Canhobie
Diamond Wire Rod Rigging
Anyone figured out how to compare Diamond Wire Tension with Rod Rigging (A Cat) using a Loose Gauge meant for Wire?Is there some conversion method?
Is this because you don’t want to get a rod rigging gauge?
I thought the same as mgs when I read your first first post. That you wanted to measure rod rigging with a wire loos gauge.
I'm now guessing what you actually want is a way of converting wire loos numbers to rod loos numbers (not that I can help with that)?
Sorry if this sounds a bit simple, but why not just attach a bit of your old wire to a bit of your new rod, use a strong point like a corner gate post, and a car, to wind it up till your loos gauge reads 25 on your wire, then see what the rod reads at?
What diameter rod did you go down too?
