Steve_sos
Light wind drifter sail
  Would like a light wind sail. At the moment we have a large Genoa and a symmetrical spinnaker.
Watching the latest Atticus video they have fitted a removable synthetic Solent stay which they can use with a smaller headsail and a lightweight Drifter sail. This to me looks like a very good idea and was wondering if it would work on our cat. Another advantage is a spare emergency stay!
Another point that I liked was that the Drifter was fitted to the stay by a continuous luff zip which looked very easy to set.
Anyone used one of these or have any thoughts ?
If you have a LARGE genoa (>135% J for example) you might not gain much extra sail area. A lighter cloth will certainly set nicer in light winds.
Their drifter doesn't look like an upwind sail to me. Seems very full cut, closer to a C0
Yes it will work on a cat.  The sail they show here is more of a Code Zero than a drifter (back to that in a moment).  On a cat we would call it a screecher but the overall concept is similiar.  Its good for tight to broad (60-120 true) reaching in 5-13 knots.  On a cat I would highly recommend running a Code Zero material (DP CZ or better) because of the added loads.  If you are going to do another stay look into a furler with a proper torsion cable.  If that is too spendy for you just put a dyneema luff cable on it and bag launch it like a kite.  Both will be easier than a zipper.
And back to a drifter.  I generally refer to a drifter as a small (usually 100% LP or less) and light weight (DP CZ 5) sail that gets you moving in 0-5.  Think staysail.  We generally do not see them on cruising boats because they have the ultimate light air sail, the iron genoa.
If I have a dyneema luff cable does that mean I don't need the sythetic solent stay? I would need a deck attachement point behind the roller furling
and just use the spinnaker halyard?
Trying to avoid using the iron genoa :D
Exactly, and its way easier.  Where do you tack your spinnaker to?  I'd tack the screecher there as well.
I tack the spinnaker to a block on each bow which is why I guess another
block behind the roller furling would be needed.
I have only seen screechers set on a bowsprit on a cat?
I used one on my trimaran (F242).  I made it as a sprit sail with a high clew, good torque rope in the luff set on a bottom up furler and made out of 3/4 oz nylon; I made it with 12 % camber and very little foot or leach round.  It was sheeted short of the jib clew but outboard so I could keep the jib out on a reach (about 15 degrees off CL).  Worked well to weather in 0-5 instead of the jib at 55 to 60 degrees off the wind..  Worked well on a reach along with jib (cutter style).   Worked very well as a storm spinnaker in 35 kts plus.  I used this sail in lieu of a screecher as it was more versatile and actually worked better upwind than a code zero or screacher in 0-5 and required a lot less luff/bowsprit tension.  When wind piped to 8 or more it couldn't be used upwind (apparent wind at that time about 13).
You might want to enquire about UK's drifter that they advertise.  Sounds like it would work for you.  https://www.uksailmakers.com/encyclopedia/4-8-drifter
Luff tension is important for this sail to work so you probably will need to take the halyard to a winch.  Don't oversheet.  Hank it on over the furled jib like a cruising asymspin.  Simple and suits your boat.  Might consider having it made same size as your large genoa so you can use the same sheeting.
We have a drifter 150% set flying with a snuffer sock- it works upwind and down by messing with luff tension.  (Not a racing sail) It’s kind of too much, and I think a 120%-130% might be better. (This is all on a mono cruising sled) You might be able to launch and retrieve using a snuffer lying on deck. Fly it inside your forestay , and you’ll use it all the time, in light airs overlap is not a big deal, especially if the sail is modern nylon and light-
here’s an example, although on a smaller boat
