mundt 205 #1 Posted May 8, 2020 Let's just say I am going to do something slightly foolish and cut the foot of a dacron sail to fit a different boat. Ain't got a sewing machine and let's pretend I can't or won't go to a loft. What kind of glue would you use to form the new foot, which won't be under a huge load, just to keep it from unravelling..? There's a full length batten a few inches above to handle load/shape. Any thoughts on how you would go about it? And if you're just going to poopoo on the whole idea, please refrain. Thanks! Share this post Link to post Share on other sites
Marcjsmith 463 #2 Posted May 8, 2020 hotknife to cut and cauterize the dacron. but make sure you leave enough to fold a hem then use double side seam tape to hold the hem in place. then get some sail repair tape to hold the hem down. and figure out a way to squeeze the bejesus out of it to get it really as flat a wrinkle free as possible. you'd only get one shot at it. and if you wanted to, you could always hand stitch a running stitch in the hem and then do the sail repair tape to cover the stitching. 2 Share this post Link to post Share on other sites
Raz'r 3,354 #3 Posted May 8, 2020 0 Advanced issue found ▲ 1 hour ago, mundt said: Ain't got a sewing machine And you call yourself a sailor... (and 5200 would glue the hem together, just need to hold it till it sets) 1 Share this post Link to post Share on other sites
kevinjones16 33 #4 Posted May 8, 2020 I know of a guy who recut an old genoa into a jib top. He used scissors and 5200. As far as I know it worked fine. Boat was an Olson 30. He took it to Hawaii. 1 Share this post Link to post Share on other sites
Haligonian Winterr 36 #6 Posted May 9, 2020 Sharp scissors and 5200. Hot knife is super helpful but not strictly required. The only "sail repair" kit on the VO65s (besides webbing/fitting repairs) is several tubes of 5200, rubbers and a roll of 3di HW Share this post Link to post Share on other sites
randii 87 #7 Posted May 9, 2020 Retask a cheapo hot knife for rope like this ... a solder gun might do in a pinch? 5200 makes an incredibly durable patch. It might work for a seam, as well. Share this post Link to post Share on other sites
welder 2 #8 Posted May 10, 2020 Anyone try the drsails quick curing adhesive Share this post Link to post Share on other sites
blurocketsmate 81 #9 Posted May 10, 2020 If all you're using is 5200, how do you hold it in place 'til it cures? I also wonder if 3M VHB tape could be strong enough on its own Share this post Link to post Share on other sites
Haligonian Winterr 36 #10 Posted May 10, 2020 2 hours ago, blurocketsmate said: If all you're using is 5200, how do you hold it in place 'til it cures? I also wonder if 3M VHB tape could be strong enough on its own I'm told that you use fast-cure and pretty much stare at it with a rubbing stick in your hand 'till it's cured. VHB would be interesting. I've stuck some things on pretty permanently with VHB, and there were some sailmakers using no-foam VHB to build spinnakers with no stitching for awhile. HW 1 Share this post Link to post Share on other sites
