Stingray~
INEOS Team GB
1 hour ago, Forourselves said:
Im still picking an INEOS v Luna Rossa Prada Cup final
INEOS will collapse inward when the pressure is applied. Can't build a team around one individual.
20 hours ago, Forourselves said:
Speed calc in the 26 knot range....  Those sure look like very large foils.  They look stable.
There's a lot of volume low down so riding higher off the foils. In fact "off" the foils might need redefining with the fin. Transitions smooth.
One is back to winning ways, taking the Tour of Italy earlier today. Well done Tao Geoghegan Hart!
Great young talent , humble too. Good win on final TT and apparently did not need a asthma TUE to do it unlike so many of the other Sky /Ineos Grand tour wins. Their car won today as well in a run-away.
55 minutes ago, amc said:
Have to go to work now but consider this.
This may also be a camera. LR and ETNZ have have similar devices on their foils and they were cameras
Foil tips are different.  That’s about the extent of my observation powers for foils.
WetHog  :ph34r:
WetHog  :ph34r:
Big input from Mercedes perhaps, plus lots of titanium
For the record, flap rules (ver 1.10)
Quote
15 Foil flaps
15.1 A foil flap must be a linear component connected to a foil wing by a foil system.
15.2 Each foil shall include two foil flaps, one lying entirely on one side of the foil wing symmetry plane, and
one lying entirely on the other side of the foil wing symmetry plane.
15.3 For the purposes of Rule 15:
(a) a “cross-section” is defined locally at any spanwise location along the rondure of the foil wing as a
section through a foil wing and foil flap, on a plane perpendicular to the rondure at that spanwise
location; and
(b) the “chord length” at a given cross-section and a given foil flap rotation angle is the distance between
the most forward point and the most aft point on the cross-section, when projected on to the foil
wing projection plane shown in Figure 13.1.
15.4 At any cross-section, the only permitted movement of a foil flap relative to a foil wing is a rotation about
an axis that remains approximately stationary with respect to the foil wing at that cross-section. This axis
must be designed to be stationary, but is permitted to have some movement resulting from:
(a) play in a mechanical bearing; or
(b) a flexure or soft hinge, such as a thin flexible material joining the foil flap to the foil wing.
15.5 Through a foil flap’s range of rotation angles and twists, a foil flap cross-section shall not significantly
deform except as permitted in Rules 15.4, 15.8 and 15.9, or as a result of external forces.
15.6 Both foil flaps of a foil shall have the same range of angular rotation and twist. With both foil flaps of a
foil centred in their ranges of motion, each foil flap shall be symmetric with respect to the other about
the foil wing symmetry plane, with a build tolerance of 3.0 mm.
15.7 At any cross-section and all rotation angles, when projected on to the foil wing projection plane, the length
of a foil flap must not be greater than 50% of the chord length. Hinges or other parts of a component which
occur at occasional cross-sections for connection purposes can be excluded from the projected lengths.
15.8 A foil flap may contact a foil wing, and in the absence of external forces, and at any cross-section and
rotation angle, either may cause deformation in the other in a single zone covering not more than 20% of
the local chord length. Outside this zone, neither shall cause deformation in the other.
15.9 Connections between sections of a foil flap are exempt from Rules 13.9, 15.4 and 15.5, providing such
connections span a combined total of no more than 10% of the span of a foil wing, where the span is
measured along the rondure
At any cross-section there can be only one flap & operating on one axis.
But it envisages multiple sections connected flexibly & doesn't seem to require all sections to be on the same axis.
I thought we'd agreed back when B1 launches happened that at least a couple of the teams seemed to be using external hinges
I'm not necessarily convinced its a fast solution but it seems to be what they're doing.
You can see its made of 2 parts in @mikenz2 pics.
Sorry to “foil” your discussions about wing design , but every time I see INEOS’s keel skeg, I think of (slalom with training stabilizers) skis and how this might assist the foils lifting, so that they can be optimised for higher speeds?
https://www.seaski.com.
