it's possible that those differences between boats are partially due to putting the boat in better wind, and not the boats' performance. We would need a lot more data to know for sure.
Yes, I have some of the ACWS races as well. This is race 8 ETNZ vs INEOS. TWS was around 11-12 kts.
615793510_uwpitch.png.e506ecc583b44b8d695394e9533f49f5.png  1795997828_uwheel.png.650f09c332435e422182d07a77189cfb.png1959303851_uwcant.png.03e371b9ecad6f3587d1887d075a14c8.png
253436765_dwpitch.png.21a6d14274757f8e6191da352778c74f.png  419088567_dwheel.png.d83b7c4c211c2b3c063895f1ab3e7a9a.png
34 minutes ago, dorox said:
Update: now all races are available at https://ac36.herokuapp.com/map
Thanks to @MaxHugen for boat images. If you zoom in, you should see schematic AC75s drawn to scale.
Looks great! Although I'm a bit disappointed that the sails are not trimmed according to AWA and AWS. :P
So this was THE cross:
May have been a little less than a boat length based on this, but it also depends on where you put the GPS location reference point on the boat.
I'll have to send @dorox imgs with the sails on the other tack... might be an issue trying to swap between the images though? :)
I understand that they didn't actually make contact, and were not overlapped. But this is not the cross. This is after LR turned, before the closest approach, and before the cross. At the closest approach, they were well within one boat length.
On the Dorox app, this was the closest between the two. Check out yourself if you can make them any closer. https://ac36.herokuapp.com/map
My GPS based minimum distance calculation was also ~30 m. LR didn't turn to avoid. They turned as a last resort trying to get a penalty on INEOS. It almost worked, they were just 1 sec late.
Thanks you, that dispels one theory and reinforces another
@dorox, your data is great - thanks a bunch for compiling it. Would it be possible to add a CMG plot by integrating the VMG curves?  And if I’m able to add one more request, is it possible to colour key the map plots so that you can identify speed along the track e.g if Ineos is blue then where the line is pale blue speed is <20kts, dark blue >40kts and shades in between.
CMG is quite simple to add, just one question: should it be derived from wind VMG, or course VMG, or simply the distance sailed from GPS?
Re colour gradients: this is doable, but in a form of scatter (colour-coded dots along the boat track)
This app is amazing! I'm really spending too much time trying to analyse how they compare to each other! :D That 36th America's Cup presented by PRADA dashboard website is also pretty amazing - I'll try to follow it along a live a race next time
I also have some suggestions to make if that's alright...
In the map app, would it be possible to add a buttons next to time stamp to be able to step through data points slowly?
The other questions is whether it would be possible to display values for the current data time point over the chart below the map?
Thank you again for putting this together - it's almost information overload :D
5 minutes ago, Enzedel92 said:
So after all of this who has the fastest boat?
Have to say NZ
(otherwise some posters will have a major tantrum)
