mako23 271 #2501 Posted October 9, 2020 35 minutes ago, MaxHugen said: I have absolutely no doubt that the clever designers have been scratching their heads, trying to figure out exactly that. You need a foil that can change its shape depending on speed. Once cavitation starts occurring, the foil changes into a different shape. You could have a foil with half the wing is the flap. At cavitation speed the flap moves inside the front half of the wing. Now your left with a wedge shape which is more likely to do super cavitation. I’m sure the rules prevent this, also the front half of the wing has to be hollow to allow the flap to move inside it. The strength of this material would have to be a super alloy 1 Share this post Link to post Share on other sites
KiwiJoker 314 #2502 Posted October 9, 2020 2 hours ago, laser 173312 said: Not a good start, given the news that the Bleedin' Bodgit Company are going to be covering the upcoming cup. Take heart. The Beeb will be relying on the same extensive core coverage we'll all see. Of course they will "sweeten" their broadcasts with coverage from their own experts. No promises on that score, but tons of national sailing broadcast experience the Wallahs at Broadcasting House can draw on. 1 Share this post Link to post Share on other sites
P Flados 180 #2503 Posted October 9, 2020 The Italian guys were specifically talking about a hybrid. From what I saw, the objective of the hybrid was not to get supercavitating capability plus typical performance (lift vs drag) at lower speeds. It was more to get supercavitating capability plus have the "normal speed" performance go from "absolutely hideous" to just "plain bad". Share this post Link to post Share on other sites
P Flados 180 #2504 Posted October 9, 2020 5 hours ago, mako23 said: You need a foil that can change its shape depending on speed. Once cavitation starts occurring, the foil changes into a different shape. You could have a foil with half the wing is the flap. At cavitation speed the flap moves inside the front half of the wing. Now your left with a wedge shape which is more likely to do super cavitation. I’m sure the rules prevent this, also the front half of the wing has to be hollow to allow the flap to move inside it. The strength of this material would have to be a super alloy I am pretty sure the required material for the above is that good old unobtainium we occasion hear about. If it were not for the symmetry requirements, I could see having a canted Y foil with the outboard element as a flapped "normal" foil and the inboard element as a non-flapped supercavitating foil. When you are in "normal mode" you use the outboard element and the arm to provide all required lift so that the supercavitating foil is not trying to produce lift and thereby minimize drag. Above some threshold (say 40 knots), you use your flap to unload the normal element and let the supercavitating element provide most if not all of your required lift. Altitude control in supercavitating mode would be tricky but not impossible. Possibly similar to the Altitude control provided by the Hydroptere configuration. Share this post Link to post Share on other sites
Schakel 124 #2505 Posted October 9, 2020 3 hours ago, P Flados said: I am pretty sure the required material for the above is that good old unobtainium we occasion hear about. If it were not for the symmetry requirements, I could see having a canted Y foil with the outboard element as a flapped "normal" foil and the inboard element as a non-flapped supercavitating foil. When you are in "normal mode" you use the outboard element and the arm to provide all required lift so that the supercavitating foil is not trying to produce lift and thereby minimize drag. Above some threshold (say 40 knots), you use your flap to unload the normal element and let the supercavitating element provide most if not all of your required lift. Altitude control in supercavitating mode would be tricky but not impossible. Possibly similar to the Altitude control provided by the Hydroptere configuration. Sail rocket, Hydropetere, that's all cutting edge technology. A fast floating laboratory; exciting, inpredictable. 1 Share this post Link to post Share on other sites
JALhazmat 936 #2506 Posted October 9, 2020 Can we try and spread the super cavitation/sail rocket discussion to a few more topics, I have seen at least five with no mention of it and it’s not acceptable ;-) 2 Share this post Link to post Share on other sites