2 hours ago, mikenz2 said:
A couple of new photos for y'all:
@mikenz2.  Great photos thanks!  Have run them through Gigapixel AI as per usual to allow reasonable blur-free enlargement.  Link here: https://www.dropbox.com/sh/eh6esoolboxnl48/AAAIrh-p3IjPNjcJ1lgEaMMea?dl=0 .  I'll add to the folder if any more appear.
Geoff
From Americas Cup 36 Facebook page. Found it interesting.
We followed both Britain and USA on the water today there was a good breeze but both needed to be pulled onto their foils by one of the tenders. Neither could get up without assistance. Does anyone know why?
Image may contain: ocean, sky, boat, outdoor, water and nature
Geoff
Thanks got my copy and these foils are getting  weirder and weirder
I watched INEOS jump into its foils unassisted yesterday, so I wouldn’t get too excited.
Very quiet northerly conditions today on the sparkling Waitemata Amway got away unassisted and fanged off towards Whangaparoa well north of course A into a better breeze whilst the Frackers buggered about for ages on course B and finally got underway taking it all very cautiously.
Yes I think it is a hybrid so the inner flap is like this and the outer is a simple flap sharing a common axis of rotation.
Where does 4.3 and 23.8 degree come from?
I think Max might have drawn this and measured the angles.
This pic from @weta27 seems to confirm they're running a continuous jib track...? independent sheet control to get around the rule but perhaps marginally more clew/leech control through the tacks compared to split tracks?
And also if you look just forward and down from my yellow circle there's what appears to be a camera mounted on the side of the boat looking down at the foils..
There's cameras at the top of the mast as well.
Wow... The photos from @mikenz2  and then pimped up by @GeeJay show lots of interesting and confusing detail!
I've had a go at marking up, but... I just don't know. The photo of the top surface of the foil seems to show a number of 'hinge' lines, which one is real?
Could it be that the only actual hinge is '2'? It's the only one that has a continuous bright strip visible on the under-side.
It's as if the leading edge section starts to bend down at '1'  (or hinge??) and its marked with a line of evenly space 'dimples'. From previous photos I assumed these were just low resolution effects on the actual hinge or flexible joint. But these enhanced and taken from closer distance photos seem to show that these are some flow conditioning/disturbing dimples...
Then at line '2', the inward part of the flap is hinged and is connected with a flexible patch marked '?'. Then line '2O' is not hinged and also has 'dimples' along it.
In any case, these foils don't seem agricultural to me...
What the heck is happening in the diagram marked ?
Zoomed in and sharpened in Powerpoint haha... I don't have the fancy AI tools :D
There seem to be some signs of the flexible material ripples?
So is it an illusion or are these foils a lower aspect ratio than the others?
From transposing a photo on the forum into scalable vector graphics, where angles can be measured. Accuracy is debatable, but may be around 90% considering the subject photo quality (not the best).
Like the seagulls then.
look I get that clever stuff can be deduced from pics but unless you know that shot was completely 100% square on and you could precisely determine the centreline of the foil profile then it’s not going to be as precise as you would like it to be
Nah mate, I'm going for American Magic vs. Luna Rossa.  Deano will be out for revenge.
Fun discussion on an excellent subject, am enjoying all of it.
About foil measurement devices, I once posted a long Foiling Week YT video that included  Bernasconi where he explained something about the lengths they went to during AC35 to verify just exactly what shapes and deformations were happening on the foils. He may also have given as a reason the necessity of trying match real-world observations against internal stress gauges and sim predictions. With flaps allowed in AC36, the same requirement may be even more important this time.
Ironic given your username that you ignore talent such as Giles Scott.
I could point out the other talent and experience, but of course when that team had to deliver in a real race on foiling boats in the SailGP they really fell to bits.
Ineos look good in that video above. Not exactly ripping through the turns like Patriot is, but staying dry. Weird that "over the hill" view when they were a long way away. He is using a very long lens. Bit of a swell rolling in?
