CaptainAhab 154 #1 Posted November 18, 2020 I’ve got one of those smart kids in my racing class who asks questions that demand good explanations. He wants to know what’s actually happening that propels a boat forward when it’s properly roll tacked. Let’s keep it simple. Single handed Laser type dinghy. Kinetics, lift, drag and the like. Reynolds numbers are a bit beyond a 15 year old. 1 Share this post Link to post Share on other sites
Steam Flyer 4,850 #2 Posted November 18, 2020 The basic factor in propelling the boat forward is that you're "sculling" the sail thru the air. Think of it as one blade of a fan, rotating from 45deg (or however far you can heel it) on one side to 45deg or however far you can heel it) on the other. Then of course, the sail flops to the new tack, and you gain more on the rotation back to (near) level. It's exactly the same physics as wind moving over the sail, except that you're moving the sail thru the air. In very light air, as you roll, easing the sail two inches adds a lot of power to your roll. There is more going on... bringing the boat to a sharp heel going into the tack -without- fanning it, helps the boat turn by two forces.... one is immersing the curve of the hull, the other is putting the drive of the sail off to one side. An exercise that's fun and helps with the 2nd part is to have then sail heeled over as far as they can, and still keep control. I like to have the kids play "Baby Ducks" which is basically follow-the-leader and I can take them on different points of sail, tack, work on right of way, etc, all close under my eye. Also at the beginner level it gives them a lot of practice in control of boat & sail at once, and learning to slow down and stop. FB- Doug 4 Share this post Link to post Share on other sites
ARNOLD 6 #3 Posted November 18, 2020 this dosent play into the actual "physics" of the roll tack on the sail itself, but keeping the board down makes it work. Share this post Link to post Share on other sites
ISA 24 #4 Posted November 18, 2020 Not too sciencey... but perhaps you could speak to him on a key formula and how it occurs twice in a roll tack: Adding weight + Heading up = Acceleration This effect is realized during a good tacking entry (and since there is no recovery/correction back down on the same tack, it can be taken higher than in upwind sailing while tacking). As you head up, you are effectively driving more flow over the surface of the foils and sails as you turn into the forces... and adding weight is the accelerator that converts potential into speed, (plus the rig movement mentioned above by Steam Flyer). He'll also benefit from this formula during a well executed tacking exit, which will always result in flattening the boat with the tiller DOWN (adding weight + heading up= acceleration, again, to finish the tack). So the boat must be tacked beyond close hauled to fulfill this formula. It's common for people to flatten while still bearing away, and this will result in "adding weight + bearing away" which is detrimental to acceleration. Analogous perhaps to accelerator plus handbrake. This concept can be emphasized in many, many areas of boat handling and speed including: starting acceleration, leeward mark rounding, downwind sailing, upwind acceleration and reset cycles, ducking, jibing, downwind upturns, by the lee pressing (in unstayed rigs) etc. There are a bunch of drills to groove this combination as well, if interested, to help make the formula connect to the physical actions. It is an important cornerstone of good dinghy sailing. Share this post Link to post Share on other sites
Gouvernail 2,734 #5 Posted November 18, 2020 You pull the sail sideways through the air and it pushes the boat forward. why?? Newton’s laws come in handy here. With respect to the sail sliding sideways the air is “sitting still.” Air is pretty light stuff but making it go off in a new direction takes energy. let’s say the sail is a flat plane set at 45 degrees to the direction it is going as the boat is rolled the air will have to be “set in motion “ by the sail. every bit of energy that is used to push the air “backwards “ has an equal snd opposite push forward on the sail but... there is sideways pushing going on as well every bit of sideways push on the air makes it equally more difficult to push the sail sideways in fact... that energy pushes the boat sideways... to leeward... you don’t want to go sideways to leeward but the Centerboard is in water which is 1000 times heavier than the air so the boat doesn’t move sideways much the rudder!!!! If you put the rudder at an angle and slide it sideways through the water as part of the roll tack, the rudder dies the exact same thing as the sail if the sailors use their bodies to push the rudder more sideways than it is set to turn the rudder pushing on the water adds to the forward force. yes... you read correctly... usually, turning the rudder slows the boat as it pushes the water forward and the water which was not in motion pushes back also.... to some extent the back side of the sideways moving sail and rudder are creating a vacuum which sucks the sideways moving sail and rudder both sideways and forward other stuff: if you roll too violently the blades and sail stall and create turbulence rather than organized harvestable energy. the roll tack has to transition into the new tack. The sloppy roll tack has way more potential to slow The boat than the good roll tack has potential to speed the boat along. ending a roll tack with flogging sails and misplaced crew destroys any good The roll tack provides. step one is to master turning the boat through the wind and arriving at the new tacking Angie with the sails trimmed and continuing to propel the boat. then.. the next step is to add a little rolling thrust In practice this might be to stay on the old high side , new low side , just a little too long for a regular tack Leave the sails a little looser than trimmed for the new tack and then climb to the new weather side . as the boat flattens to the proper heeling angle , trim the sails and gel how the body accelerates a bit as your technique improves you should be able to feel the optimum forward movement of the boat. Anecdotal: a couple weeks ago I was out trying roll tacks on my AERO. I probably tacked fifty times and three or four of those tacks were fantastic. Most were sorta ok. Another half dozen were clumsy turns best described as roll stops. what I know: if I am approaching the finish line and throwing in a perfect roll tack will shoot my bow over the line just ahead of a nearby competitor, eleven times in twelve I won’t beat that other boat... more practice is necessary Share this post Link to post Share on other sites