amc 47 #2507 Posted October 9, 2020 11 hours ago, mako23 said: You need a foil that can change its shape depending on speed. Once cavitation starts occurring, the foil changes into a different shape. You could have a foil with half the wing is the flap. At cavitation speed the flap moves inside the front half of the wing. Now your left with a wedge shape which is more likely to do super cavitation. I’m sure the rules prevent this, also the front half of the wing has to be hollow to allow the flap to move inside it. The strength of this material would have to be a super alloy This, I think, will be the answer in the future with some clever hinge linkages and tracks and stuff also flexible foil surfaces that completely change the shape of the foil. They will probably also be moving continuously to achieve optimal results. Share this post Link to post Share on other sites
mako23 271 #2508 Posted October 9, 2020 6 hours ago, P Flados said: Above some threshold (say 40 knots), you use your flap to unload the normal element and let the supercavitating element provide most if not all of your required lift. very interesting P Flados Yes you could use a flap so the outer foil produces less lift, but how does that stop cavitation ? maybe you could have this side sticking out of the water Share this post Link to post Share on other sites
P Flados 180 #2509 Posted October 9, 2020 Reducing lift is part of how you can go faster before the onset of cavitation with traditional foil technology. Thin sections also help. So if you just want a little more speed you can keep the tradition foil in the water and use the flap for control. And yes the other choice is to increase boat altitude and end up with nothing but the supercavitating element in the water. This is where the Hydroptere style of altitude control would be required. Either of the above would probably make supercavitating work for the main foil on an AC75 platform. The actual top speed gain would then probably be limited by the rudder. Balancing the boat to minimize rudder loading (both vertical and horizontal) at speed would become more important than it currently is. Share this post Link to post Share on other sites
mako23 271 #2510 Posted October 9, 2020 17 minutes ago, P Flados said: The actual top speed gain would then probably be limited by the rudder. Balancing the boat to minimize rudder loading (both vertical and horizontal) at speed would become more important than it currently is. Very good point and something I hadn’t considered. Considering you need to retain a T shape foil for stability control, this would add another complication if you tried to get the rudder to achieve super cavitation. All super cavitation foils I’ve seen don’t have a T section. Yet if you go to a straight foil you lose the ability to control angle of attack and your back end would sink. Share this post Link to post Share on other sites
Stingray~ 1,237 #2511 Posted October 10, 2020 21 hours ago, P Flados said: Stinger, go back to your Bermuda data. What were peak SOG values on upwind & downwind legs compared to what they did when reaching. Good question but I can’t answer it without resurrecting a 3 yr old laptop. The highest speeds were recorded by AR and TJ. TJ’s was as they bore away around the Leg 1 reach mark, AR’s was on a tight approach to the bottom of Leg 6 downwind, making the turn to the finish reach. From what most insiders have been saying, a massive difference this time will be how upwind speeds will be around 40 knots versus around 32 knots in Bermuda. That’d make AC75’s kill AC50s or even F50’s on an up-down track. Share this post Link to post Share on other sites
P Flados 180 #2512 Posted October 10, 2020 14 minutes ago, Stingray~ said: Good question but I can’t answer it without resurrecting a 3 yr old laptop. Lol, I am trying to get use to a new laptop even as I type this message. I decided to try a 12" and am finding the vertical screen dimension is a lot less than desired when I am on forums that embed a bunch of junk at the top and/or bottom of the screens. Share this post Link to post Share on other sites
Stingray~ 1,237 #2513 Posted October 10, 2020 17 minutes ago, P Flados said: Lol, I am trying to get use to a new laptop even as I type this message. I decided to try a 12" and am finding the vertical screen dimension is a lot less than desired when I am on forums that embed a bunch of junk at the top and/or bottom of the screens. My new one is good enough (I run several monitors) but I’m just not going to dust off a 3 yr old one, to be able to re-query a database that is cool but almost 4 yrs old, it’s not worth my time Nice screens are cheap, one of mine is around that old and still works beautifully, highly recommended for whenever you move the laptop to a spacious desk for a change of scenery. Share this post Link to post Share on other sites