INEOS will be fine with pressure. Historically that is not Ben's issue.  Luna Rossa on the other hand tends to explode with pressure, plus their crew selections often do not operate purely on merit.
The problem is that they are all bloody fast compared to almost everything else. They are doing dry turns a lot of the time (but all seem to have the occasional splash down).
Which is faster/fastest I don't think we have a hope of working out- how ever many seagulls fly past. Even assuming that there is a single answer and that in fact there isn't one boat faster in light winds, one in heavier winds etc
Still very early days with the B2's. I don't think Ineos is any where near fully optimised. Rig tension doesn't look to be really cranked on. No rake in the mast, and the fore stay looked to have a bit of sag.
No swell, just a long way away.
So curvature of the earth?
not possible, the earth is flat of course.
No, the tide was out over there
Don’t be silly, It’s the first glimpse of evil Jim’s cloaking technology to ensure that the rig is End plated  to the ocean surface.
As known by many people around the globe.
  • Like 4
The horizon is only about 5km away at sea level. They looked to be further away than that.
All the forestays have sag. It is called jib sheet tension.
I doubt any of the B2s are optimised yet.
15 Foil flaps
location; and
Not seeing what you are seeing.
- 2 flaps per foil
- one on each side of the arm
Seems clear enough no?
At about 5 km, the horizon curve appears - unless you're a member of the Flat Earth Society, I guess, HR.
I see you "rounders" have now even started altering videos on sailing forums to support your whacky round earth theories!
- 2 flaps per foil
15.9 that you quoted says that the flap can be in multiple sections, and that the join between them is exempt from some of the rules. So as long as the flap sections each rotate around an axis that is in the plane of the section of foil they attach to, no problem.
Apart from how to design that join and keep it smooth
So you either haven't bothered to look at their sailing roster or you are dismissing some of the best sailors in the world. I might be biased, but I think that overall, they have the strongest sailing roster. Just a few stand outs.....
Ben Ainslie - not bad
Giles Scott - Only one Olympic gold (so far), 3rd AC Campaign
Iain "Goobs" Jensen - Gold and silver medals, considered by many to be the best "wing" trimmer in the world (I personally don't - I think he is equal best with Glenn Ashby) 3rd AC campaign
Xabi Fernandex - Gold and Silver Olympics 3rd AC campaign
Joey Newton - crew on 2 AC winners 5th AC Campaign
Then add the likes of Freddie Carr (3rd AC), Chris Brittle (4th AC) and Andrew Mclean (5th AC)
Let's not forget the CEO, Grant Simmer (only 4 AC wins across roles from sailor to design head to CEO), who has the best track record of anybody in AC management.
Does that really look like a team built around one individual? Or is the use of Ben Ainslie just a great marketing tool?
4 hours ago, weta27 said:
That looks like a red seagull so it must be very fast!!
That seagull must have some quite sophisticated mainsail calibration stuff looking at the masthead
They looked very fast in that video. Looked to me that the chase boat couldn't keep up? And the hull shape seems to be assisting with lift IMO. Let's hope Ben has learnt from the last AC in terms of a team approach? Can't wait until the December racing as we'll see some match racing and some sort of indicative feedback as to what the racing will look like?
I suspect that the flap would start moving at you line 1.  You can see how the angles between the bulb and foil arms are all smooth until you get to line 1.  It then changes to a flat side on the bulb that would allow the flap to move free up and down.
A couple of grainy close-ups to add to the foil discussion.
The first is just after the starboard foil has been raised, showing the flap still partly up (I think?) and the water flowing from what appears to be the lower trailing edge of the foil but is actually the gap between the fixed foil and flap - both sections of the flap are partly hidden due to the angle they are raised by.
The larger "tail" on the bulb in the first shot also looks like evidence that the flaps are up?
The next (a few seconds later) shows the flap back down but with a couple of streams of water still coming out of the gap.
7 minutes ago, The_Alchemist said:
Speed calc of about 36 knots near the end of the video.