Major Tom 362 #6 Posted November 19, 2020 The one very obvious thing is when you rapidly heel the boat to weather the sails are in effect feeling a lift over the rig, so the sail will still be working until you are almost head to wind if you time your roll perfectly. 1 Share this post Link to post Share on other sites
martin 'hoff 702 #7 Posted November 19, 2020 You're getting good info here. Two additional points A simplification of the physics is: it's an effective way of transferring your body motion - kinetics - onto the boat, and turning it into motion forward. A complement: when coaches get sailors to practice roll tacks, they get them to practice tacks. Good outcomes all around. 2 Share this post Link to post Share on other sites
European Bloke 426 #8 Posted November 19, 2020 Forget the tack. It's simple. Take a boat out in very little wind and rock and roll and it will go. It goes because you're creating apparent wind over the rig by moving it through the air. Rocking and rolling is obviously illegal. The exception is when you tack, when you're allowed one big rock. The rules say you can only come out of the track as fast as you go in. That rule is hard to apply and often broken. 3 Share this post Link to post Share on other sites
Kenny Dumas 254 #9 Posted November 20, 2020 And racing lasers is totally hopeless without it. They all bury you on the first tack. Like, first to last. 1 Share this post Link to post Share on other sites
CaptainAhab 154 #10 Posted November 20, 2020 Thanks for some good information. SA is really good at providing a diverse perspective. Kinetics- moving one’s body moves the boat forward as long as you aren’t rocking or ooching. Fanning- You are getting a powerful fan stroke on the sail which increases your wind. Pump- In some boats it’s to one’s benefit to give a short pump at the end. It’s more of a Squeeze, because you are letting the sail out on the opposite tack before you quickly trim it back to it’s typical upwind setting. Boat & condition specific. Those are all above the water. The rig & the sailor are obvious. What’s happening underwater? Hull type(round vs flat) Does fanning the center/dagger board produce any useful forward motion like the sail? I’m always surprised how well & fast a Laser sails straight when it’s completely leaning over. We play around with that to prove how far it’s possible to heel. Please keep going. Cheers I like to have the kids fix their rudders and try their roll racks. For the advanced ones we take away their rudders. This is one of the most impressive boat handling vids ever. I show this on the blowout days. 2 Share this post Link to post Share on other sites
MrSwordfish 13 #11 Posted November 25, 2020 Two basic things are at work here: 1) Most boats have a hull design that makes them turn to weather when heeled. So, if you heel the boat to leeward, it will head up without using the rudder, or with less rudder. Since the rudder is basically a brake, steering with the hull instead of he rudder is faster. Then, once the boat has passed head to wind and is on the new close hauled course, heeling it the other way will stop the turn, again without using the rudder. This is why roll tacking is legal - you're allowed to use heel to facilitate steering. 2) The essence of the roll tack, what makes it fast, is the burst of speed you get when you bring the boat back to flat at the end. By "fanning" the sail across the air, you push a lot of air backwards. Air goes backwards, the boat squirts forward. You can use this idea at the start - when the gun goes off (or slightly before) roll the boat to leeward and then hike it back to flat. Basically, half a roll tack. 3 Share this post Link to post Share on other sites
Major Tom 362 #12 Posted November 25, 2020 1 hour ago, MrSwordfish said: You can use this idea at the start - when the gun goes off (or slightly before) roll the boat to leeward and then hike it back to flat. Basically, half a roll tack. That would be classified as rocking, which last time I looked at a rule book was illegal unless you were sailing a class where the rules specifically allow rocking, pumping and ooching.......... Share this post Link to post Share on other sites
Wavedancer II 117 #13 Posted November 25, 2020 Major Tom: I have watched Laser medal races where they all used this 'technique' at the start. Only one time, and typically in low wind conditions. Laser Radial Medal Race | Hempel World Cup Series: Miami, USA - YouTube Start is around 7.5 minutes into the video Share this post Link to post Share on other sites
NYBOZO1 10 #14 Posted November 25, 2020 Much to be learned here.... Share this post Link to post Share on other sites
MrSwordfish 13 #15 Posted November 26, 2020 22 hours ago, Major Tom said: That would be classified as rocking, which last time I looked at a rule book was illegal unless you were sailing a class where the rules specifically allow rocking, pumping and ooching.......... You are allowed to heel the boat to facilitate steering, so at the start you can heel the boat to steer up to a close hauled course. Perfectly legal. But you only get to do it once. Share this post Link to post Share on other sites
MrSwordfish 13 #16 Posted November 26, 2020 19 hours ago, NYBOZO1 said: Much to be learned here.... Why do they all have what looks like a giant block of cheese strapped to the bow? Share this post Link to post Share on other sites
NYBOZO1 10 #17 Posted November 26, 2020 In the big war, some were known as "cheese eating surrender monkeys". Share this post Link to post Share on other sites
Raptorsailor 286 #18 Posted December 6, 2020 Pretty sure you’re simply giving the sail a bit of exta airspeed for a couple of seconds that gives the boat a little boost. Share this post Link to post Share on other sites
garland823 3 #19 Posted December 7, 2020 Intuitively I always thought the centerboard/daggerboard did the majority of the work in a roll tack. Share this post Link to post Share on other sites
MrSwordfish 13 #20 Posted December 8, 2020 9 hours ago, garland823 said: Intuitively I always thought the centerboard/daggerboard did the majority of the work in a roll tack. Yeah, big airfoils up in the thin fluid , little hydrofoils down in the dense fluid. That's sailing 101. I don't know that the centerboard comprises a "majority" of the effect, but it's certainly a big part, which I neglected in my summary. But the sails are a big part of it too. Both foils work together; in "normal" sailing, air and water flow over the foils and generate lift. In a roll tack, the rolling makes more fluid (water and air) flow past the foils generating more lift than would be there in the absence of rolling. Not exactly rocket science. " Share this post Link to post Share on other sites