Sailbydate 2,401 #2514 Posted October 10, 2020 46 minutes ago, P Flados said: Lol, I am trying to get use to a new laptop even as I type this message. I decided to try a 12" and am finding the vertical screen dimension is a lot less than desired when I am on forums that embed a bunch of junk at the top and/or bottom of the screens. Not to mention all the crap posted in between, eh P? ;-) Share this post Link to post Share on other sites
Crux 15 #2515 Posted October 12, 2020 I see that Rita B1 is now sitting with all the cars on Bledisloe Wharf in Auckland 4 Share this post Link to post Share on other sites
Varan 1,678 #2516 Posted October 12, 2020 Going against previous winner "Oracle New Zealand"... ha ha Share this post Link to post Share on other sites
Indio 782 #2517 Posted October 12, 2020 34 minutes ago, Varan said: Going against previous winner "Oracle New Zealand"... ha ha That wasn't the only boris-johnsonism in the piece, otherwise it was good. Share this post Link to post Share on other sites
Basiliscus 265 #2518 Posted October 13, 2020 On 10/2/2020 at 5:19 AM, Horn Rock said: I would've thought they would want the windward skin to be flatter, to create a greater pressure differential - more like the solid wings. Flatter windward skin creates less pressure differential, not more. Think of the sail curving the air flow. The windward skin is on the outside of the curve, so positive pressure is needed to make the air curve. More curvature = more pressure. 2 Share this post Link to post Share on other sites
weta27 3,956 #2519 Posted October 13, 2020 On 10/12/2020 at 1:00 PM, Crux said: I see that Rita B1 is now sitting with all the cars on Bledisloe Wharf in Auckland Looks like she is now on the forecourt at the INEOS base Share this post Link to post Share on other sites
Raptorsailor 277 #2520 Posted October 13, 2020 9 hours ago, weta27 said: Looks like she is now on the forecourt at the INEOS base Sure it's B1? Isn't B1 on a cargo ship to New Zealand? Share this post Link to post Share on other sites
MrBump 57 #2521 Posted October 13, 2020 6 hours ago, Raptorsailor said: Sure it's B1? Isn't B1 on a cargo ship to New Zealand? Crux posted monday saying it had arrived and was sitting on the wharf. 1 Share this post Link to post Share on other sites
weta27 3,956 #2522 Posted October 13, 2020 B1 un-wrapped 4 Share this post Link to post Share on other sites
Varan 1,678 #2523 Posted October 14, 2020 ^^^ you of anyone knows the saying... pic or it didn't happen. 1 Share this post Link to post Share on other sites
Crux 15 #2524 Posted October 14, 2020 Really - who cares about Rita B1. Anyway she came in on a car shipment Saturday and photographed on Bledisloe Wharf, Sunday morning sitting in the rain. 3 Share this post Link to post Share on other sites
Lickindip 485 #2525 Posted October 14, 2020 ^ a picture of a boat!!!!! THANK YOU!!!! 5 Share this post Link to post Share on other sites
NZL3481 370 #2526 Posted October 14, 2020 2 hours ago, Crux said: Really - who cares about Rita B1. Anyway she came in on a car shipment Saturday and photographed on Bledisloe Wharf, Sunday morning sitting in the rain. The next time that thing is in the water will be as a party barge getting towed to Kawau at 25 knots Share this post Link to post Share on other sites
Bushman 7 #2527 Posted October 14, 2020 52 minutes ago, NZL3481 said: The next time that thing is in the water will be as a party barge getting towed to Kawau at 25 knots sounds fun .. i'm in .... Share this post Link to post Share on other sites
mikenz2 1,536 #2528 Posted October 14, 2020 Called past on the way home from work: Now the really interesting thing was what that red sheet was trying to cover up..... but it's too early to be posting sneak peeks just yet :-) 4 Share this post Link to post Share on other sites
Rushman 217 #2529 Posted October 14, 2020 B1 I presume @mikenz2 Did you manage some photos of behind the red sheet? Share this post Link to post Share on other sites
mikenz2 1,536 #2530 Posted October 14, 2020 Just now, Rushman said: B1 I presume @mikenz2 Did you manage some photos of behind the red sheet? Very much the remains of B1. They gutted it pretty good before it left, definitely no intentions to sail her in Auckland 1 Share this post Link to post Share on other sites
