DIY boat cover
8 replies to this topic
#1 g2g
g2g
  • 55 posts
Posted 03 December 2009 - 02:55 PM
Up on the hard to do a lot of work this winter. Anybody ever made a 'roof' over their boat? I don't want to go all the way to the ground, but I do want to be able to stand or nearly stand up. 37' on deck, 10'-6" beam. This is in the PNW and wet is a larger concern than wind.
Thanks.
#2 MoMP
MoMP
  • 3,335 posts
Posted 04 December 2009 - 01:05 AM
There are portable garages that may be able to be altered for height. Basically, a big tent.
#3 Ishmael
  • 16,647 posts
Posted 04 December 2009 - 01:52 AM
There are lots of folks on the cold half of the continent who do this every year. Basically, a backbone of 2x4's supported by struts, PVC pipe or similar bent over those and tied off to the stanchions/toerail/slow neighbors, then heavy tarps over that. Make tiedowns wherever you want in the tarp by lashing golf balls into a pocket in the tarp. You can get glue-in zippers and vents to customize.
There's enough wind in the PNW on occasion that you'll want to make sure the assembly doesn't blow your boat over onto someone else's toy. :blink:
#4 soling2003
soling2003
  • 2,356 posts
Posted 04 December 2009 - 06:46 AM
What Ishmael said
#5 Gato Salvaje Pequeno
  • 189 posts
Posted 30 May 2010 - 08:56 PM
Pull the mast and put in a boathouse. Warmer in winter and cooler in summer.
#6 Jim Conlin
Jim Conlin
  • 578 posts
Posted 30 May 2010 - 10:00 PM
A good method from Practical Sailor
#7 Oxygen Mask
Oxygen Mask
  • 6,672 posts
Posted 31 May 2010 - 09:34 PM
As usual, Practical sailor isn't very practical... ;)
Can be real simple. PVC pipe is cheap and bends nicely.
Very large tarps can be had for relative cheap from Harbor Freight, or heavy duty clear plastic from Home Despot..
some ideas:
http://www.pearsonin...ver_frame_4.jpg
http://i107.photobuc...II/IMG_0269.jpg
http://doorgarden.co...eenhouse-67.JPG
#8 Greyhawk
Greyhawk
  • 1,586 posts
Posted 31 May 2010 - 10:43 PM
Full Story
#9 Jim Conlin
Jim Conlin
  • 578 posts
Posted 01 June 2010 - 06:53 PM
If you want something to enclose the whole boat, the Stimpson bow sheds are OK.
