Editor 617 #1 Posted July 21, 2020 Trippy, no doubt. Share this post Link to post Share on other sites
Trevor B 73 #2 Posted July 21, 2020 Plasti-teak deck on a Santa Cruz 33? Or something else... Mega-30? Share this post Link to post Share on other sites
AnotherSailor 257 #3 Posted July 21, 2020 Way too much $ Share this post Link to post Share on other sites
sunseeker 140 #4 Posted July 21, 2020 Restomod Ranger 33 Share this post Link to post Share on other sites
RImike 149 #5 Posted July 21, 2020 New deck with the toe rail installed backwards? 2 Share this post Link to post Share on other sites
USA 5184 21 #6 Posted July 21, 2020 better question: WHY is it? Share this post Link to post Share on other sites
SloopJonB 8,305 #8 Posted July 21, 2020 Don't like the white seams outside - that's cabin sole material. Share this post Link to post Share on other sites
'Bacco 91 #9 Posted July 21, 2020 Those fancy low stretch docklines should work well with that toe rail. 2 Share this post Link to post Share on other sites
AnotherSailor 257 #10 Posted July 21, 2020 3 hours ago, RImike said: New deck with the toe rail installed backwards? Ha, I was thinking "something is off" but then focused on the deck and missed the issue. I like the Rangers and Gary Mull designs generally speaking, but this restoration might lack some wisdom Share this post Link to post Share on other sites
Matagi 789 #11 Posted July 21, 2020 Somewhere a former 3 hours ago, RImike said: New deck with the toe rail installed backwards? Somewhere someone is slowly dying inside a bit. I like it, though. Not the toerail, but the flexiteek. Share this post Link to post Share on other sites
12 metre 365 #12 Posted July 21, 2020 4 hours ago, RImike said: New deck with the toe rail installed backwards? Not all toerails have outboard rails. For example, older C&C toerail has the rail inboard: https://southshoreyachts.com/shop/cc-old-style-toe-rail-aft/ Share this post Link to post Share on other sites
apophenia 162 #13 Posted July 21, 2020 Either someone has Black Soo envy, or someone else needs to get better at presenting images on the web. Share this post Link to post Share on other sites
Left Shift 2,751 #14 Posted July 21, 2020 No matter which way that toerail is installed, it guarantees a lifetime supply of crew with legs gone numb from hiking. Share this post Link to post Share on other sites
SloopJonB 8,305 #15 Posted July 21, 2020 4 hours ago, RImike said: New deck with the toe rail installed backwards? Holey rail works better installed that way - more defined edge to brace your foot against and it's much easier to bend that way as well. Share this post Link to post Share on other sites
mandinga 0 #16 Posted July 21, 2020 Not crew friendly Share this post Link to post Share on other sites
Great Red Shark 394 #17 Posted July 21, 2020 The point being that Flexi-teak, with the white 'seams' - isn't half-bad, and if they had a production pattern and could re-deck you for, say, a few hundo, then that'd be neat, if wood decks were your thing. Heck, you could probably make it look like that and do the foam stuff! Share this post Link to post Share on other sites
RImike 149 #18 Posted July 21, 2020 1 hour ago, 12 metre said: Not all toerails have outboard rails. For example, older C&C toerail has the rail inboard: https://southshoreyachts.com/shop/cc-old-style-toe-rail-aft/ Your correct on that and that might be the the case in the OP, but the bow chocks will eat through a mooring line in no time. I don't care how much chafe sleeve is on it those leads to not appear to be kind on the line. Share this post Link to post Share on other sites
Hitchhiker 869 #19 Posted July 21, 2020 It's a bad idea. Share this post Link to post Share on other sites
12 metre 365 #20 Posted July 21, 2020 14 hours ago, Editor said: Trippy, no doubt. Well, the ed usually leaves a clue in these "What is it?" threads. So while bow on it certainly looks like a Ranger 33, I think it has to be something by William Tripp Jr - although I don't have a clue what Tripp design this could possibly be since it doesn't have the gun turret doghouse seen in many of his designs. Share this post Link to post Share on other sites
Expat Canuck 69 #22 Posted July 21, 2020 The blue hull next to it is a C&C Landfall 38. Share this post Link to post Share on other sites
JEA 14 #23 Posted July 21, 2020 Too narrow in the bow to be a Tartan 30, maybe a Tartan 3000. Spent a lot of time on the bow of a T-30. Share this post Link to post Share on other sites
sonofasailor4x 3 #24 Posted July 22, 2020 Tartan 28. Share this post Link to post Share on other sites
Senator Seditious Maximus 360 #26 Posted July 22, 2020 Pregnant Melges 24? Share this post Link to post Share on other sites
sonofasailor4x 3 #27 Posted July 22, 2020 Nope, my first try was wrong, not a Tartan 28. But definitely an Oday 27. Designed by Alan P Gurney who once worked with Bill Tripp. Share this post Link to post Share on other sites
FixinGit 110 #28 Posted July 22, 2020 With the right application of rum and squinting at the screen i kinda looks like portrait of evil Donald Duck. Share this post Link to post Share on other sites
Strategery 32 #29 Posted July 22, 2020 Its a bad use of guys. Share this post Link to post Share on other sites
Dayracer 0 #30 Posted July 22, 2020 It is definitely NOT an Oday 27. THIS is an Oday 27.... Share this post Link to post Share on other sites
terrafirma 1,063 #31 Posted July 22, 2020 An article on the Oday 27. The coachroof slope looks bigger and higher in this dirty boat pic. So I tend to agree it isn't an Oday 27. Some said definitely is an Oday 27? Here's the article. Share this post Link to post Share on other sites
vesa 21 #33 Posted July 22, 2020 17 hours ago, Great Red Shark said: The point being that Flexi-teak, with the white 'seams' - isn't half-bad, and if they had a production pattern and could re-deck you for, say, a few hundo, then that'd be neat, if wood decks were your thing. Heck, you could probably make it look like that and do the foam stuff! I think it may actually be Esthec, pretty similar.. , but anyway, it’s a great material I have it on my boat in Med, 6 years, zero maintenance and looks like new. Share this post Link to post Share on other sites
Grande Mastere Dreade 2,157 #34 Posted July 22, 2020 On 7/20/2020 at 11:47 PM, Editor said: Trippy, no doubt. with all the discussion about spring lines and not one in sight... Share this post Link to post Share on other sites