Rushman 217 #2531 Posted October 14, 2020 1 minute ago, mikenz2 said: Very much the remains of B1. They gutted it pretty good before it left, definitely no intentions to sail her in Auckland And the answer to the question is.... 1 Share this post Link to post Share on other sites
Mozzy Sails 442 #2532 Posted October 14, 2020 Why even ship her out? 1 Share this post Link to post Share on other sites
mikenz2 1,536 #2533 Posted October 14, 2020 Just now, Mozzy Sails said: Why even ship her out? Backup plan... Britannia-2 is known to be radically different, best have something you know on hand just in case it doesn't work out. 1 Share this post Link to post Share on other sites
enigmatically2 477 #2534 Posted October 14, 2020 Or in case of damage and it is quicker to resurrect B1 than repair B2. The current NZ issue shows the merits of that 2 Share this post Link to post Share on other sites
Priscilla 2,093 #2535 Posted October 14, 2020 Crikey that is one fugly looking critter. 1 Share this post Link to post Share on other sites
barfy 1,056 #2536 Posted October 14, 2020 7 hours ago, Crux said: Really - who cares about Rita B1. Anyway she came in on a car shipment Saturday and photographed on Bledisloe Wharf, Sunday morning sitting in the rain. How can you be sure it's rita 1? Share this post Link to post Share on other sites
barfy 1,056 #2537 Posted October 14, 2020 2 hours ago, enigmatically2 said: The current NZ issue shows the merits of that No one has any data that points toward any "issue". Least of all you. Share this post Link to post Share on other sites
enigmatically2 477 #2538 Posted October 14, 2020 21 minutes ago, barfy said: No one has any data that points toward any "issue". Least of all you. Really? You did see the reports of damage to the steering pedestal. On this forum, NZ newspapes, sailing forums etc. And since then no news, and we have reports that the shed doors were closed and they have of course not been sailing again from what we can tell. Certainly none of our locals have suggested they have been. I wouldn't call it incontrovertible proof, but it is certainly "data that points towards an issue". In bold and underlined, lit up with bright lights.. Share this post Link to post Share on other sites
JonRowe 671 #2539 Posted October 14, 2020 15 minutes ago, enigmatically2 said: I wouldn't call it incontrovertible proof, but it is certainly "data that points towards an issue". In bold and underlined, lit up with bright lights.. It is a single datapoint. "One hears they had an issue". Here's another datapoint, we have AM, INEOS and LR all prepping to launch boats with AM definitely preparing boat 2, and INEOS/LR presumedly preparing boat 2's as well. So there is currently "radio silence" from all the teams, perhaps we should be drawing the conclusion that ETNZ are also preparing boat 2, which coincidentally aligns with a capsize. Who knows? Not us on this forum. Share this post Link to post Share on other sites
GBH 64 #2540 Posted October 14, 2020 3 hours ago, Priscilla said: Crikey that is one fugly looking critter. few months ago and one of those involved told me you ain't seen nothing yet in the ugly stick department Share this post Link to post Share on other sites
enigmatically2 477 #2541 Posted October 14, 2020 10 minutes ago, JonRowe said: It is a single datapoint. "One hears they had an issue". "One hears" ? You are kidding. Sail world reported it, spoke to a crew member about cause, got info from the team about damage. You correct that I am inferring that is why they have not sailed since, but this is not an non-attributable quote from an anonymous member of this forum, but a widely reported event. And the non-sailing since could be a coincidence. But coincidences often aren't Share this post Link to post Share on other sites
JonRowe 671 #2542 Posted October 14, 2020 15 minutes ago, enigmatically2 said: "One hears" ? You are kidding. *shrug* I mostly object to the continued bashing of the team just because of silence, it could be they have a major problem with the boat but it's certainly not "In bold and underlined, lit up with bright lights.." 1 Share this post Link to post Share on other sites
