12 metre 349 #1 Posted July 20, 2020 Contemplating a 1979 J/30 across the border. Problem is with the Coronavirus thing, I am unable to view her. The galley on the pre '84s looks kind of cramped in the photos - I like the layout in the post 84 ones much better. Anybody updated the galley on an older J/30 to be like a post 84 one? I don't care about the loss of the Q-Berth. Doesn't look like too big a project, but I could be wrong. Anything to be aware of in a '79 model? Stories of core issues abound, whether true or not, I don't know. First year of production of anything tends to be the worst though. Share this post Link to post Share on other sites
USA 5184 21 #2 Posted July 21, 2020 I personally think J Boats got the galley right on the older boats. I'm not quite sure why everyone is obsessed with the larger galley. I've never cooked a three course meal down below on any of my boats nor do I know anyone who ever has. All I need is a cooler for the beers and sandwiches and I'm all set. A big galley looks great at the boat show, but for practical use of the boat, I'd be happier with the extra quarter birth for sail/miscellaneous storage, or an extra bunk. I love J's, but they are fully cored hull and decks. Its a 40+ year old boat so it wont be perfect, but they are still usually pretty solid. Check the hull between the keel and the stuffing box. Worst case with the J/29/30 is water sometimes gets in from around the shaft and settles in the core in this relatively flat area. Other then that, the usual suspect: Bulkheads, stanchion mounts, rudder mounts, around deck hardware, etc. J/30's are a really nice all around cruiser/racer. If you end up with an older one, I wouldn't spend the extra money updating the galley. If the galley is super important, look at a Catalina 30 of the sale era. They aren't as fast or as good looking in my opinion, but they have one of the largest, best laid out interiors of 30'cruising sailboat from that era. 1 Share this post Link to post Share on other sites
12 metre 349 #3 Posted July 21, 2020 4 hours ago, USA 5184 said: I love J's, but they are fully cored hull and decks. Its a 40+ year old boat so it wont be perfect, but they are still usually pretty solid. Check the hull between the keel and the stuffing box. Worst case with the J/29/30 is water sometimes gets in from around the shaft and settles in the core in this relatively flat area. Other then that, the usual suspect: Bulkheads, stanchion mounts, rudder mounts, around deck hardware, etc. I'm not too familiar with the construction of the J/30 other than having a balsa cored hull & deck. From how you describe it, it sounds like they used balsa throughout the hull - i.e not solid glass in the keel sump area nor along the bottom centreline. What about the thru hulls - did they bevel the core around the perimeters, or just hole saw and goop in place? Share this post Link to post Share on other sites
Rambunctious 6 #4 Posted July 21, 2020 2 hours ago, 12 metre said: I'm not too familiar with the construction of the J/30 other than having a balsa cored hull & deck. From how you describe it, it sounds like they used balsa throughout the hull - i.e not solid glass in the keel sump area nor along the bottom centreline. What about the thru hulls - did they bevel the core around the perimeters, or just hole saw and goop in place? Just a hole saw. I didn't see any location on mine where the holes were prepared or the core was isolated. Despite that, the core issues were easy enough to repair. YMMV. Share this post Link to post Share on other sites
USA 5184 21 #5 Posted July 22, 2020 19 hours ago, 12 metre said: I'm not too familiar with the construction of the J/30 other than having a balsa cored hull & deck. From how you describe it, it sounds like they used balsa throughout the hull - i.e not solid glass in the keel sump area nor along the bottom centreline. What about the thru hulls - did they bevel the core around the perimeters, or just hole saw and goop in place? Its cored everywhere and there was no isolation on any through hulls or deck fittings, that will be your job to do As for the Keel sump area, I'm not sure. I had a 1996 J/24 and 1983 J/29 and I honestly don't remember if the sump area was solid glass or of it was cored or not. Share this post Link to post Share on other sites
Squalamax 40 #6 Posted July 22, 2020 19 hours ago, 12 metre said: I'm not too familiar with the construction of the J/30 other than having a balsa cored hull & deck. From how you describe it, it sounds like they used balsa throughout the hull - i.e not solid glass in the keel sump area nor along the bottom centreline. What about the thru hulls - did they bevel the core around the perimeters, or just hole saw and goop in place? The J29 is solid FG laminate around the keel sump and approximately 8-10" to either side of centeline from bow to stern. I would think the J30 is the same as it is the same hull and most of the other early J Boats were built this way. 1 Share this post Link to post Share on other sites
arcpix 30 #7 Posted July 28, 2020 On 7/21/2020 at 9:17 AM, USA 5184 said: I personally think J Boats got the galley right on the older boats. I'm not quite sure why everyone is obsessed with the larger galley. I've never cooked a three course meal down below on any of my boats nor do I know anyone who ever has. All I need is a cooler for the beers and sandwiches and I'm all set. A big galley looks great at the boat show, but for practical use of the boat, I'd be happier with the extra quarter birth for sail/miscellaneous storage, or an extra bunk. I love J's, but they are fully cored hull and decks. Its a 40+ year old boat so it wont be perfect, but they are still usually pretty solid. Check the hull between the keel and the stuffing box. Worst case with the J/29/30 is water sometimes gets in from around the shaft and settles in the core in this relatively flat area. Other then that, the usual suspect: Bulkheads, stanchion mounts, rudder mounts, around deck hardware, etc. J/30's are a really nice all around cruiser/racer. If you end up with an older one, I wouldn't spend the extra money updating the galley. If the galley is super important, look at a Catalina 30 of the sale era. They aren't as fast or as good looking in my opinion, but they have one of the largest, best laid out interiors of 30'cruising sailboat from that era. Agreed 100%. We have hull #25 built in ‘79. We race and entertain. The minimalist galley has been fine even on distance races lasting several days. Like any older boat, it’s going to have issues and will be a work in progress. That said, the J/30 is a rock solid boat. Share this post Link to post Share on other sites
Hitchhiker 782 #8 Posted August 17, 2020 I race one to Hawaii once. The small galley worked really nicely for the three of us on a 13 and 1/2 day race. Share this post Link to post Share on other sites
Bump-n-Grind 595 #9 Posted August 21, 2020 I had an older boat. I never did much cruising, just racing. I can't speak to the newer boats layout, but for what I did with the boat, I'd rather have the extra quarter-berth for knackerd crew. about the only thing I ever cooked on the alcohol stove was coffee and grilled cheese sammiches. For racing, the older cockpit layout was more comfortable without that built in coaming to bruise the backs of your legs Share this post Link to post Share on other sites
