CheeseBurger, on Jan 22 2010, 11:34 AM, said:
Tom O, on Jan 22 2010, 08:14 PM, said:
Icecube, on Jan 22 2010, 11:05 AM, said:
Naviguesser, on Jan 22 2010, 07:59 PM, said:
Icecube, on Jan 22 2010, 10:53 AM, said:
Only if you can build it from parts supplied from somewhere else, which is not true in this case. The 'assembled' 'sail' can only be made from these specific custom-'constructed' US-made panels.
I agree, but Oracle's argument has been the 'sail' must be made in Switzerland. If Alinghi took panels from another boat, albeit a rather large one, i'm sure they could still make a 'sail' suited to their boat. [color="#4169E1"][/color]I'm not sure you understand the concept of load path fiber orientation. Only if the larger boat had sails with very close to the same dimensions as Alinghi would this work.[color="#0000FF"][/color]
I'm sorry but i'm of the opinion that Oracle have opened up a can of worms, and i'm also of the opinion that it be either everything or nothing constructed in the home country. And if i were in charge, i'd want to see all sailors and designers etc also from the home country. Just my opinion.
[color="#4169E1"][/color]I believe it will be proved that USA is very close to already meeting your everything made in country and have the data to prove it.[color="#0000FF"][/color]
Also Alinghi sails are very close to being done in Switzerland.
Why are customs sails more important that custom idraulics? Who decides?
In this case the advantage of the Defender comes out in full:
- To win this battle, BOR must demonstrate that Alinghi is not CiC AND USA is 100% CiC
- To win this battle, Alinghi must only demonstrate that BOR boat is not 100% CiC. Finding one single Mexican built bolt is enough. If both boats are disqualified, Alinghi keeps the cup.
Alinghi can require BOR to be CiC even on parts that are not CiC on A5!!!
BOR gave Alinghi a very good argument to attack BOR, should Alinghi loose on the water.
I also liked the arguent that SNG as trustee should be given access to all BOR document to fulfill their trustee obbligations to verify that USA is CiC. :lol:
I agree the sails arrive in Switzerland very close to finished.
If Team Alinghi bought a bunch of Carbonfiber thread bundles, Mylar and glue from North in Minden and transported these raw materials sperately to Switzerland and the cut, alligned and bonded everything together in Switzerland, I would agree with you that there is not much difference between sails and hydraulics to trim them. But, that's not the case. Furthermore if USA has Italian hydraulics in the boat and the court deemed them non-CiC, the most probable decision the court would hand down would be to fit US domestic components in place of the Italian components. USA might suffer a small weight penalty due to the change. But, I believe they would still be able to compete and not give up as much as Alinghi giving up 3DL.
So, I disagree with your opinion.
Your reasoning applies if there is any rouling BEFORE the race. I doubt it.
After the race, BOR will not be able to replace anything if found non-CiC.
Please notice that the phrase "So, I disagree with your opinion" is not acceptable in this forum. Please replace it with a personal insult of your choice B) :lol: .
And, now we get back to the reason that BMWO filed this motion while still negotiating the Singapore MC. It was to meet the courts deadline for filings to be heard prior to the race. The court may choose not to hear the case prior to race day. But, they are also not going to disqualify either party for rulings they chose to make after the fact. At the most they say make these corrections and race again. IMHO
Sign In
Register
Help
MultiQuote