enigmatically2 477 #2543 Posted October 14, 2020 Where have I based the team? I have asked questions. I have not criticized the team at all. I do think the NZ supporters on here are being somewhat hypocritical in their ostrich-like attitude to this incident compared to when other teams have problems, but no criticism of the team at ll. Breakages happen. Anyone that has sailed knows that. On this thread I merely commented that GB was sensible to keep B1 for spare use, and had disagreement over it. I agree that there has been little news, which given the amount of attention NZ normally gets is unusual, but absence of news or hard facts has never stopped speculation on here before so I'm not sure why you think it should on this issue? Share this post Link to post Share on other sites
rh3000 1,484 #2544 Posted October 14, 2020 6 hours ago, enigmatically2 said: Where have I based the team? I have asked questions. I have not criticized the team at all. I do think the NZ supporters on here are being somewhat hypocritical in their ostrich-like attitude to this incident compared to when other teams have problems, but no criticism of the team at ll. Breakages happen. Anyone that has sailed knows that. On this thread I merely commented that GB was sensible to keep B1 for spare use, and had disagreement over it. I agree that there has been little news, which given the amount of attention NZ normally gets is unusual, but absence of news or hard facts has never stopped speculation on here before so I'm not sure why you think it should on this issue? You are right, I'll arrange a mob of ETNZ fans to go down to the base, hurl rotten tomatoes at the team and demand they tell us that the boat nearly sank and Burling got his balls caught in foil arm. 1 Share this post Link to post Share on other sites
mikenz2 1,536 #2545 Posted October 14, 2020 Do we think this is the cradle for B-1 or B-2? Share this post Link to post Share on other sites
MrBump 57 #2546 Posted October 14, 2020 would have to be B1, consistent with the hull mod to B1 and B1 still on low shipping cradle. Share this post Link to post Share on other sites
weta27 3,956 #2547 Posted October 14, 2020 Definitely designed for a skeg and those angles don't look like B1's bottom? 2 Share this post Link to post Share on other sites
weta27 3,956 #2548 Posted October 14, 2020 So frustrating, everything is building to a climax and I'm going to be out of town for a week ...!! Sounds like it will all be happening while I'm away. 1 Share this post Link to post Share on other sites
JALhazmat 936 #2549 Posted October 14, 2020 Given that B1 is sat on its cradle, that’s for B2 1 Share this post Link to post Share on other sites
P Flados 180 #2550 Posted October 14, 2020 Weta, I am confident that there will be ample opportunities for you to show off the photographic fruit of your in person spectating after your return. Know also that the lack of your contributions while you are gone will be a sad thing for the viewers that frequent these threads in order to watch from afar. Share this post Link to post Share on other sites
barfy 1,056 #2551 Posted October 14, 2020 9 hours ago, enigmatically2 said: I agree that there has been little news, which given the amount of attention NZ normally gets is unusual, but absence of news or hard facts has never stopped speculation on here before so I'm not sure why you think it should on this issue? But that's why there are pages on the royal family, and politics, and and. There is absolutely nothing to speculate. Either the boat is broken, or fixed, or a lull before b2. So knock yourself, spec u late. It's too windy today regardless. Share this post Link to post Share on other sites
mako23 271 #2552 Posted October 15, 2020 4 hours ago, weta27 said: Definitely designed for a skeg and those angles don't look like B1's bottom? Kinda similar ETNZ B1 if you added a Skeg onto it. Also that cradle looks very new. Not a single stain on it. Why build a new cradle for B1 when you could take the old B1 cradle with you when shipping the boat to NZ. I know this syndicate is well funded...but not to the point there throwing money out the window. Talking about skegs....maybe ETNZ is putting one on B1 during the no show. Of course this is idle speculation of the worse kind. Share this post Link to post Share on other sites
mako23 271 #2553 Posted October 15, 2020 Talking about skegs ....they obviously help create lateral resistance when the hull is fully in the water. But when the hull is flying can they not have an advantage by forcing the airflow to exit the stern in a cleaner manner. Share this post Link to post Share on other sites
