mcexley001 18 #1 Posted November 19, 2020 Similar to what we saw on ITUK recently, American Magic's Patriot now has a main with battens extending past the leech. Any consensus on the intent of this development? Screen grab from Justin Mitchell's Youtube page. 1 Share this post Link to post Share on other sites
Indio 782 #2 Posted November 19, 2020 6 minutes ago, mcexley001 said: Similar to what we saw on ITUK recently, American Magic's Patriot now has a main with battens extending past the leech. Any consensus on the intent of this development? Screen grab from Justin Mitchell's Youtube page. Fuck that's a lot of spray... Share this post Link to post Share on other sites
Windskip 15 #4 Posted November 19, 2020 9 minutes ago, Indio said: Fuck that's a lot of spray... 20-24 knots windspeed, and they appeared to be doing little splashdowns a lot and then popping right up, maybe testing some new mode. Very very fast at times from the look of things though. 2 Share this post Link to post Share on other sites
A3A 85 #5 Posted November 19, 2020 The Italian boys are FOS. This is more likely a quick and dirty test of a smaller head width for heavy air. It's cheap and easy to modify an older existing main this way and not sacrifice a set of battens, nor mess up all the shape control scheme in the top of the sail. At around $200 per meter, the 16 battens (8 per skin) will run near $20k. If the concept is good, then you build a sail to size with a proper set of battens. 1 Share this post Link to post Share on other sites
I14RACER 176 #6 Posted November 20, 2020 5 hours ago, A3A said: The Italian boys are FOS. This is more likely a quick and dirty test of a smaller head width for heavy air. It's cheap and easy to modify an older existing main this way and not sacrifice a set of battens, nor mess up all the shape control scheme in the top of the sail. At around $200 per meter, the 16 battens (8 per skin) will run near $20k. If the concept is good, then you build a sail to size with a proper set of battens. Nah. These guys have money to burn. They are not doing anything half way. Even for testing. They have in-house sail designers and makers. This was intentional. So that they could meet sail width measurement specs and make the sail smaller for lower righting moment in heavy breeze. 1 Share this post Link to post Share on other sites
kindofblue 0 #7 Posted November 20, 2020 The battens remind me of our Hobie Cats ;-) Share this post Link to post Share on other sites
A3A 85 #8 Posted November 20, 2020 12 minutes ago, I14RACER said: Nah. These guys have money to burn. They are not doing anything half way. Even for testing. They have in-house sail designers and makers. This was intentional. So that they could meet sail width measurement specs and make the sail smaller for lower righting moment in heavy breeze. The rule allows a full meter of head width between max and min. They must be seriously overpowered if they need to get smaller than minimum and resort to measurement tricks. I'm not sure the AC sail measurers would measure the straight to the batten tips. It would be to the intersection of the projected leech segments. Share this post Link to post Share on other sites
Mozzy Sails 444 #9 Posted November 20, 2020 7 hours ago, A3A said: The rule allows a full meter of head width between max and min. They must be seriously overpowered if they need to get smaller than minimum and resort to measurement tricks. I'm not sure the AC sail measurers would measure the straight to the batten tips. It would be to the intersection of the projected leech segments. this is all in the NYYC thread. And yes, the measurement arbitration put out the adjudication that this is exactly what they do. Is the width of the AC logo specified anywhere? Perhaps that is sized so it would fit he min head girth? 1 Share this post Link to post Share on other sites
.......................... 167 #10 Posted November 21, 2020 19 hours ago, kindofblue said: The battens remind me of our Hobie Cats ;-) I was going to say it looked like a 1990 Chris Cairns Tornado sail built for the windy worlds with the hollow between the battens and the straight run from batten two to five to let the middle leech blow/twist open in the big puffs... Share this post Link to post Share on other sites
alanjs 0 #11 Posted November 21, 2020 within the rules, a mainsail area can be as low as 135 sq. m with minimum head size (maximum foot). The deduced sail area and lower CofE results in increased performance in higher winds (as illustrated yesterday?) Share this post Link to post Share on other sites
atwinda 87 #12 Posted November 21, 2020 On 11/19/2020 at 8:32 PM, I14RACER said: Nah. These guys have money to burn. They are not doing anything half way. Even for testing. They have in-house sail designers and makers. This was intentional. So that they could meet sail width measurement specs and make the sail smaller for lower righting moment in heavy breeze. I genuinely believe this mindset does not take into account a cost-benefit analysis. SURE they COULD spend $25,000 to cut the main and battens to try an idea, but is that worth it if you could test the same case for $2000-$4000 and avoid ruining a set of expensive battens in the process? Let's say it didn't work out, and you cut the battens down- if those battens were not specific to that mainsail, you're out a ton more money to use the non-recut main again. And again... Recuts take TIME (the one thing you can't get back), what other sails are they building? With the first regatta a month away, are they going to be bringing new sails online for that... You'd expect those blanks to be arriving around now to be finished by then. Ya gotta make sure the graphics team has plenty of time to paint/apply the pretty sponsor logos on the sails. I don't think "they have money to burn"- that money has to be accounted for and used prudently to ensure the team as a shot of their goal. Spend carelessly and you may not have cash at a crucial moment to develop and implement a new system. ETNZ have been up front about bring new gear online at very late stages of the cycle- and I am sure all these teams are applying an agile mindset to their final configuration. I stand by this was a quick recut. Share this post Link to post Share on other sites
snaerk 45 #13 Posted November 21, 2020 Na na na na na na na na na na na na na na na na Bat-Main !!!! 2 Share this post Link to post Share on other sites