Any chance you could get a calc of any of the boats' speed at take-off?  19 knots (on one foil) has been quoted, but seems a bit high to me...
  • Like 6
1 minute ago, Ex-yachtie said:
That Jonathan Livingston gets around...:)
It would be difficult.  There is not a lot of video of the take offs and most of them are not perpendicular to the camera with a stationary point of reference.
It appears he's...
Lost
On a painted sky
Where the clouds are hung
For the poet's eye
Got that album on vinyl and CD. Can't say kids are a fan (yet). Philistines...
13 minutes ago, The_Alchemist said:
It would be difficult.  There is not a lot of video of the take offs and most of them are not perpendicular to the camera with Understand. a stationary point of reference.
Understood.   There was a video not long after Te Aihe's launch (I think) that showed her taking off in calm water in the harbour, reasonably close to perpendicular... but of course I can't find that vid now!
I know I am delinquent on this, but is there a post that explains the methodology you are using to calculate the boat speed?
Guess work..
they are only square on to the camera  with 33 seconds left of the video and then rapidly start moving away messing up any accuracy
1 hour ago, JALhazmat said:
Guess work..
Only need 1 boat length.
Well spotted @weta27
To me it looks as if the flap is indeed not along the full width of the foil wing and it's more likely at that '2' line I've marked before.
The spray and brighter line seem to be starting aft of the 'half-chord' line '1'.
Interestingly, in the second photo, the lowest bit of spray seems to be where the flexible (rubber?) patch would end, just beyond the kink.
The actual movable flap would be the part marked in yellow?
Could lines 1 & 2 both be hinges in a Fowler Flap arrangement?
19 minutes ago, MastaVonBlasta said:
They look quite fast in this clip!
And is the guy at the very back sending emails while on the boat...? ;)
No way we can just see the difference between 35 and 40, and those are very different speeds. I calculate 34 at about the time of that still.
Fowler Flap: "A split flap that slides backwards, before hinging downward, thereby increasing first chord, then camber."  I think that falls outside of the Rules:
15.4 At any cross-section, the only permitted movement of a foil flap relative to a foil wing is a rotation about an axis that remains approximately stationary with respect to the foil wing at that cross-section. This axis must be designed to be stationary...
Guess work..
I didn't actually ask you, but as you seem to know, perhaps you can explain the methodology, including why it matters that they be square to the camera?
No I am just sceptical as to the accuracy.
alchy will explain it
Boat is 75ft, so you are measuring how long the boat takes to cover it's own length i.e. against a reference object (wave crest, crane) in background. If boat is at an angle, it will take longer to cover the distance. Easiest to think about it at extreme angles to viewer...
You mean capturing the time interval between the bow passing an object and the stern?
These boats are 75ft long. Let us assume that they are doing 40kts. That means that they will move one boat length in about 1.1s
But if they were doing 35kts it would take 1.27s a difference of 0.16s
Even if the boat were square on its very unlikely that you could measure the time difference more accurately than that because of human reaction times, video rate etc (noting that with standard video at 24fps, one frame at the start and one at the end would equate to half of that time interval).
The angle of the boat to the camera would always lead to an underestimation of the speed, 10 degrees equates to a 1.5% underestimate ; 20 degrees equates to a 6% underestimate; 30 degrees equates to 14% underestimate. Those are relatively low in comparison, but I would point out that there is something about these boats that tends to make you think you are more square on than you are based on my observations
And that is before you get into the difficulties of comparing boat with boat which requires an understanding of wind conditions AWA/TWA, sea state and knowledge of what the crew were trying to test out at the time.
It matters not whether the boat is at an angle to the camera. You do have to measure the bow to the center of the stern. It does matter if the hull is at an angle to it's direction of travel or if it is turning at the time. So the accuracy is relative to how well you identify the center of the stern and the amount of angle of the hull relative to the direction of travel., as well as the accuracy of the frame timing on the video. Seems reasonable to assume we could estimate within 2 or 3 frames, which would be about 10%.