Priscilla 2,093 #2554 Posted October 15, 2020 2 hours ago, mako23 said: Talking about skegs ....they obviously help create lateral resistance when the hull is fully in the water. But when the hull is flying can they not have an advantage by forcing the airflow to exit the stern in a cleaner manner. Does that mean the Handbags who have by far the most impressive skeg also have the cleanest rear airflow exit or to put it bluntly fart. Share this post Link to post Share on other sites
crashtack 141 #2555 Posted October 15, 2020 3 minutes ago, Priscilla said: Does that mean the Handbags who have by far the most impressive skeg also have the cleanest rear airflow exit or to put it bluntly fart. Maybe it's like a very big f1 diffuser? Does the exiting airflow even matter here? Share this post Link to post Share on other sites
mako23 271 #2556 Posted October 15, 2020 26 minutes ago, ivansh said: Maybe it's like a very big f1 diffuser? Does the exiting airflow even matter here? At 10 or 15 knots no. But at 40 plus knots I’d argue yes. Remember the boat when going into the wind could have airflow at 52 or plus knots going over they hull. Some of that airflow is going to wrap under that hull and create non laminar flow on the leeward side. With wind flowing under the hull at over 50 knots some attempt to keep this laminar would be worthwhile. However even with what, I would say the main purpose of the skeg would be lateral resistance in water. If you can clean up the airflow while on the foils that’s a bonus. Share this post Link to post Share on other sites
mako23 271 #2557 Posted October 15, 2020 42 minutes ago, Priscilla said: Does that mean the Handbags who have by far the most impressive skeg also have the cleanest rear airflow exit or to put it bluntly fart. Great store of pictures you have Share this post Link to post Share on other sites
Flippin Out 109 #2558 Posted October 15, 2020 20 hours ago, Mozzy Sails said: Why even ship her out? Because she's an ugly piece of shit !! Share this post Link to post Share on other sites
JALhazmat 936 #2559 Posted October 15, 2020 2 hours ago, ivansh said: Maybe it's like a very big f1 diffuser? Does the exiting airflow even matter here? For that to actually work you have to seal the edges to contain the airflow under the boat and maintain a relatively constant ride height with the ground/sea within a few centimetres, neither of those things are happening. there has been ALOT of discussion on ground effect/wing in ground effect ( two different principles) and F1 comparison already 1 Share this post Link to post Share on other sites
chesirecat 433 #2560 Posted October 15, 2020 Slightly relevant article re additive manufacturing and Honda R&D, since Ineos has plenty of access to this using titanium and time to develop the design pipeline (as first used in their test boat) and incorporate into B2. I've always respected Honda R&D since their IoM exploits where some of their engineering remains a mystery even today - like how on earth did they do it. https://redshift.autodesk.com/crankshaft-design/?fbclid=IwAR2WXR1AxcabgirfcqKwIQ5kUs-ewJI5f8Y6Rde2c3OK5U8nm-moLNQfhDo 1 Share this post Link to post Share on other sites
rh3000 1,484 #2561 Posted October 15, 2020 13 minutes ago, chesirecat said: Slightly relevant article re additive manufacturing and Honda R&D, since Ineos has plenty of access to this using titanium and time to develop the design pipeline (as first used in their test boat) and incorporate into B2. I've always respected Honda R&D since their IoM exploits where some of their engineering remains a mystery even today - like how on earth did they do it. https://redshift.autodesk.com/crankshaft-design/?fbclid=IwAR2WXR1AxcabgirfcqKwIQ5kUs-ewJI5f8Y6Rde2c3OK5U8nm-moLNQfhDo Sounds similar to the mystery that surrounds their legendary mountain bike https://en.m.wikipedia.org/wiki/Honda_RN-01_G-cross Share this post Link to post Share on other sites
Ex-yachtie 1,470 #2562 Posted October 15, 2020 10 hours ago, weta27 said: So frustrating, everything is building to a climax and I'm going to be out of town for a week ...!! Sounds like it will all be happening while I'm away. Who approved this? 2 Share this post Link to post Share on other sites
Ex-yachtie 1,470 #2563 Posted October 15, 2020 10 hours ago, JALhazmat said: Given that B1 is sat on its cradle, that’s for B2 What’s B2 sitting on then? Share this post Link to post Share on other sites
