The Dark Knight 679 #1 Posted December 1, 2019 Are there many old IOR boats that have had the infamous IOR bump removed and how was it done? I was just looking on the "Police car" FB page https://www.facebook.com/police.car.sailing/ and someone had posted photos of work they had done to remove the bump from a Davidson 39 It's not structural work, so probably not so "expensive" to do. I wonder if the change has tamed the boat's down wind manners. Share this post Link to post Share on other sites
SloopJonB 7,974 #2 Posted December 1, 2019 It would have to help some but that bustle and pinch was only a contributor to the "Death Roll". The real problem was the boats were full displacement hulls and the racers would run them up to the hull speed wall and keep piling on sail - tall, skinny spinnakers in 25 or 30 knots of wind are going to broach any boat that can't break out of the displacement wave train. It just digs a bigger & bigger hole and rolls around in it. People just didn't do that sort of shit on Westsails or Taiwan Teakies or they'd roll the decks under too. 1 Share this post Link to post Share on other sites
Grande Mastere Dreade 2,026 #3 Posted December 1, 2019 2 hours ago, The Dark Knight said: It's not structural work, so probably not so "expensive" to do. I wonder if the change has tamed the boat's down wind manners. yeah, you're right, that doesn't look expensive... to some billionaire 3 Share this post Link to post Share on other sites
The Dark Knight 679 #4 Posted December 1, 2019 1 minute ago, Grande Mastere Dreade said: yeah, you're right, that doesn't look expensive... to some billionaire It will be cheaper to put on a false bottom to smooth out the bump than it would to make a structural change to achieve the same goal. Share this post Link to post Share on other sites
MiddayGun 180 #5 Posted December 1, 2019 Quite a few old half tonner & quarter tonners have been 'IRC Optimised' here in the UK. Which does sometimes involve removing the bump. Some good info & pics here: http://www.corby-yachts.com/refits.html I've no idea how much it makes a difference because its usually combined with new keel, new rudder & new rig. I can't imagine it being a cheap job though. Share this post Link to post Share on other sites
The Dark Knight 679 #6 Posted December 1, 2019 Interesting looking at some of the mods done by Corby. They take the same approach as in the photos I posted earlier. Add some external ribs and fill with hard foam, then put a skin over. Share this post Link to post Share on other sites
Zonker 2,422 #7 Posted December 2, 2019 Wonder why all the ribs? Probably just to get the shape right. But I'd treat the existing hull as the structural/watertight hull, and just add a foam layer + very light glass exterior skin. If you wanted to it right you would laser scan the hull (< $2k), bring it into a CAD program, add the foam layer in 3D, and then CNC cut foam blocks that would perfectly create the shape you want. No upside down glassing of ribs and fairing. It would all just be very fair from the start. Police car ribs look like plywood (shudder) 3 Share this post Link to post Share on other sites
El Borracho 1,655 #8 Posted December 2, 2019 Would add considerable flotation, no? What is the result? Insignificant? Share this post Link to post Share on other sites
12 metre 344 #9 Posted December 2, 2019 The wood ribs are used for fairing in the Davidson crease on a Davidson 39 - not Police Car, which was an alloy Dubois. The Davidson mod photos got mixed in with the Police Car posting. The Davidson crease is fairly evident in the photo below of Waverider Not really removing the bump (crease) on the Davo per se. I suspect more extending/fairing it to increase the sailing length. Share this post Link to post Share on other sites
Bruno 113 #10 Posted December 2, 2019 Apples and oranges. Those photos show an egg crated bump removal, not added surface area, thereby shoaling the hull. Most bumps, as in the Dubois example cited, are molded in, cutting out part of the hull and adding a new piece ain't easy. Neither is adding foam and glassing upside down and achieving a fair result. Nb the keel stub showing after the ribs are removed. Some IOR boats had U shaped bows, adding a bustle to such a boat might help. Or not, here's an intelligent article about shape. http://www.oceannavigator.com/January-February-2003/Shaping-an-offshore-hull/ Share this post Link to post Share on other sites
Zonker 2,422 #11 Posted December 2, 2019 Then there were the IOR local measurement point bumps that looked like a grapefruit was stuck to the hull and glassed over. At least they would be easy to fix. Share this post Link to post Share on other sites
CaptainAhab 154 #12 Posted December 2, 2019 Are you going remove lumps while you are doing the bumps? Our 1982 32’ IOR had all of the maxed out measuring points and duck tail. It was one of Brit Chance’s last IOR efforts. The mathematically optimised hull was a sight to behold out of the water. She was susceptible to broaching above 25 knots going downwind Share this post Link to post Share on other sites
CaptainAhab 154 #13 Posted December 2, 2019 Are you going to remove her lumps while you are doing the bumps? Will this be a full liposuction reduction? Our 1982 32’ IOR had all of the maxed out measuring points and duck tail. It was one of Brit Chance’s last IOR efforts. The mathematically optimised hull was a sight to behold out of the water. She was susceptible to broaching above 25 knots going downwind. Share this post Link to post Share on other sites
The Dark Knight 679 #14 Posted December 3, 2019 18 hours ago, Zonker said: Police car ribs look like plywood (shudder) Not Police Car. It was photos from someone else's bump job mod that they shared on the PC page. Police Car is getting the bottom paint finalised, bump and all, ready to get wet. The owner is keen to sell but no one wants to buy a project on the hard, so he is trying to get it ready for the water to make it a more attractive proposition for buyers. Unfortunately it seem that the sellers budget will not cover the full on PC paint job or vinyl wrap https://www.facebook.com/police.car.sailing/ Share this post Link to post Share on other sites
charisma94 220 #15 Posted December 3, 2019 I wonder what the deck is like? It had holes in it 20 years ago! Was only 3mm plate to begin with... Share this post Link to post Share on other sites
stumblingthunder 565 #16 Posted December 3, 2019 Regardless (N/M 1 ton) version, had the stern IOR whoopties evened out and the bow reshaped in the early 90s. OH Rodgers engineered that project. I was part of the sanding/fart-rock crew that faired the hull. As far as I know, the boat is still up in the Great Lakes. - Stumbling Share this post Link to post Share on other sites
Brain-O 0 #17 Posted December 11, 2019 Fix these bumps cheap Share this post Link to post Share on other sites
Carrera 32 #18 Posted January 24, 2020 Back to the original question, adding an external fairing to fill in the IOR bustle (leaving the structural hull intact underneath), while laborious, is not that expensive. We did it to a Farr 37 about 15-20 years ago. We actually connected with the Farr design office to see what shape they recommended and they gave us some good drawings and specs to work with. From there it was just grinding the section of hull down to glass, building up the foam core as recommended by Farr, shaping the foam, covering with multiple layers of glass and fairing compound, a lot of sanding, barrier coat, and finally paint. It took the better part of every weekend for 3 months but we got it done. I'd say it definitely added some stability and speed (from the increased LWL) off the wind. Share this post Link to post Share on other sites
George Hackett 54 #19 Posted January 25, 2020 So how is the rudder dealt with? A third rudder bearing and longer rudder shaft? Share this post Link to post Share on other sites
Carrera 32 #20 Posted January 27, 2020 On 1/24/2020 at 7:27 PM, George Hackett said: So how is the rudder dealt with? A third rudder bearing and longer rudder shaft? If I recall, we shaved a small wedge section off the top of the rudder to fit the new hull profile and glassed in a small rudder post tube but we didn't add an additional bearing. Since the overall length of the rudder and the post did not change, we didn't see a need to mess with the rudder post/bearing assembly. Share this post Link to post Share on other sites
