aA 199 #1 Posted November 9, 2020 looking at snipe systems (to be used in another class) i get the following: 1. line to clew through pole and dead ended on boom 2. launch line - attached to end of pole, through bungee’d block (hung from spreaders) 6-12” above gooseneck, through block at mast then to deck and into cleating system 3. retract - 4:1 bungee in boom through sheave at end of boom and attached to butt end of pole anything i am missing there? now big question is sleeve at front end of pole (that attaches with bungee to boom as close to mast as possible) could obviously be fabbed from pvc, but is there a standard part available? google-foo is yielding no results or i’m a dumbass who cannot figure out the right keyword Share this post Link to post Share on other sites
European Bloke 447 #2 Posted November 9, 2020 We went through this. In the end the down the mast version used in the N12 is much better. You can set it to leeward on a reach which is really effective. https://www.national12.org/news_ltr/1997/97news4.shtml Share this post Link to post Share on other sites
aA 199 #3 Posted November 9, 2020 7 hours ago, European Bloke said: We went through this. In the end the down the mast version used in the N12 is much better. You can set it to leeward on a reach which is really effective. https://www.national12.org/news_ltr/1997/97news4.shtml thanks for the reply, unfortunately that system is not an option Share this post Link to post Share on other sites
European Bloke 447 #4 Posted November 9, 2020 Do you meant this type of fitting for the inboard end? https://www.technicalmarinesupplies.co.uk/brands/ezi-launcher/ The trouble in most are designed for twin pole systems, so the fitting on the mast is a double fitting. Can I ask why you can go with the down the mast option? Share this post Link to post Share on other sites
some dude 163 #5 Posted November 9, 2020 TAP Plastics for the win 1 Share this post Link to post Share on other sites
Grande Mastere Dreade 2,147 #6 Posted November 9, 2020 14 hours ago, aA said: looking at snipe systems (to be used in another class) i get the following: anything i am missing there? ever sail a snipe? those launching systems suck balls.. there's always something that gets screwed up... Share this post Link to post Share on other sites
sailwriter 131 #7 Posted November 10, 2020 Been using the Snipe system for years on a Windmill. Use PVC parts for forward end. Spray paint for cosmetics. Save $250! 1 Share this post Link to post Share on other sites
aA 199 #8 Posted November 10, 2020 8 hours ago, European Bloke said: Do you meant this type of fitting for the inboard end? https://www.technicalmarinesupplies.co.uk/brands/ezi-launcher/ The trouble in most are designed for twin pole systems, so the fitting on the mast is a double fitting. Can I ask why you can go with the down the mast option? not ball and socket. like the inboard end here: http://www.snipetoday.org/articles/technical-experts/boats-equipments/snipe-rigging-101/ pole is too long for up the mast. the entire purpose of the launcher is to assist the 8 year old little person crewing deploy a pole 3 times her size Share this post Link to post Share on other sites
European Bloke 447 #9 Posted November 10, 2020 5 hours ago, aA said: not ball and socket. like the inboard end here: http://www.snipetoday.org/articles/technical-experts/boats-equipments/snipe-rigging-101/ pole is too long for up the mast. the entire purpose of the launcher is to assist the 8 year old little person crewing deploy a pole 3 times her size Ahh, I see thank you. I don't think it is to long for up the mast, but as the jib has more overlap I don't think you could make the pole work to leward. Share this post Link to post Share on other sites
laserandy 7 #10 Posted November 20, 2020 The standard Snipe launcher system uses a single line running from the clew, through the pole (front to back), back forward through the block on the mast that fixes the inboard end when deployed, and then down through a block and cleat on the deck. Nothing is dead-ended other than the shock cord. The system works reasonably well on the Snipe once it's set up, but I'd be reluctant to use it on anything much bigger where you can't muscle the whole boat around when it doesn't work right. A non-launcher pole works fine as well, Stars use them and we used to use them in Snipes too. Share this post Link to post Share on other sites
Snaggletooth 3,015 #11 Posted November 21, 2020 Beene wacheng thisse foire severalle dayes, haventte reade throuh it, butte woudente be bettere to starte with a 'smartere' whiskere polle? Share this post Link to post Share on other sites
mustang__1 294 #12 Posted November 29, 2020 When did i14s get a wisker pole? Share this post Link to post Share on other sites
laserandy 7 #13 Posted December 3, 2020 On 11/20/2020 at 8:25 PM, Snaggletooth said: Beene wacheng thisse foire severalle dayes, haventte reade throuh it, butte woudente be bettere to starte with a 'smartere' whiskere polle? They talk back Share this post Link to post Share on other sites
Snaggletooth 3,015 #14 Posted December 3, 2020 4 minutes ago, laserandy said: On 11/20/2020 at 8:25 PM, Snaggletooth said: Beene wacheng thisse foire severalle dayes, haventte reade throuh it, butte woudente be bettere to starte with a 'smartere' whiskere polle? They talk back 'smarte asserey' hasse certin benefittes........... 1 Share this post Link to post Share on other sites
Dex Sawash 468 #15 Posted December 6, 2020 Does the Snipe system count on the forestay being loose and bagging off downwind to get the pole through on gybes? I've never touched one but the geometry suggests it may. Share this post Link to post Share on other sites