Mozzy Sails 442 #2564 Posted October 15, 2020 12 minutes ago, Ex-yachtie said: What’s B2 sitting on then? It's hanging by the deck attachment points, with supports either side, whilst the epoxy sets on the latest bustle arrangement? I guess they could have glued it on before shipping, they had the hull in the spice island base for a few weeks, but this makes a better story. Like I said earlier in the thread, that cradle is certainly not contoured to the bustle. It merely makes space for one. That and the addition of the skeg post Italy, and the timeline for B2 hull shape sign off suggests to me the skeg is an appendage. Plus I know someone who saw the mould and he said it didn't look like it had a skeg. Share this post Link to post Share on other sites
Priscilla 2,093 #2565 Posted October 15, 2020 4 hours ago, mako23 said: Great store of pictures you have Never in my sailing life would I have ever imagined this... 3 Share this post Link to post Share on other sites
mako23 271 #2566 Posted October 15, 2020 1 minute ago, Priscilla said: Great picture.....do you have any more directly in front to see Skeg profile Share this post Link to post Share on other sites
JALhazmat 936 #2567 Posted October 15, 2020 Probably loads on the Prada thread? Share this post Link to post Share on other sites
JALhazmat 936 #2568 Posted October 15, 2020 42 minutes ago, Ex-yachtie said: What’s B2 sitting on then? It had to be transported on a cradle so it could be on that while the daily launch/service cradle is built or it’s on a something that allows it to be fitted out The pics are not transport cradles and they certainly are not for B1. As others have stated the profile is entirely wrong. I know you won’t believe me so that’s fine. Share this post Link to post Share on other sites
JALhazmat 936 #2569 Posted October 15, 2020 29 minutes ago, Mozzy Sails said: It's hanging by the deck attachment points, with supports either side, whilst the epoxy sets on the latest bustle arrangement? I guess they could have glued it on before shipping, they had the hull in the spice island base for a few weeks, but this makes a better story. Like I said earlier in the thread, that cradle is certainly not contoured to the bustle. It merely makes space for one. That and the addition of the skeg post Italy, and the timeline for B2 hull shape sign off suggests to me the skeg is an appendage. Plus I know someone who saw the mould and he said it didn't look like it had a skeg. The pics of it shrink wrapped showed something underneath bustle/skeg shaped so I am pretty sure it was shipped with it intact rather than added on in NZ Share this post Link to post Share on other sites
mikenz2 1,536 #2570 Posted October 15, 2020 54 minutes ago, Ex-yachtie said: What’s B2 sitting on then? Good question, she was sitting up on a cradle already. With very finished looking livery, including bright red "RITA" on the side. Share this post Link to post Share on other sites
mako23 271 #2571 Posted October 15, 2020 7 minutes ago, JALhazmat said: The pics of it shrink wrapped showed something underneath bustle/skeg shaped so I am pretty sure it was shipped with it intact rather than added on in NZ Is there any sign of a skeg on NYYC club B2. I saw one picture were it was claimed someone could see one. I looked and wasn’t convinced one way or the other. Share this post Link to post Share on other sites
Boink 661 #2572 Posted October 15, 2020 On 10/10/2020 at 8:04 AM, Stingray~ said: From what most insiders have been saying, a massive difference this time will be how upwind speeds will be around 40 knots versus around 32 knots in Bermuda. That’d make AC75’s kill AC50s or even F50’s on an up-down track. They might get to go that fast upwind, but even if the boatspeeds are only similar, the VMG gains from the angles they sail and the speed preservation they demonstrate in manoeuvres - particularly in the tacks - means the AC75 would slaughter the AC50's all day, everyday - and twice on Sunday....... Share this post Link to post Share on other sites
mikenz2 1,536 #2573 Posted October 15, 2020 The new livery: 2 Share this post Link to post Share on other sites
mikenz2 1,536 #2574 Posted October 15, 2020 A peek at the bow: 3 Share this post Link to post Share on other sites