As well as wether the frames you are looking at are interpolated or not, and what other affects have been applied to the video. The time between frames is not a known factor without knowing the settings used to encode the video, the algorithm used, and some form of reference timecode.
Oh, and the hull is 68.5 feet, no? With a 6.5 foot sprit?
Rule 11.3 The forward most point on the hull shall be no less than 20.600 m and no greater than 20.700 m from TRP(67.59 ft - 67.91 ft)
17.2 The bowsprit shall extend from the hull to at least 22.760 m forward of TRP. (74.67 ft)
17.3
No part of the bowsprit shall be:(a) forward of a plane 22.860 m forward of TRP (75.00 ft)
Well, JALHazmat thinks it is magic, so let's just keep it between us.  I heard he got real upset when he found out how the Easter Bunny and the Tooth Fairy worked.  :D
I dug up some of the earlier discussion on how I did the calculations.  I get the time it take for one boat length (hull w/o bowsprit) to pass a stationary object.  Time from the frame rate of the video (typically 25 or 30 frames/sec), step through and count the frames.  I typically try to get multiple readings
It doesn't really work if the camera is moving, like traveling in another boat (unless you know the boat speed).  I usually noted that the speed is typically within about 2 knots of accuracy, but posted the speed in tenths of a knot to show differences in speed. (e.g. 23.5 knots going in one direction is slower than the 24.4 knots going in the other direction).  One time I even used the speed of a seagull to prove that the UK video had been speed up to 2x speed.
Here are some good speed estimates for when you look at a video.  The camera must be stationary (not in a moving boat) and exclude the bowsprit from the length of the hull.
If you count out the time it takes for the hull to pass a stationary object.  Count by using the old:  1 one thousand 2 one thousand (each being a ~0:25 secs), or use a timer...
time              speed
0.75 sec     53 knots
1.00 sec     40 knots
1.25 sec     32 knots
1.50 sec     27 knots
1:75 sec     23 knots
2.00 sec     20 knots
2.25 sec     16 knots
I'll be honest Alchemist, I don't think you can get to 2kts of accuracy for the reasons I gave in my post (which you kindly liked). I think at best you can claim +/ 5kts at the sort of speeds these boats are going. And that is assuming a timer not relying on verbal counting
p.s. I completely agree with JonRowe's point that frame rate is not enough on its own, the coding can make a difference. Hence why I allowed a complete frame at start and end. I reckon that is the best you can do.
How do you go through a video frame by frame?
It all sounds like it would be difficult, but as you state the difference between 40 or 35 knots is about 4-5 frames in one of these videos.  These boat travel a great distance in 4-5 fames in these videos and it is very easy to observe it in the video.
For example, here is a reading of the speed in the "Defiant - 2020-08-17 1127.mp4".  the first shot is when the boat lines up with the tower, the second shot is 5 click farther along the video.  There is no way that can make that much of an error in taking a measurement.
164126197_ScreenShot2020-10-27at10_30_35AM.thumb.png.b9f4e309c467f66b8efdeb92a9c7c762.png
400712694_ScreenShot2020-10-27at10_30_54AM.thumb.png.da3e3b9bb0ac476cbcd5ccf48848a61c.png
The speed I measured was 31.7 knots (38 clicks).  That was measuring from the bow to the middle of the stern (since the boat is at a slight angle).
 1747616602_ScreenShot2020-10-27at10_38_22AM.thumb.png.cb2642df73c3b5e5e57c7300b670fb8c.png
If you add or subtract one click to the end of the measurement you get speeds of 30.9 to 32.6 knots (31.7 +/- 0.9).   I also measured two more sections of the video just after this and got the exact same 38 clicks and thus the same speed.  This shows that the video has a consistent frame rate.  I also measured 3 more points later in the video that all gave 40 clicks or 34.7 knots.  (I know that the precision is not to the tenth of a knot, but just showing the results of the calculations).  Of course this all assume the video is posted at the real time.
you have to have download the video to your computer.