barfy 1,056 #2575 Posted October 15, 2020 6 minutes ago, Boink said: They might get to go that fast upwind, but even if the boatspeeds are only similar, the VMG gains from the angles they sail and the speed preservation they demonstrate in manoeuvres - particularly in the tacks - means the AC75 would slaughter the AC50's all day, everyday - and twice on Sunday....... That Sunday performance could be a design validation. I don't have the inclination to quote the Muppet brigade who went on about: the transition being unmanageable, the boats falling over at the dock and before powering up, maneuvers being impossible,.soft sails being fifty percent of a wings performance. But you know who you are who speculated on nothing but your anger and bitterness. Share this post Link to post Share on other sites
JALhazmat 936 #2576 Posted October 15, 2020 51 minutes ago, mikenz2 said: A peek at the bow: But that means they have the budget for more than one cradle? Omg! ;-) 6 Share this post Link to post Share on other sites
mad 3,701 #2577 Posted October 15, 2020 13 minutes ago, JALhazmat said: But that means they have the budget for more than one cradle? Omg! ;-) Share this post Link to post Share on other sites
JonRowe 671 #2578 Posted October 15, 2020 49 minutes ago, JALhazmat said: But that means they have the budget for more than one cradle? Omg! ;-) That made me smile, but did get me thinking, theres some draping cloth, the boat and you can see possibly the rear of the cradle? What do we think about the chance the shot was taken whilst they were moving the boat onto the cradle? B2 possibly hanging from the winches in the roof as they have a proper base and not a tent, so they can lift the boat indoors? Share this post Link to post Share on other sites
RMac 295 #2579 Posted October 15, 2020 So far still cautiously optimistic the Ineos boat two will still be horrendously ugly. Seeing that they went for the aesthetic choice to cover the thing in little sucker shapes like some kind of cephalopod limb is very encouraging at this stage. 1 Share this post Link to post Share on other sites
The_Alchemist 1,098 #2580 Posted October 15, 2020 18 hours ago, mikenz2 said: Do we think this is the cradle for B-1 or B-2? Could be a cradle for the support boat. It can't be for B1 or B2 because both of those boats are currently setting on their cradles. Share this post Link to post Share on other sites
rh3000 1,484 #2582 Posted October 15, 2020 5 hours ago, mikenz2 said: The new livery: That's walking a fine line between going to look awesome or vulgar as fuck... Time will tell 2 Share this post Link to post Share on other sites
JALhazmat 936 #2583 Posted October 15, 2020 beauty is in the eye of the (cup) beholder? 1 Share this post Link to post Share on other sites
JALhazmat 936 #2584 Posted October 15, 2020 1 hour ago, The_Alchemist said: Could be a cradle for the support boat. It can't be for B1 or B2 because both of those boats are currently setting on their cradles. INEOS employ a series of very tall people to work on the support boats so to make sure the boat is at a comfortable working height they need a cradle 4 m off the ground so they don't get bad backs from crouching down. its the B2 cradle. 4 Share this post Link to post Share on other sites
atwinda 87 #2585 Posted October 15, 2020 6 hours ago, mikenz2 said: A peek at the bow: Is that "red tarp" an old ETNZ IACC or TP52 spinnaker? 1 Share this post Link to post Share on other sites
Ex-yachtie 1,470 #2586 Posted October 15, 2020 2 hours ago, rh3000 said: That's walking a fine line between going to look awesome or vulgar as fuck... Time will tell Given the trend to date... Share this post Link to post Share on other sites
The_Alchemist 1,098 #2587 Posted October 15, 2020 7 hours ago, mikenz2 said: A peek at the bow: Looks like another dreadnaught? Share this post Link to post Share on other sites
The_Alchemist 1,098 #2588 Posted October 15, 2020 Is this a reflection of a foil/rudder from their instagram site? Share this post Link to post Share on other sites
JALhazmat 936 #2589 Posted October 15, 2020 Multi layered photo image that tells you nothing, It was used on the insta page to hint at the Belstaff clothing launch that’s all Share this post Link to post Share on other sites
Jono 41 #2590 Posted October 15, 2020 And despite all the talk about sailor safety on the water and for the shore crew on land, I saw a GB sailor biking home last night on a main arterial road without a helmet on and in flagrant breach of NZ traffic regulations. Absolutely shocking....... How can it be??? Why doesn't he get a Landrover too??? 1 Share this post Link to post Share on other sites
Priscilla 2,093 #2591 Posted October 15, 2020 12 hours ago, mako23 said: Great picture.....do you have any more directly in front to see Skeg profile
